Old Jan 14, 2012, 03:20 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
RC Goat,
can you fly around and give us an average of your flight times with atmost 10oz of dead weight using 5500mah Lipo.
thanks much. Is 25min reasonable?
LexusFPV is offline Find More Posts by LexusFPV
Old Jan 14, 2012, 07:36 PM
rc_goat is offline
Find More Posts by rc_goat
Orange Co, CA
Joined Dec 2010
Sorry do not have that any 3 cell lipos larger than 3200. Also not really interested in duration flying 6 op 8 Minuets at a time are all I need. Do not use my quad for FPV or long range flying.
rc_goat is offline Find More Posts by rc_goat
Old Jan 15, 2012, 05:49 PM
wowhobbies is offline
Find More Posts by wowhobbies
Joined Jan 2009
Turbo Ace X830-S Las Vegas Strip from the sky
Turbo Ace X830-S Las Vegas Strip from the sky. Vibration free footage from dynamically balanced motors out of the box. Use purple cross on screen for stability reference.
Turbo Ace X830-S Quadrocopter - Step up your aerial video from Gaui 330X-S quad (1 min 34 sec)
Jonathan
www.WowHobbies.com
wowhobbies is offline Find More Posts by wowhobbies
Old Jan 22, 2012, 12:44 AM
cyberbronco is offline
Find More Posts by cyberbronco
United States, FL, Fort Myers
Joined Dec 2010
Vegas video
Beautiful video! What camera was used?
cyberbronco is offline Find More Posts by cyberbronco
Old Jan 27, 2012, 01:49 AM
Joined Jan 2009
Panasonic Lumix DMC-FH25K
I like the Sony DSC-TX7 better because it outputs in .mp4 instead of .mov so I don't have to go through file conversion and lose details. Also it has better auto exposure in vidoe than the Panasonic Lumix and the GoPro 2. GoPro 2 however has wider view which is important in aerial video. There will be a WiFi module available in 2 weeks that plugs in the back of the GoPro which will be great for remote control and viewing from an I-pad, soon to be tested on the X830-S. I don't expect much range from Wifi but it will be great even at 30 to 50 feet which allows me to see what I am filming from my phone. I almost bought the LCD module which would have been a bummer because I would have to remove it when I put on the Wifi since there is only one expansion port. I do belief RC Goat is correct on the GoPro stability since it is designed for extreme sports.
Guys, one customer showed a new way to mount the GoPro on the X4 camera mount by utilizing its image inversion function and mount the camera upside down. I will soon post a picture.
Jonathan
www.WowHobbies.com
Old Jan 27, 2012, 01:52 AM
Joined Jan 2009
Originally Posted by LexusFPV View Post
RC Goat,
Yes, 25 minutes and I did this 2 times and each time return with about 15%-20% left in the tank.
Jonathan
www.WowHobbies.com
Old Jan 27, 2012, 09:11 AM
LexusFPV is offline
Joined Feb 2011
Jonathan....
please post on Vimeo flight (25min+) on 3s-5500mah? (2x Parallel 3s-5500mah=total 11000mah)
Old Jan 27, 2012, 07:41 PM
Wes Eubank is offline
Find More Posts by Wes Eubank
Joined Jan 2012
X830 struts
Recent photos show a strut from the motor mount to the landing leg. My 830-S did not come with these supports. Is this something I need to add?
Wes Eubank is offline Find More Posts by Wes Eubank
Old Jan 27, 2012, 09:39 PM
Joined Jan 2009
The struts are for large DSLR camera like the Canon T3i. They are not necessary for smaller cameras. We will also be showing an alternative way to mount the GoPro on the Turbo Ace X4 camera mount. The flexible design of the X830-S landing skids allows you to mount most cameras easily on the X830-S. Just replace the stock legs with longer carbon rods to extend the skid if you have taller or bigger camera. If you buy a quad that has nice looking fancy legs then likely it will not be extendable and you are stucked.
Jonathan
www.WowHobbies.com
Old Jan 27, 2012, 09:42 PM
Joined Jan 2009
Jonathan....
That is a long long video to make. If you do the math using a 2200mAh battery, it won't be necessary.
Jonathan
www.WowHobbies.com
Old Jan 27, 2012, 09:45 PM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
The purple cross looks like the Mercalli plugin cross and you have a dust spec on the sensor that moves around which indicates you have used stabilization software, probably mercalli.
Stacky is offline Find More Posts by Stacky
Old Jan 28, 2012, 09:50 AM
LexusFPV is offline
Joined Feb 2011
Is there a return to policy if I don't get the exact runtimes that you advertise?
I will buy the Batteries from your company so everything is monitored.....
thanks much. Great videos.
Old Feb 09, 2012, 08:55 AM
thefokker is offline
Find More Posts by thefokker
Team White Llama
thefokker's Avatar
USA, IL, Mundelein
Joined Mar 2005
I work at a hobbystore part time fixing heli's mostly, and a customer brought in 1 of these 830s quads he bought from wowhobbies. He does not have the 4gb flash drive with config software, and manual. Can you please post where I can download this info to get his quad flying.
I like the cam vibration attenuation rubber. Looks like a decent quad, but its a paperweight until I can find the manual.
thefokker is offline Find More Posts by thefokker
Old Feb 10, 2012, 09:01 AM
Team White Llama
thefokker's Avatar
USA, IL, Mundelein
Joined Mar 2005
Still Waiting!!!
Old Feb 11, 2012, 08:22 PM
Team White Llama
thefokker's Avatar
USA, IL, Mundelein
Joined Mar 2005
Uh...Still waiting!!! Ive sent emails, pm's, wow hobbies has no customer service apparently.
Discussion Turbo Ace X720 Quad... GGoodrum Multirotor Talk 1083 Apr 01, 2013 09:36 PM
Help! M120d01 ESC burning hot with Turbo Ace 26 Horenus Micro Helis 16 Feb 02, 2012 11:22 AM
Sold CNC Upgraded MCPX and Turbo Ace Dual Case cgsoldier Aircraft - Electric - Helis (FS/W) 4 Oct 09, 2011 07:49 PM
Sold Turbo Ace X720 QuadCopter - Bind N Fly smokeytbear Aircraft - Electric - Multirotor (FS/W) 3 Sep 30, 2011 10:01 PM
Question Can I use this Turbo Ace motor? JeremyT Electric Heli Talk 3 Sep 19, 2011 06:32 PM
