Old Dec 10, 2011, 06:45 PM
eyeinsky1 is offline
Find More Posts by eyeinsky1
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
KK control board aeroplane
I have been researching the use of muli-copter arduino base open source board for the purpose of airplane stab for AP/AV/FPV. I decided to include the KK control and so far it looks like very good cheep replacement for 3 standard gyros.
This test was complete to proof operation evaluation of the system operation. I was not able to use the standard layout of board because the dimension would not fit in the fuselage. So to I position the board with the direction arrow pointed up, this position the yaw gyro in the pitch axis orientation. The rest of the axis are connected as orientated to proper operation.
My test flight today shows very nice operation of this board. I only chose the typhoon to proof that you could take very responsive, non stable aircraft and it could be made to fly better than the most stable trainer.
Thanks for interest, any question or discussion welcome.
KK Airplane (4 min 43 sec)
eyeinsky1 is offline Find More Posts by eyeinsky1
Old Dec 10, 2011, 06:46 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
The Standard configuration is not the best for fix wing operation due to the dimension and orientation of gyros.
I mounted the board vertical arrow straight up this resulted in the need to swap channels to maintain proper gyro orientation.
Here's the flying wing setup with rudder optional.
The throttle channel must be connected to the both KK board and the ESC, I suggest a Y cable.
Arming is done by keep throttle at idle and Rudder over hard or in my modified configuration elevator down. If the board does not arm reduce throttle trim till arming can be achieved.
Useful Links:
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
Where I got my board:
http://www.ebay.ca/itm/260881453731?...ht_6221wt_1048
I've seen them little cheaper, but make sure you get the USB loader too. Later you can buy them seperatly but don't buy the HK ones with only 4 output ports.
black board 5.5
Tutorials:
KKmulticopter Flash Tool - Tutorial (1 min 47 sec)
How to revers gyro?
OpenAero Gyro Reversing Procedure (1 min 17 sec)
Here's the final fitted project. Still some small adjustment to dial her in but the systems are working fine. We now using the OpenAero SW 1.4, this is much nicer than the 2.0 KK aeroplane SW because there is no arming required and the servos have much less jitter. Later the OpenAero will support the vertical mounted board so the standard configuration will work fine and the gyros swapped around will not be required.
HK EPP FPV KK OpenAero Aerial Video.mov (6 min 41 sec)
Old Dec 11, 2011, 06:25 PM
Diedsen is offline
Find More Posts by Diedsen
Joined Oct 2011
Re:
Wow!
How did you manage to get this board working?
I've looked in to this, but I couldn't get the board to arm..
Can you tell us more about how you accomplished this?
Like you sad; really nice replacement for 3 gyro's.
Space wise but also cost wise!
Diederik
Diedsen is offline Find More Posts by Diedsen
Old Dec 11, 2011, 07:55 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Justed added more detail including arming proceedures, I will add new detail to page 1 and 2 when I get time.
Here’s a video with the KK control on my HK EPP FPV airplane, wind were very rough and gusty this day so a good test for stability test.
HK EPP FPV - KK Control Aero Mode (1 min 24 sec)
Standard Aeroplane OpenAero KK control HK EPP FPV test flight was successful. Wind was low sky’s were foggy, the OpenAero sw performed excellent, we perform two test fwd and aft C of G operation.
HK EPP FPV KK OpenAero Test Flight.mov (8 min 25 sec)
Old Dec 11, 2011, 08:46 PM
MauiNate is offline
Find More Posts by MauiNate
United States, CA, Ventura
Joined Aug 2007
Does the board run the servos at 50hrz or higher?
MauiNate is offline Find More Posts by MauiNate
Old Dec 11, 2011, 08:54 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Not sure
Old Dec 11, 2011, 09:29 PM
MauiNate is offline
Joined Aug 2007
I'd be careful about running analog servos higher than that. The refresh rate has a tendency to kill servos. FMkit made a stabilizer for a wing, and it worked great for about 3 flights, then his servos died because he was working them too much to stabilize the wing. Just a heads up
Old Dec 11, 2011, 09:36 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, I've noticed that if I plug any servos (even analog) into the three channels that
normally drive ESCs on the KK board that they buzz something fierce as though
they're being refreshed much faster.
I would have thought someone would have made a regular fixed wing firmware for
the KK board by now.
ian
Daemon is online now Find More Posts by Daemon
Old Dec 11, 2011, 09:46 PM
MauiNate is offline
Joined Aug 2007
The code is open source, it shouldn't be that hard to change the refresh rate to even 25hz. Probably has something to do with gain as well I'd imagine.
Old Dec 12, 2011, 05:46 AM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
There is a little buzz here with the servos. I will check the frequency later and report back.
Good question!
Thanks Jerry
Old Dec 12, 2011, 06:11 AM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
if gyro set to HH mode servos not stressed much.
I'm flying with HH gyros for more than a year and don't have any problems with servos. Using digital MG servos only and 5v UBEC.
fmkit is online now Find More Posts by fmkit
Old Dec 12, 2011, 09:09 AM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
KK board could work with flying wing..!?
tushev is offline Find More Posts by tushev
Old Dec 12, 2011, 04:53 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
No problem just add a mixer to output KK with V tail/ ailevon mix. or place the kk board gyros 45 degree to sense both pitch and roll mix the ailevon in the radio. The easiest way stab the flying wing / delta wing just use two rate gyros mounted on the 45 degree connected to each servo and mix the ailevon in the radio.
Here's my gyro stabilized striker setup
Stryker F27 Takes on the Daisy Field (4 min 14 sec)
Jerry
Old Dec 13, 2011, 04:59 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Update: added software, links and video tutorial
Old Dec 13, 2011, 06:55 PM
tushev is offline
tushev's Avatar
USA, NY, New York
Joined Nov 2008
Discussion KK control aero mode eyeinsky1 Multirotor Talk 35 Aug 06, 2012 05:04 PM
Discussion KK Control Board Connection With AR6200? rtbchris Multirotor Talk 2 Aug 16, 2011 09:12 PM
Sold G10 quad frame, motors, and kk flight control board! Updated!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 5 Jul 10, 2011 12:36 PM
Discussion KK control board dimensions DavidIvanowich Multirotor Talk 2 Jul 09, 2011 09:10 AM
Wanted STABLE Quad control board (not kk,gaui or fy90q) RChelisrule FPV Equipment (FS/W) 5 Mar 28, 2011 04:41 PM
