Old Dec 10, 2011, 11:02 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Question
Firmware Updater will connect but setup utility does not
Hey guys I am just now getting to hooking my green v1 pro board back up after I hooked up the 12v line wrong and popped the 5v reg.
so all looks well, i get the flashing green light but it is will not arm.
so i wanted to look at the diag tab in setup utility and i cannot get the utility to connect to the board.
This definitely could be a problem that was caused by me blowing the 5v line.... but it seems to work, green light, beeping and such, purple light with no RX.
I am using a windows 7 PC x64 and downloaded the driver and restarted.
what is weird is that i can flash it with the flash program and it connects.
anyone else run across this before?
Adidas4275 is offline Find More Posts by Adidas4275
Old Dec 10, 2011, 11:09 PM
Adidas4275's Avatar
Joined Mar 2011
well i got it to connect,
I uninstalled the driver, restarted, unplugged the usb, reinstalled the driver, plugged in the usb and then restarted and then it connected.
not sure what happened, but atleast i got one problem figured out, on to the next one
Okay I spoke to soon, I figured out my AR8000 was part of the issue (perhaps another casualty of reverse polarity) but now the damn setup utility isnt connecting unless I uninstall the driver, restart and reinstall.
anyone else have this issue with the setup utility?
Old Dec 11, 2011, 10:14 AM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Check and make sure that no anti-virus software is running.
Also, in setup you sometimes switch tabs and then re-connect.
photronix is offline Find More Posts by photronix
Old Dec 11, 2011, 01:04 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I run Norton (Symantec) Internet Security/anti-virus 100% of the time and have never had a problem installing or running any FP programs.
RC Man is offline Find More Posts by RC Man
Old Dec 12, 2011, 09:47 AM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
I run similar and also have never had a problem. However, sometimes the solution to any software not running correctly is the anti-virus software.
Help! HFP will not power up after firmware update wayneabonga Hoverfly Technologies 1 Nov 08, 2011 11:15 AM
Help! HFP board will not power up after firmware update wayneabonga Hoverfly Technologies 5 Nov 06, 2011 08:07 PM
Discussion mCPx will not bind or connect to Dx6i creeddrummer87 Micro Helis 5 Mar 22, 2011 10:07 PM
