I'm still waiting for someone to come forth with the voltage of a fresh 5 cell 2/3A Elite pack....
I think that is someone bothers to measure, they will discover that the 6.6v of a 2S life is not the issue that they think it is for the majority of the servos out there. R< TARGET |
Latest blog entry: Stork 4 Pro X-tail from...
Not really.
If I ever get down to 6.4v on the data logger (which can be replaced with a loaded voltmeter) I recharge. Essentially, all the same rules apply, check your average consumption of battery power, figure out what your time limit is to fly (with safety margin), and there you go. R, Target |
http://www.rcgroups.com/forums/showp...&postcount=255 Here's one where a brand new Perfect went in and some were speculating that my Life cells were to blame.... over 4yrs ago... http://www.rcgroups.com/forums/showp...&postcount=212 |
When you use LiFe packs you get in the habit of watching how many mAH you put back in after a day's flying. If you find a charge cycle requires either way more or way less than what you expect, that's a sign to do a full discharge/charge cycle to verify the pack's capacity. In the 2+ years I've been using Hyperion 1450mAh LiFe packs in my planes I have never had one go bad or even test funny. Never. The only downside to using LiFe is that servo manufacturers are still playing a bit of catchup to offer products that are spec'ed to handle LiFe voltages. Chris B. |
Chris, I am flying HV servos on LiFe's with very good results, would not even considering going back the other way or going to LiPo, just so easy to work with these cells. And even though Ed brings up what happens when they are run down to nothing, why is that a problem? I fly half the day, and top off which can be done fast and easy and you are ready to go. In any contest, I have never had to put in more than 500mah and as Chris pointed out, not so much as a single funcky charge or voltage numbers that made me wonder if something was up in the charge. Just such great cells to deal with all the way around.
Marc |
Its just funny to me that people are using a 5 cell Nixx pack to avoid low voltage Rx glitches, and no regulator, but if they think about using a LiFe pack, they immediately want to use a regulator (even though a fresh 5 cell pack is higher voltage initially).
I will say this: If you have a binding problem with one of the servos in your plane for any reason, the servo likely will not survive with a Life pack, but may with a NiXx pack, solely due to the voltage droop under load that the round cells experience normally. That in itself is a good thing, but if the RX browns out because of it, then its not. I'd rather have control of 5 out of 6 servos, then 0 out of 6 servos.... R, Target |
| Thread Tools | |
| Sold NIP Align 6A External BEC RCE-B6X w/ 5.1V Voltage Regulator K10382A | ohsnap | Aircraft - Electric - Power Systems (FS/W) | 0 | Oct 06, 2011 12:59 AM |
| Question Using a BEC as a voltage regulator? | Eyefly | Power Systems | 8 | May 09, 2009 11:09 AM |
| BEC == Voltage Regulator? | TMP00283 | Electric Heli Talk | 25 | Nov 23, 2008 04:26 AM |
| Sold New Align BEC/Regulator w/Voltage Display $8 | xwingnut | Aircraft - Electric - Power Systems (FS/W) | 2 | Feb 01, 2008 01:08 PM |
| Voltage regulator as BEC? | Tuomas Pietinen | High Performance | 1 | Mar 10, 2002 06:32 AM |
