Old Dec 09, 2011, 03:20 PM
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
"Crash-proof 3D foam RC plane" by hammydude12345
OK, it's not a build I've done yet, but I found this on YouTube. As is my habit whenever I run across an interesting plane I make AutoCAD drawings if none are available. I know no plane is fully crash-proof, but I loved the simplicity of this one, and I think it is probably quite a bit more crash tolerant than many others out there. It incorporates some good ideas. I will be building one some time soon, for sure. It's so straightforward it should be a quick build and looks like it flies well.
The build: http://www.youtube.com/v/wC6-ljrSpgA...yer_detailpage
Flight vid:
Crash-proof 3D foam RC plane flight (1 min 19 sec)
Hammydude12345 hasn't found his way to RC Groups yet, but I've encouraged him to do so. He confirmed that the drawings are accurate and asked me to post them. I hope you don't mind this indirect method, but I thought you might like to see this plane.
potshot is online now Find More Posts by potshot
Old Dec 12, 2011, 03:31 PM
F3Pflyer's Avatar
Joined Dec 2011
All EPP I imagine? What motor Abd speed control?
F3Pflyer is offline Find More Posts by F3Pflyer
Old Dec 12, 2011, 05:24 PM
potshot's Avatar
Joined Mar 2009
The specs are in the last 10 seconds of the build video. He says he used 3mm foam from BP Hobbies, but they only show 5mm on their website. The motor is a BM2408-12 with a 10x4.7 prop, with a 20A ESC and 1300 mAh battery (I'm guesing 3 cell).
I can't see why fanfold or Depron wouldn't work just as well. Built light, I'd imagine a Blue Wonder would be all right, too. That's the setup I'll use when I build mine.
Old Dec 25, 2011, 04:15 PM
NL
Joined Nov 2009
I built it from 5mm Depron.
You guys manage to find materials that I can't get hold of... :-(
Anyway, I have a "too big" motor on there. I first had a smaller motor but it wouldn't run properly. Apparently I broke a ball in the ball bearing on the maiden of another project. :-(
Now I Have a 5" prop on this motor (C2409 from HK), which people claim should be run with 9" - 11" props. Will I be able to fly like this or do I have to make a larger prop fit? The plane+battery weighs 288g all up right now.
The advantage of the 5" prop is that it doesn't reach the ground, so I don't have to make a landing gear.... :-)
rewolff is offline Find More Posts by rewolff
Old Dec 25, 2011, 04:27 PM
potshot's Avatar
Joined Mar 2009
A Hobby King search for "C2409" came up empty. The only 2409 motors I could find there are the bell types, which all call for 8 or 9 inch props. They are lower KV motors, so I don't think you'd get much out of them with a 5 incher.
Don't forget to post some pictures of your build, rewolff
Old Jul 12, 2012, 04:08 PM
potshot's Avatar
Joined Mar 2009
He's baaaaack
I finally got back to building one of these, and I've made some changes. I'm calling it Hammy26.
I cut the parts out of Hobby Lobby foamboard because I wanted to leave the paper on and want it to stay on. I scaled it down to a 26" wingspan so all the parts would more easily fit on a single 20"x30" sheet of foamboard, and that size plane seems ideal for my 1/2 acre flying space. The entire LE is a 3mm CF rod. This plane will be used outdoors so I hope the extra weight will be helpful in the wind.
I had lots of color packing tape so for once I decorated a plane before assembly. I still have to cut off the rudder and separate the fuse halves. The parts shown in the photos weigh 213 grams - porky by my usual standards but hopefully it will penetrate well if properly powered. I know it will not be a floater, and that's fine with me.
I haven't selected the motor yet; I want to see what the airframe weighs after assembly and with three 9g servos.
So far my investment is $2 for the sheet plus several feet of packing tape. I'm planning to use 5 min epoxy to assemble it. I have all the other odds and ends on hand.
Old Jul 16, 2012, 10:44 AM
USA, OH, medina
Joined Sep 2010
Hey Potshot,
Do you have plans for the Hammy 26?
