Old Dec 12, 2011, 12:43 PM
Don't ask me anything...
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Originally Posted by areid View Post
I've used a cheepo turnigy switch mode bec from HK in a mid range dlg with zero issues, but am hesitant to trust it (or their higher amp version) in anything larger/more expensive.
I have had such good reliability with the Turnigy / Hobbywing "8a, Max 15A" switching type unit (from HK or similar), that I now use it with 2 cell LiPo's in all my expensive gliders such as Pace F4, 4m mouldies, etc. The unit allows you to select 5v or 6v output. The switch is an "open circuit to ON" (i.e. if it gets disconnected, the unit defaults to "on". There are voltage warning lights. The power output is a y-lead with 2 servo type connectors, and a ferrite ring. I love it.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Dec 12, 2011, 03:06 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
This one?
http://www.hobbyking.com/UNITEDHOBBI...idProduct=6233
And this one looks to be the same unit branded differently:
http://www.hobbypartz.com/ubube.html
The features look good, but the dimensions seem like it may not fit into an F3B or F3F plane....Might be the hot tip for a slightly bugger fuse, or in a scale sailplane.
R,
Target
target is offline Find More Posts by target
Old Dec 12, 2011, 05:16 PM
R.M. Gellart's Avatar
Joined Nov 2005
[QUOTE=areid;20111634]Interesting thread. I also like using LiFe's and get a bit nervous running without a regulator (despite in theory the peak voltage is less than a 5 cell NiMH)."
Intersting comment Areid, cause when I have commented about this I can guarentee you that the off the charger voltage is signaficantly less that 5 cell NiMh (Cd). I use a balancer every charge just to see the voltages on each cell just so I know that all is well in the pack. I am coming off the charger at ~6.7V +/-.05V. If I remember correctly (it has been that long since I have used NiMh's), I routinely saw NiMh packs fresh off the charger at atleast 7.0V and sometimes up to 7.2V. I must admit that I have never ever worried about LiFe's sans a regulator or BEC using JR servos, both regular or HV. I have learned the lesson that devices that are controlling voltage are just another site of failure in the system.
Now, with reference to the MKS servos, that is another issue and I guess I realize that they sound nice but how do you bring a servo, in this day and time, to the market that does not handle voltages in the 6.0-7.0V range. The first time I heard about this, I kind of thought the heresay was not possible, well, the guy the Mark Miller was talking about I also know and he nearly lost a ship over it. I guess that is another story, sorry for the opinion.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Dec 12, 2011, 05:54 PM
SoaringDude's Avatar
near Sacramento, CA
Joined Aug 2010
Originally Posted by OVSS Boss View Post
... I am coming off the charger at ~6.7V +/-.05V.
Marc
Hi Mark, wondering what charger you are using? Most I am familiar with will charge LiFe 2S packs to well over 7v right off the charger (while it's true under load they soon drop to ~6.8). Maybe your balancer puts a significant load on the cells after the charge cycle is done?
Chris B.
SoaringDude is offline Find More Posts by SoaringDude
Old Dec 12, 2011, 07:08 PM
Joined Nov 2005
I am using the Thunder Power 1010 with the external balancer. I am guessing if your voltage is different it has to do with the programming, but I am not sure. The voltage I am seeing has nearly no deviation from that value.
Marc
Old Dec 12, 2011, 08:55 PM
Sink Stinks
Silent-AV8R's Avatar
Orange County, CA
Joined Aug 2004
Here's an interesting story. Kyle Dahl, who is one of the current heli hot shots, has a fleet of 3 identical Logos. All have a BEC that gives either 7.4 or 5.2 volts. Turns out 1 of his 3 primary helis had the BEC inadvertently set to 5.2 instead of the 7.4 of the others.
Over the course of flying all three helis in a short period it was not until after he was done flying that the setting error was discovered. In other words, he could not tell the difference between 7.4 volts and 5.2 volts when it came to the performance of his helis.
Kind of makes you go Hmmmmm..................
I use the LiFePO4 packs because I love how they perform, not so much because of the absolute voltage. Nice steady voltage over the useful charge. I am not going to put in my planes any servo that cannot handle the packs I want to use without a regulator.
