Old Dec 10, 2011, 10:20 PM
Zombee is offline
Find More Posts by Zombee
Joined Jan 2011
Quad Build/Plan, Will it work? Goodluckbuy,HobbyKing,Ebay
Hello there guys, I got some question about this plan i have on my mind, I am planning on building this by my self with physical help of a professional, i live on a small town of dysart in queensland australia, with no one who flies rc except me. So this is going to be my first quad build and first ever fly with a multirotor.
Now this is going to be my setup. i gathered all the cheapest parts i could get and i want you guys to see if its a good idea or recommend a better one
FC:http://www.goodluckbuy.com/kkmultico...adcopter-.html
Frame:http://www.goodluckbuy.com/kk-mk-x52...dform-kit.html (already bought, waiting to arrive)
Motors:http://www.ebay.com.au/itm/outrunner...item4ab15ae17b 4x
ESC:http://www.ebay.com.au/itm/Mystery-R...item27b3223dbe 4x
ACCESORIES
EXTENSION WIRE:http://www.hobbyking.com/hobbyking/s...mtr_BLACK.html
PROPS:http://www.hobbyking.com/hobbyking/s...2pc_pack_.html , http://www.hobbyking.com/hobbyking/s...7-6645EE95C0AB
I wanna know if you guys think it will work. as i dont wanna be disappointed at the first time . i spent alot of time researching for this parts, i wanted to spend as less as i can because i dont have that much budget. but if you guys think it wont fly, i want you guys to give me a recommendation of a different cheap part.
Zombee is offline Find More Posts by Zombee
Old Dec 10, 2011, 11:27 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
those ESC's may not work... it says "Throttle range self-adjusting" ... i think you need programmable ESC's for multicopters...
SGsoar is offline Find More Posts by SGsoar
Old Dec 11, 2011, 12:03 AM
GALLAWAY is offline
Find More Posts by GALLAWAY
--Parking Lot Pilot--
GALLAWAY's Avatar
Hertford, NC
Joined Feb 2005
Did you look at this? http://www.goodluckbuy.com/x525-v3-q...lticopter.html
TG
edit:
Ohhh... See you already bought the frame.
GALLAWAY is offline Find More Posts by GALLAWAY
Old Dec 11, 2011, 01:18 AM
FE Obsessed is offline
Find More Posts by FE Obsessed
Flight Surgeon
FE Obsessed's Avatar
United Kingdom, Portchester
Joined Jul 2005
Can I suggest a better flight controller?
The KK Boards are amazing and cheap but don't have accelerometers to auto level (Great when starting out) or other features (gps eventually), I started with one but wish I had gone straight to MultiWii.
This MultiWii board should give a much more stable flight, doesn't cost much more and you can upgrade the sensors with breakout boards later, there are several threads on them in this forum
http://www.rcgroups.com/forums/showthread.php?t=1551599
http://www.goodluckbuy.com/mwc-multi...breakout-.html
A Power Distribution board makes thing SO MUCH easier
http://www.goodluckbuy.com/multicopt...ion-board.html
The LCD Means you can change settings at the field easily but isn't strictly necessary
http://www.goodluckbuy.com/mwc-multi...er-module.html
And If you wanted to push the boat out a little you can upgrade to the SE With Magnetometer (For absolute heading hold) and Barometer (For Altitude Hold)
As far as Esc & Motor choice are concerned there are better ones for not too much more, everything on a Quad mounts up fast as you have to buy 4 of everything!
The Mystery ESc's are Probably fine But I would choose these
http://www.hobbyking.com/hobbyking/s...rammable_.html
And the Motor KV seems a bit high, you will be better off with the Keda 20-22L, they generally have the best rep for budget motors and work well with the 10 x 4.5 SF props
http://www.hobbyking.com/hobbyking/s...er_20_22L.html
FE Obsessed is offline Find More Posts by FE Obsessed
Old Dec 11, 2011, 02:32 AM
Zombee is offline
Joined Jan 2011
Yes, i would consider this MultiWii FC, i was looking at it but i just think that kk is easier to flash, and ive never flashed anything before except my samsung cellphone xD, but yes sure i find it much more interesting i will probably just go with this MW fc.
and yes about the motor. i just decided to use 30a setup because it seems unique in some way i dont know why it just came into my mind, but yeah ill consider getting a 20a first then probably upgrade.
but what do you think about this motor?
http://www.ebay.com.au/itm/outrunner...item1c21ba5983
using a it with TGY Plush 30a?
