Old Dec 10, 2011, 08:31 PM
flashbang is offline
Find More Posts by flashbang
flashbang's Avatar
Joined Dec 2011
Help!
Wild Hawk motor rotation?
Looked hi and low all over the WWW and got nothing but conflicting results for these two questions.
What would be the stock motor rotation looking at the motor from the rear of the plane? And which way to install a EMP 6 x 3E prop?
flashbang is offline Find More Posts by flashbang
Old Dec 10, 2011, 08:42 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Motor should turn CW looking from the rear.
Prop numbers should face forward.
BTW, I have a Wild Hawk and I'm holding an EMP 6x3E in my hand.
If that doesn't fix it something else is wrong.
Let us know.
bartricky is offline Find More Posts by bartricky
Old Dec 11, 2011, 07:18 AM
flashbang's Avatar
Joined Dec 2011
Thanks for the answer. Nothing is broke. I never tested the stock motor for rotation. I just took the WH out of the box and split it in half. I'm in the process of upgrading the motor,esc and new Lipo power. Using a Emax 2836-24 Inrunner Brushless Motor and have learned that depending how the wires are attached it will change rotation from CW to CCW, but not knowing which way a WH motor should spin created a key element that was missing.
Old Dec 11, 2011, 07:50 AM
bartricky's Avatar
The CW rotation looking from the tail is a standard for all RC plane electric motors.
The rare exceptions being twin motors when you want one motor to counter rotate.
Pusher props are mainly a throw back to fuel engines where you can't reverse the rotation.
Plane sounds very good. I found that adding a little rudder surface helps. Glue the tailfeathers on, balance the CG on the wing spare covers.
Pic of Jr. Hawk... same plane.
Discussion Wild Hawk motor/lipo upgrade plan? flashbang Electric Plane Talk 1 Dec 04, 2011 06:58 PM
Sold Wild Hawk 3ch tx/rx, brushed ESC, motor, 2 servos and wings cardnation Aircraft - General - Radio Equipment (FS/W) 3 Nov 02, 2011 11:35 AM
Discussion Wild Hawk motor mounting cnterfld21 Beginner Training Area (Aircraft-Electric) 9 Jun 22, 2011 09:18 PM
Wanted Hawk Sky, Wild Hawk, Sky Surfer, etc dpw21562 Aircraft - Electric - Airplanes (FS/W) 5 Mar 06, 2011 07:12 AM
Wanted Wild Hawk, Hawk Sky, Sky Surfer, dpw21562 Aircraft - Sailplanes (FS/W) 0 Mar 03, 2011 07:03 PM
