This thread is privately moderated by aeajr, who may elect to delete unwanted replies.
Old Feb 07, 2004, 01:57 AM
webguyjv is offline
Find More Posts by webguyjv
Int'l Slope Observer
webguyjv's Avatar
Fremont, CA
Joined Oct 2001
Where To Get Replacement Tubing In NorCal
This thread is really great guys -- great work!
I want to start uising a hi-start. I have one that's about 12 year sold - heven't used it in a LONG time. The surgical tubing is brittle and it needs to be completely replaced.
Do you guys know of a place in Northern California that sells the kind of tubing used on hi-starts?
I'm wondering if it's cheaper to replace the tubing, or just buy a new hi-start.
Thanks again for this great thread.
Happy Flying ;-)
Webguyjv
webguyjv is offline Find More Posts by webguyjv
Old Feb 07, 2004, 03:02 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Webguyjv,
Glad you like our little discussion here.
Whether it is better to replace the tubing or the whole thing is up to you. If the line is good, the parachute good, the rings good, the reel good and the spikes good, then all you need is the tubing. on the other hand the difference in price for a complete unit vs just tubing may not be that much.
For example, the Dynaflight HD at Tower is $60. The tubing alone is $50. For $10 you get the spool, ($5) parachute ($12) rings ($3), line ($3) and a spike. - might as well get the whole kit and use the old stuff to make a shorter up-stat for practice.
What kind of plane are you launching and what size and strength was your old hi-start. Were you happy with it.
Maybe we can point you to a good source. The interenet places ship pretty quickly.
My upstart is made with 25 feet of REAL surgical tubing that I bought on e-bay for about $12 I think.
Tell us how we can help you.
aeajr is offline Find More Posts by aeajr
Old Feb 07, 2004, 06:50 AM
fprintf is offline
Find More Posts by fprintf
[intentionally blank]
fprintf's Avatar
Cheshire, CT, USA
Joined Jan 2001
http://www.aerofoam.com/hosemonster.html is the only place to buy histarts, imho.
Buy cheap, buy twice.
In this case it is not that much more expensive to get the really good stuff. $55 plus shipping for 100 feet of the best histart rubber there is. $110 including shipping for a complete 100' histart, including nylon line, a nice parachute, proper connecting rings etc.
Unfortunately Mark in is Washington State, so not local. There are two ways to do it locally. 1) go to your local hobby shop and pick up a histart - usually $60 - $70 complete. 2) Go to your local medical supply shop and purchase surgical tubing. I would bet that in Northern CA with any consistent use (e.g. every weekend) it would only last a year or so due to UV exposure.
I like my Hobby Lobby Hi-start, but next time I am definitely going for an Aerofoam Hosemonster. I have been flying off of one and the rubber is *so* much more stretchy, and feels just as powerful but somehow softer.
fprintf is offline Find More Posts by fprintf
Old Feb 12, 2004, 09:40 PM
gdjsky01 is offline
Find More Posts by gdjsky01
Jeff
USA, CA, Redondo Beach
Joined Aug 2003
Joining Hi-Start peice after a break
Then the inevitable happens. And now you have two fine peices of latex rubber tubing. What's the best way to join them back together? Welded steel rings? Key rings? Just knot them together?
Best wishes.
Jeff
gdjsky01 is offline Find More Posts by gdjsky01
Old Feb 12, 2004, 09:55 PM
fprintf is offline
fprintf's Avatar
Cheshire, CT, USA
Joined Jan 2001
Best way I have found is to find a piece of dowel that is just over the inside dimension of the histart. First put some Household goop on the dowel, then shove the dowel inside each end of the two pieces. Once dry this should be enough to keep the histart together. For extra safety you can wrap dental floss, spectra fishing line or other strong string around the joint.
Old Feb 15, 2004, 07:14 PM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Better wrap it with a rubber band. A #64 rubber band will do OK.
Ricardo.
