Old Dec 10, 2011, 05:24 PM
stevolution is offline
Find More Posts by stevolution
stevolution's Avatar
United States, OH, Avon
Joined Apr 2011
Battery explanation
Can some please try to explain the batteries to me... Sorry im still new with the electric stuff... Like what is it the more maH the more powerful?and then number after that I have no clue ...lol example 1000maH 3S 25~50C please break this down for me ... Thnx guys
stevolution is offline Find More Posts by stevolution
Old Dec 10, 2011, 07:44 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
The 3S means 3 cells wired in series.
Series raises the voltage.
1000mAh = 1.0AMP = capacity
25C means this this battery can continuously deliver 25 times it's capacity
Which is 25 x 1 = 25AMPS
Not for very long but it can.
The 50C is a burst amount that can only be supplied for a short time burst.(seconds)
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 11, 2011, 02:37 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Just to add to TheWoodCrafter's explanation, each LiPo cell is nominally 3.7v, so quite often you'll see a "3S" battery described as "11.1v".
Also, LiPo batteries can go up to 4.2v per cell when fully charged, so sometimes you'll see a 3S LiPo referred to as 12.6v when calculating power.
abenn is online now Find More Posts by abenn
Old Dec 11, 2011, 03:45 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Just to get the units right
1000mAh = 1Amp.hour (Ah) capacity i.e. it will deliver 1A for an hour or 10A for 6 minutes (1/10 hour) etc.
In simple terms higher voltage, e.g. higher "S", means more power at the motor.
Higher capacity (mAh) means longer flights.
Higher C-rating means it is possible to drag more power out but at the expense of less flight time. E.g. a 20C battery used to its full current capabilities runs the motor for 60/20 = 3 minutes, a 30C battery at full current runs for only 60/30 = 2 minutes.
Steve
slipstick is offline Find More Posts by slipstick
Old Dec 11, 2011, 07:25 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Minor correction: 1000mah = 1.0Ah = capacity
mah = milliamp hour = capacity in milliamps
Ah = Amp hour = capacity in Amps
ma = milliamp = instantaneous current flow in milliamps
Amp = instantaneous current in Amps
mah, or Ah specifies the amount of current the battery can supply over one hour. So a 1000mah battery can supply 1000ma for one hour.
However the current provided by a battery is dependent on the load it sees, which in the case of an airplane is the combination of the motor and propeller. If you increase the load, i.e. increase propeller size, the current (ma) will increase.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Dec 11, 2011, 09:09 PM
Joined Apr 2011
Steve
Thnx this was exactly what i was looking for, for now..All the other helps as well but i need to do a lil more research before i can fully grasp it all the way..
Suggestion Regarding J Bourkes explanation of prohibited language NoFlyZone Site Suggestions / Complaints 2 Nov 04, 2011 11:00 PM
Question Battery voltage explanation?? T-CAT Batteries and Chargers 17 Jul 21, 2010 08:20 AM
Discussion battery explanation? carrmann Electric Power Cars 10 Mar 22, 2010 08:39 PM
Battery terminology and basics explanation? kuyars Batteries and Chargers 2 Sep 29, 2003 04:45 PM