390w sounds pre awesome. i also am putting fpv equipment, so i might use 2 2200mah batteries parallel and be the power source for both fpv and the escs. and yes that Power distrubutor thing also, i was gonna buy it but i just didnt put it on the list xD
Edit: I will try my best to get the MW fc with acc baro and magno, i just need to get some more juice from me parents xD
Old Dec 11, 2011, 02:33 AM
Zombee is offline
Joined Jan 2011
TG
edit:
yeah haha, i was gonna just buy this one but when i talked to there tech they told me that the motor were no good based on there customers
Old Dec 11, 2011, 02:35 AM
Zombee is offline
Joined Jan 2011
Yeah, i think soo too but i think it can be programed with transmitter, and i also think this is the same with plush escs, i got a card programmer for tgy, and i was thinking maybe it can work with this one. if not i might consider buying 30a esc TGY plush
Old Jan 16, 2012, 01:12 PM
kopauk is offline
Find More Posts by kopauk
Singapore, Singapore
Joined Nov 2011
ebay,hobbyking
hi
I am new to RC.I am trying to build my first quad.
I already ordered this
1.Aircraft X450 CNC Metal MultiCopter Quadcopter XCopter Frame 4-axis ,
2.FC KK FC Board , 3.Power board.
Now I am looking
4.NTM Prop Drive Series 28-30A 750kv / 140w and 5.HobbyKing 30A BlueSeries Brushless Speed Controller
6.I already have ZIPPY Flightmax 4200mAh 4S2P 30C LiFePo4 Pack.
Please suggest me this is a correct setup or not.
thanks
kopauk is offline Find More Posts by kopauk
Old Jan 16, 2012, 01:39 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
That's an expensive KK board, the HK version is a lot cheaper.
http://www.hobbyking.com/hobbyking/s...a168PA%5F.html
http://www.hobbyking.com/hobbyking/s...occessors.html
Erknie is offline Find More Posts by Erknie
Old Jan 16, 2012, 02:13 PM
Soupbones is offline
Find More Posts by Soupbones
Soupbones's Avatar
Australia
Joined May 2011
Originally Posted by kopauk View Post
hi
Now I am looking
thanks
I would go for a stronger frame, something like in the original post. Being that your new to quads and RC, your going to crash it on the first day, guaranteed, and that frame there will break being thats its CNC arms. Meaning you will be waiting two weeks for another or parts.
I suggest going for a X525 frame, something strong, or even better, a DJ frame.
Soupbones is offline Find More Posts by Soupbones
Old Jan 28, 2012, 09:18 AM
kopauk is offline
Joined Nov 2011
Thanks Soupbones.
I already ordered a DJI frame from Ebay . I also bought above NTM motor and TGY plush 30 A esc.Now I am worry about how can I mount NTM motor on those frame.
I have accessories pack but I can buy required screws from my local shop.Can it be fit that motor on my frames?
Old Jan 28, 2012, 07:32 PM
Soupbones's Avatar
Australia
Joined May 2011
As suggested earlier, there are Multiwii boards which are more stable then the cheaper KK boards. Also suggested was you can add extra sensors for things like altitude hold to them.
Even better, and cheap is the Crius SE MultiWii board which is a multiwii board with all the sensors already on the board. Cost under $80US posted from Goodluckbuy. Just search it out. Bit of mucking around to get them tuned up, but worth it. I am still in the process of tuning mine at the moment. I have it stable in ACCRO mode. Soon as I get the sensors correct it will be even better. These boards have three added sensors, Accelerometers, Baraometric Altitude hold and magometer heading hold sensors. Great buy for under 80 bucks if you ask me.
Old Jan 29, 2012, 04:11 AM
kopauk is offline
Joined Nov 2011
goodluckybuy
hi
I found this board from goodluckybuy.
how about it.
Old Jan 29, 2012, 05:22 AM
Soupbones's Avatar
Australia
Joined May 2011
Thats just a basic Multiwii board. No accelerometers for auto level and no other sensors. May as well get a KK board, as it does the same.
If you want the extra sensors for better and more level flight and altitude hold, then you pay a bit more for boards with these extra features. Most with these extra features cost well over $100US, usually a lot more. This one -http://www.goodluckbuy.com/mwc-multi...ard-quadx.html is pretty darn cheap for what you get.
Old Jan 30, 2012, 11:49 AM
kopauk is offline
Joined Nov 2011
thanks Soupbones
I will be going to buy it
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Idea Finally .... A Sensible Gun Registration Plan That Will Work dumbthumbs Life, The Universe, and Politics 43 Nov 21, 2009 10:56 AM
Discussion Will the Spektum AR6000 work with HobbyKing? Berkie Radios 5 Oct 12, 2009 07:16 PM
Discussion Quad Tiltrotor Landing Gear Design - will it work? maxvtol VTOLs 1 Aug 30, 2007 12:37 PM
Discussion 54/60" JW build instructions (Will also work with 36") KingOfTheHill Dynamic Soaring 0 Nov 06, 2006 08:20 PM