Ricardo RW is offline Find More Posts by Ricardo RW
Old Feb 15, 2004, 07:25 PM
fprintf is offline
fprintf's Avatar
Cheshire, CT, USA
Joined Jan 2001
Ricardo.
That is what I do at the histart *ends*, but for a break in the middle and without connecting rings there is no way to wrap the elastic band around the joint! That is, unless you cut the elastic band and tie it when you are done wrapping.
Incidentally, if you have a nice histart w/ UV protection in it (Hobby Lobby, Aerofoam) then the potential weak link is the elastic band - it degrades rather quickly in sunlight. I need to replace mine after two years of activity.
Old Feb 15, 2004, 08:42 PM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
To protect the rubberband wrap from UV you can coat over the wrap with black RTV rubber. There are two kinds of liquid RTV rubber, silicone and sulfide. The sulfide RTV rubber used as a boat caulk and between deck boards is best. It is available in marine supply stores.
Ollie is offline Find More Posts by Ollie
Old Feb 16, 2004, 09:14 AM
Ricardo RW's Avatar
Joined Jun 2002
... cut the elastic band and tie it when you are done wrapping.
Yes, I cut the elastic band and tie it firmly on top of the dowel.
But, I prefer to strip bike blades in bands similar about the size of #64 elastic bands. With this straps I don't have to worry about UV.
Regards.
Ricardo
Old Feb 16, 2004, 01:00 PM
gdjsky01 is offline
Jeff
Joined Aug 2003
I don't mean to be dense, it's a gift really , but anyone have a picture of said joint? So to recap:
We take a dowel that has to be shoved firmly into the center of the surgical rubber, goop it, then join the two broken pieces. Break a few #64 rubber bands, and wrap those tightly around the joined pieces? Then liberally coat the tightly wound #64 rubber bands with boat deck RTV (good ol Home Dee Pot RTV is NG)?
How about just using a few larger tie wraps instead of the #64 rubber bands??
Jeff
Old Feb 16, 2004, 02:44 PM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
The reason that nonelastic bands like hose clamps and tiewraps aren't as good is that when the tubing stretches the wall thickness decreases over the dowel and the clamps loose tightness. However, when the tubing OD shrinks under stretch, the rubberbands comply and continue to provide enough clamping pressure.
Old Feb 16, 2004, 04:09 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
If you use dowels that fit tight, get 2-3 inches or more of dowel into each piece of elastic, the goop and rubberbands are just extra insurance. as you apply the tension to the line, the tubing will stretch and tighten around the dowel.
One thing that will help is to cut small rings around the dowel so the tubing as somethign to grab onto. You dont' want to use the type of dowel that is fluted the long way. That will reduce the contact area. Small rings scratched in with a knife will work great. They don't have to be deep, you are just creating some small grab areas. The rubber will squeeze into those rings and grab tight.
Old Feb 16, 2004, 08:20 PM
T. Lyttle is offline
Find More Posts by T. Lyttle
Keremeos BC Canada
Joined Dec 2002
I have 2 breaks in my tubing, and I repair with a simple reef (not granny) knot, using soap & water as a lube (important); once dry, it seems to be fine. My repairs have never failed, am I just lucky?
T. Lyttle is offline Find More Posts by T. Lyttle
Old Feb 16, 2004, 11:20 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Nope, sounds good. If it works, that is the true test.
Old Feb 26, 2004, 10:31 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
What specifications do people recommend for a hi-start for 3 meter planes?
Or what model and brand woudl you recommend?
easy way to use hi start jtraxler Sailplane Talk 16 Dec 12, 2007 10:50 PM
Learning to use AutoCAD 2002 OCModels Power Systems 4 Mar 07, 2002 11:55 AM
Need a source for hi start tubing Jar'sbuddy Electric Sailplanes 3 Feb 01, 2002 12:11 PM
NIB Dynaflite Hi-Start (standard) JCastle Aircraft - Electric - Airplanes (FS/W) 0 Dec 27, 2001 10:15 PM
How can I make a hi-start?...I've got the materials kiwip Electric Sailplanes 6 Jul 02, 2001 10:14 AM
