You know far more about EE than I Paul, but I tend to think that people grossly oversize their wiring. 28AWG with the cheapest crap insulation will carry 3A continuous all day long in the hottest Death Valley sun. That's a lot of power, certainly more than an Eneloop pack can produce, which is so popular in F3X models. So while people may think that each of their 6 servos can draw 1.5A, really most modern digitals like MKS6125 and ATX761 pull well under 1A when nearly stalled and if you leave them like that for long enough to melt a wire, chances are the servo will melt as well. So, no, we don't have all 6 servos drawing 0.7A in a F3J launch and even if we did, the wiring would take many minutes to heat.
All that said, I wouldn't use 28AWG for a battery lead either, but only because it is less durable than 22/24 and the weight is never a concern here. For wings though, 30AWG is overkill even for long runs out to ailerons, but it's too small to crimp well at the RX end and the wing plugs need to be mounted PnP style to avoid handling the fragile wire so often 28AWG is a compromise. |
Depends on what you're willing to accept for/as a voltage drop.
The trouble isn't handling the nominal current (1A) or power dissipation as you say, 28~30AWG is just fine with that, about 0.07~0.16V drop across a half-foot pairing at 1A; it's dealing with the surges. With digital servos you'll see 5~10A surges on unloaded servo transients, and even worse under load. If you have a 10A surge, that suddenly turns into a 0.7~1.6V drop as opposed to a ~0.25V drop with 24AWG. If there was only one pair of wires I'd strongly recommend 'overdoing', it's the batter/regulator -> RX ones, purely to minimise voltage sags, you can go thin on the servos lines since you obviously won't get your RX browning out (in a way, thinner servo lines prevents browning out a bit more because of the extra resistance acting as a current limiter). Paul. |
Latest blog entry: What a change of life. No more R/C.
/Ville (still confused) |
A glued in (both ends) MPX 6 pin connector is "Plug and Play".
R, target |
Latest blog entry: Stork 4 Pro X-tail from...
Any connector you want, DB9, MPX, Deans, Futaba, etc. just glued/screwed to both parts such that you never see or touch any wires. One or both ends of course must be soft mounted (5200, Goop, silicone, etc) to avoid stressing the connector with airframe flex or misalignment.
For example most people setup 3 piece wings with connectors hard-glued to the center panel and loose pigtails on the tips that they yank, scrape, mash and mangle every time they transport or assemble the plane. It's no big deal if the wire breaks and you lose an aileron, but it sure is a problem if the power wires short together because it will kill the whole system. |
/Ville |
Now I follow. /Ville
USA, FL, Milton
Joined Jul 2008
[QUOTE=vespa;21549342]Liftchaser, if your plug has been corroded, pitted, stretched open, or the wiring has been partially broken the result will be a little bit of heat and a large voltage drop. I really think there would need to be a short somewhere for the plug to melt like that. Could the regulator itself have shorted against the fuselage or battery?
Hi Vespa, I think you're onto something there. I recently switched suppliers for the pins and sockets I use to make end connections and I suspect there's something fundamentally wrong with the new items. I think I mentioned I had switched the new Shadow back to a 4 cell pack and JR switch. In the process I shortened the main power lead to the switch and crimped on a new connector. Didn't change the battery side. Hooked everything up and ran the airplane for probably 10 -15 min. to check it out. Everything worked OK so I thought I'd put the airplane on charge to bring the pack back up to full charge. The charger indicated an open circuit and when I tried to switch the power back on I had nothing. I pulled everything back out of the fuselage and started checking from the battery outward. I powered the RX with a separate battery and digital VOM in the circuit to check current draw. Nothing out of the ordinary there, max current draw was no more than 350 ma with all the servos and RX running to their extremes. The battery, including the connector, looked perfectly normal. The switch harness looked normal at first but as I examined each connector I could see the same melting beginning in the power connector I had shortened. I need to do some more digging, but I believe there is something in the base material or plating of the pins, or damage in the crimping process, that is setting up a high resistance path for the current across the connector. That, in turn, is generating lots of heat and melting the plastic, probably eventually burning through the wire. In both cases so far the damage has been at the first connector downstream of the battery, the point where current and voltage is highest. Switching to a soldered 3 pin Deans or similar connector at that point may be a better solution than any crimped connection. Needless to say, I'm going back to my original supplier for pins and sockets. Saving a buck vs saving an airplane is false economy at its worst. lc |
I use the connectors and pins from Hansen Hobbies. Do they have a good track record with everyone?
| Thread Tools | |
| Sold NIP Align 6A External BEC RCE-B6X w/ 5.1V Voltage Regulator K10382A | ohsnap | Aircraft - Electric - Power Systems (FS/W) | 0 | Oct 06, 2011 12:59 AM |
| Question Using a BEC as a voltage regulator? | Eyefly | Power Systems | 8 | May 09, 2009 11:09 AM |
| BEC == Voltage Regulator? | TMP00283 | Electric Heli Talk | 25 | Nov 23, 2008 04:26 AM |
| Sold New Align BEC/Regulator w/Voltage Display $8 | xwingnut | Aircraft - Electric - Power Systems (FS/W) | 2 | Feb 01, 2008 01:08 PM |
| Voltage regulator as BEC? | Tuomas Pietinen | High Performance | 1 | Mar 10, 2002 06:32 AM |