99CRASH99 is offline Find More Posts by 99CRASH99
Old Jul 16, 2012, 11:58 PM
potshot's Avatar
Joined Mar 2009
Here ya go, 99. During assembly I made some minor changes to the plans.The plans include those changes, the most important of which is the addition of 1 1/2" in overall length to allow more latitude for battery placement, which I could have used on mine. I also lowered the "canopy" top 1/2" and the top of the rudder about an inch in an attempt to cut some weight aft.
I mounted an Emax CF2822 with an EP8040 prop, 18A ESC, Orange receiver, 3 x 9g servos and a 3S 1300 battery. I'll have some photos of the finished product and a flight report soon.
Old Jul 17, 2012, 01:58 AM
Joined Jul 2012
Very Cool cant wait to build one! ill use depron and a emax 28-22 1534kv motor 15amp esc, 8x4 prop and 850mah 3sp battery. Thanks!
ausrod is offline Find More Posts by ausrod
Old Jul 17, 2012, 08:59 AM
potshot's Avatar
Joined Mar 2009
Great! Yours will be a lot lighter than mine so it will be a good comparison. Yours should be pretty lively with that motor. Don't forget to send pictures and a flight report when you're done, ausrod. Have fun!
Old Jul 18, 2012, 08:22 AM
USA, OH, medina
Joined Sep 2010
Potshot, Thank you for all your work on this it sure makes things easier on the rest of us.
It looks like you might have forgotten the notch in the rudder for the elevator clearance in your Hammy 26 plans.
Old Jul 18, 2012, 11:01 AM
potshot's Avatar
Joined Mar 2009
My pleasure, 99. CAD is one of the fun parts of this hobby.
Actually, if you look at the narrowest part of the elevator, you'll see that it fits entirely within the V-shaped area formed at the aft end of the upper and lower fuse halves. In most other builds you'd see a fan shape instead of the V shape. The whole idea behind this design is straight cuts, so it might be a little misleading.
Old Jul 18, 2012, 08:48 PM
potshot's Avatar
Joined Mar 2009
At last
Well, it's done and ready for maiden. It weighs in at 16 oz. on the button with a 3S 1300, at least twice as much as anything that size I've ever built. I said I wanted weight and I got it. Now I'll find out if it meets my goal.
The topside color scheme comes from a full scale Extra 300L that I got to fly a little bit recently. The Extra also had a purple component which I used on the bottom. I know it's not a candidate for Plane Beautiful, but I'm hoping it will be visible enough to these bad eyes.
Now to set up the TX for throws and rates. Hope to maiden it very soon. And despite hammydude's title, I'm under no illusion that it's crashproof.
Old Jul 19, 2012, 07:17 AM
USA, OH, medina
Joined Sep 2010
Potshot
I see that you put your servos way up front. I made the mistake of putting them right behind the wing. That , as I found out, is a critical stress point because the whole tail section joins there. Putting the servos there weakened that area. On my 3rd attempt at flight it broke in half. (So much for Crash proof). I wish I had waited for your revised drawings because that tail heaviness is pretty bad. From your pictures it looks like your planes have the short nose? If so, did you have to add weight to the front?
Old Jul 19, 2012, 07:24 AM
USA, OH, medina
Joined Sep 2010
Oh BTW mine came in at 11oz. But I'm using a rimfire 250 and a 430ma 2s. I tried it with the tail slightly heavy and it just hovered on the prop.
Question most crash-proof 3d trainer? raythomas Foamies (Kits) 38 Aug 23, 2008 01:26 PM
Discussion Sky Angel RTF Electric 2Ch RC Crash Proof Plane proflying Micro RTF 9 Jun 16, 2008 06:31 PM
New Product Magic Butterfly, 3D-Trainer, Crash proof! AUSTARSMODEL 3D Flying 0 Nov 09, 2007 08:35 AM
Discussion What is the most crash proof 3D plane? Dave K 3D Flying 14 May 21, 2006 09:03 AM