Silent-AV8R is offline Find More Posts by Silent-AV8R
Old Dec 12, 2011, 11:22 PM
near Sacramento, CA
Joined Aug 2010
Originally Posted by Silent-AV8R View Post
... I am not going to put in my planes any servo that cannot handle the packs I want to use without a regulator.
Then either you're choosing from a small subset of the best performing servos out there OR you feel safe with exceeding manufacturers spec voltage limits. I'd rather not use a regulator or voltage reducer either but... careful selection of the best one for the job can greatly reduce the risks of using one. I'm pretty confident this thread will help with that!
Chris B.
Old Dec 12, 2011, 11:24 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
And now ask him which servos are IN the sailplanes he flies!?
R,
Target
Latest blog entry: Stork 4 Pro X-tail from...
Old Dec 12, 2011, 11:37 PM
Sink Stinks
Orange County, CA
Joined Aug 2004
Both are true. So it is more correct to say that I am choosing from a small subset of the best performing servos out there AND I feel safe with exceeding manufacturers spec voltage limits.
I use Futaba S3150 and S3155 servos on unregulated 2S LiFePO4.
Old Dec 12, 2011, 11:55 PM
LSF V aspirant
tewatson's Avatar
Orange, CA
Joined Oct 2006
Bill,
You outlaw!
Tom
tewatson is offline Find More Posts by tewatson
Old Dec 13, 2011, 12:02 AM
near Sacramento, CA
Joined Aug 2010
This forum really is much better than TV.
Old Dec 13, 2011, 01:34 AM
Sink Stinks
Orange County, CA
Joined Aug 2004
Originally Posted by tewatson View Post
Bill,
You outlaw!
Tom
Yep, livin' life on the edge.
Old Dec 13, 2011, 04:46 AM
'da Range
Joined Nov 2003
Chris B.
My iCharger has a 'storage' mode charge option. I use this immediately after doing a full ballanced charge and it brings the 2S pack voltage down to the recommended storage charge of 6.6 volts. In observing its discharge amounts, there appears to be only 40 mah removed to get it down to this voltage, I thus fly with it that way and so I don't need to ever worry about those peak spikes created during the charge and certainly don't miss the 40 mah for flight.
JrcSeller is offline Find More Posts by JrcSeller
Old Dec 13, 2011, 06:49 AM
Joined Dec 2005
Originally Posted by target View Post
This one?
R,
Target
Yup, those are them! I have managed to stuff one into a Pace F4 which has a very small fuzz, so it can be done...
Old Dec 13, 2011, 07:02 AM
Joined Nov 2005
Chris B.
Chris, I was through the Horizon Hobbies office last week and saw the most amazing thing, LiFe's everywhere. Peter Goldsmith, Team JR Leader and John Diniz, JR Line Manager, have LiFe's in their ships and Horizon will have a line of them for sale soon. No regulators, nothing extra in sailplanes but the batteries and normal parafanial. At least at JR, servos are tested to higher voltages. And those of us that fly them in 2S LiFe set ups have no problems.
I realize that there are folks that put more time on their ships than I do in a year, but I fly comps all the time, my set ups have to hold up and be reliable. Just like Bill M., the attributes these batteries bring to the table are just just too good to pass up, sans any regulators*.
Marc
*Do remember Chris, I lost a ship because of a CC Reg that failed in flight, and as was pointed out to me, everything works great till it fails...
Sold NIP Align 6A External BEC RCE-B6X w/ 5.1V Voltage Regulator K10382A ohsnap Aircraft - Electric - Power Systems (FS/W) 0 Oct 06, 2011 12:59 AM
Question Using a BEC as a voltage regulator? Eyefly Power Systems 8 May 09, 2009 11:09 AM
BEC == Voltage Regulator? TMP00283 Electric Heli Talk 25 Nov 23, 2008 04:26 AM
Sold New Align BEC/Regulator w/Voltage Display $8 xwingnut Aircraft - Electric - Power Systems (FS/W) 2 Feb 01, 2008 01:08 PM
Voltage regulator as BEC? Tuomas Pietinen High Performance 1 Mar 10, 2002 06:32 AM
