Old Dec 09, 2011, 08:18 PM
toxic-trip is offline
Find More Posts by toxic-trip
toxic-trip's Avatar
United States, AZ, Scottsdale
Joined Mar 2007
Het f-20
I am about to lose my mind, what is the C of G for the HET F-20. I cannot find it anywhere? I really want to maiden it Sunday morning but need some finalizations done first.
toxic-trip is offline Find More Posts by toxic-trip
Old Dec 09, 2011, 09:06 PM
Robert Wagoner is offline
Find More Posts by Robert Wagoner
Robert Wagoner's Avatar
Tucson, Arizona, USA
Joined Dec 1999
Here is a picture from the HET doc Carl Tulanko put together.
C.G. is 2.55" / 65mm from the leading edge of the wing root.
--RW
Robert Wagoner is offline Find More Posts by Robert Wagoner
Site Sponsor
Old Dec 09, 2011, 09:19 PM
toxic-trip's Avatar
Joined Mar 2007
Thank you, do you know if that is from leading edge of wing or leading edge of triangle piece in front of wing?
I am almost done after two years of doing this project (I had lots of other projects come up)!!!
Old Dec 09, 2011, 09:23 PM
ex-racr is offline
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
From the LE of the actual wing where it meets the fuselage; not the extension. FWIW I had the CG at 67mm from the LE of the wing and found it very nose heavy. I moved it back to 80mm from the LE with no ill effects.
Unfortunately, my plane had a few mishaps, so I've put it aside for now.
Terry
ex-racr is offline Find More Posts by ex-racr
Old Dec 09, 2011, 11:02 PM
Joined Dec 1999
Yes, as Terry mentioned. Nice looking F-20.
--RW
Site Sponsor
Old Dec 10, 2011, 07:04 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Well I am the new owner of the Air Power version of this plane. Have out 5 flights on it so far but the setup it came with just doesn't put out like I expected so I am doing some power plant swap outs to try a few things. Will get some video once she is all dailed in.
Jason
P.S. My Air Power F-20 has the LE root extensions and my c/g is 115mm from the LE of the extension where it meets the fuse. Fly's great there. Not sure if that is in the ball park of the c/g's mentioned or not.
FresnoJay is offline Find More Posts by FresnoJay
Old Dec 11, 2011, 02:35 PM
toxic-trip's Avatar
Joined Mar 2007
Maidened it today, almost planted it straight in to the ground, the CG of ~75mm from leading edge was nearly fatal (I was holding full up elevator entire circuit until I re-landed).
I then moved CG back to 85mm and HOLY $H!T it is FAST and stable!!! I never even hit past 3/4 throttle because I was too scared it would rip apart mid-air it was going so fast (it would compete with my 400 size pylon racer at these speeds)!
I love the HET 2w-25 6s 2200mah 30c w/ wemo pro fan!!!
Old Dec 11, 2011, 03:42 PM
ex-racr is offline
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
Glad it worked out for you.
Old Dec 12, 2011, 08:00 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Leading edge root extensions (LERX)
This has nothing to do with the CG but thought y'all might like the info
LERX are small fillets, typically roughly triangular in shape, running forward from the leading edge of the wing root to a point along the fuselage.
On a modern fighter aircraft they provide usable airflow over the wing at high angles of attack, so delaying the stall and consequent loss of lift. In cruising flight the effect of the LERX is minimal. However at high angles of attack, as often encountered in a dog fight, the LERX generates a high-speed vortex that attaches to the top of the wing. The vortex action maintains a smooth airflow over the wing surface well past the normal stall point at which the airflow would otherwise break up, thus sustaining lift at very high angles.
Su-27UB with LERXLERX were first used on the Northrop F-5 "Freedom fighter" which flew in 1959,[1] and have since become commonplace on many combat aircraft. The F/A-18 Hornet has especially large examples, as does the Sukhoi Su-27. The Su-27 LERX help to make some advanced maneuvers possible, such as the Pugachev's Cobra, the Cobra Turn and the Kulbit.
ApexAero is offline Find More Posts by ApexAero
Old Dec 12, 2011, 11:18 AM
toxic-trip's Avatar
Joined Mar 2007
That is really interesting, I had no idea they help with high alpha flight. It looks like on the new China J-10 (I think thats the number), the LERX can move about 30 degrees up and down, does this further help the performance of the aircraft?
Old Jan 06, 2012, 03:54 PM
rupert the bear is offline
Find More Posts by rupert the bear
Joined Jun 2007
Laziness dictated that i left the little triangle wing extensions off mine it still flies great in fact it flies surprisingly well, very stable and once you get used to it relatively easy to land.
It uses the HET motor and fan with a zippy 4 cell 5000mha battery, some people are using a lighter battery but it easily carries the weight of the 5000 mha and i get good flight times
This is my second one , the first was lost in a mid air with my mates HET Mig.
rupert the bear is offline Find More Posts by rupert the bear
Old Jan 06, 2012, 06:06 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the lex and nose on the full scale F-20 are two of the things that made this a great plane ..the motor was awsome too! the lex should influnce the C/G a bit as the c/g is pretty far forward on most f-20 models
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jan 07, 2012, 04:47 AM
Si Goodchild is offline
Find More Posts by Si Goodchild
Si Goodchild's Avatar
Lincolnshire, UK
Joined Oct 2009
Maidened it today...
...I love the HET 2w-25 6s 2200mah 30c w/ wemo pro fan!!!
You are so right! I have the WeMo running the HET 2w-25 on 6s 3000mah 40C packs in my HET F16. Man that thing shifts! It's always a bit butt-clenching flying it because with that much power the fan can generate torque-roll which is not something I'm used to in EDFs. I cat-launch and bell-land on a tiny and rough grass strip so tailerons get replaced frequently. Using retracts on a tarmac surface sounds like real luxury: I'm envious!
You my find that with a bigger pack the motor will generate even more thrust as the voltage will sag less under load: you'll soon become used to the speed.
Si
Si Goodchild is offline Find More Posts by Si Goodchild
Old Jan 07, 2012, 04:48 AM
Lincolnshire, UK
Joined Oct 2009
Rupert - that's a damned pretty jet - pity the tailplane and elevator wouldn't last one landing at my field!
Old Jan 07, 2012, 05:07 AM
Joined Jun 2007
Thanks, the tailplane seems quite strong (we have a grass strip with a few bumps and undulations)
If you judge the landing right the F20 seems to slow done well at a surprisingly high angle of attack until you are ready to lower the nose and let it settle onto the grass.
I have not had much experience with ducted fans but one of the appeals with these HET jets is that they sound fantastic, unlike some of the other ducted fans i have heard
Help! HET F-20 Tigershark build help hudsonaj36 Electric Ducted Fan Jet Talk 48 Oct 03, 2012 10:43 AM
Sold NIB HET F-20 Tigershark DaveBC Aircraft - Electric - Jets (FS/W) 25 Aug 03, 2011 02:42 PM
For Sale Phase 3 F-16 with HET 6904/2W-20 Motor lotech Aircraft - Electric - Jets (FS/W) 25 Jul 04, 2011 12:28 PM
Found HET F-20 or HET F104 if you have both kids NIB I want them sherlockshah Aircraft - Electric - Jets (FS/W) 1 Mar 12, 2011 12:01 AM
For Sale HET F-20 with servos / LPU DEAL - Central Ohio kevin Aircraft - Electric - Jets (FS/W) 0 Mar 03, 2011 12:49 PM
