USA, ME, Ellsworth
Joined May 2008
Park 400, 56 grams, 920 Kv - http://www.horizonhobby.com/products...920kv-EFLM1305 Park 480, 87 grams, 910 Kv - http://www.horizonhobby.com/products...910kv-EFLM1500 If you want to add a little more power to the equation buy a motor that is a little heavier. Most motors produce about 3 Watts of power for each gram of motor weight so if you mutltiply the weight in grams by 3 you will get about that much power. Note that the 87 gram Park 480 is described as a 250 Watt motor, multiply 3 x 87, that is 251 Watts. Many of the other numbers in the specs are presented out of context, may be presented in a confusing or even dishonest manner, and are prone to mistakes or exaggeration. The 3 watts per gram rule is easy to apply and seldom very far off of the mark. You don't mention what Kv you want, that is an important consideration if you did not know that. If you don't buy a motor of the right Kv for the propeller you intend to use the motor will not work for you. Kv selections do not need to be precisely the same from one motor to another, but should be similar, like withing a few hundred RPM or less. Jack |
USA, ME, Ellsworth
Joined May 2008
http://www.gobrushless.com/shop/inde...how&ref=motors Quote:
It is easy to misuse or misapply the term "watts" as far as where they are or come from. Especially so if you are not the most technically minded person in a crowd that includes a lot of more technical minds. I always say motors "are good for" or "produce" or "crank out" their power and it is measured in watts. That works for me and the meaning is generally understood I think. Jack |
| Thread Tools | |
| For Sale E-flite Park 400 Brushless Inrunner Motor, 4200Kv with ESC, gearbox and prop | rampman | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 10, 2011 07:31 PM |
| Sold E-Flite Park 400 brushless motor $20.00 | rconfused | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 21, 2011 10:28 AM |
| Sold E-flite Park 400 brushless motor 3700kv new never used $25 shipped | cleansho93 | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 14, 2011 11:52 PM |
| For Sale 4000KV Brushless Outtrunner Motor For Aling 450 E-FLITE 400 | RCMODELOPART | Aircraft - Electric - Helis (FS/W) | 1 | Jun 08, 2009 10:38 PM |
