LI, New York, USA
Joined Mar 2003
Actual hi-start launches:
http://www.youtube.com/watch?feature...&v=JGvhxIICR48 |
Here's another one. 71 oz model launching to about 250' with little to no wind. Old Pinnacle hi start from NSP, not pulled back to it's full extension. It's a pretty heavy duty hi start, so we rarely pull it back as far as it will go.
Evansville, WI
Joined Dec 2006
I just successfully tested my home built Hi-start
It's about 40' of 1/4" silicone tubing and around 100' of 30# fishing line. It's a bit short, but my field is space limited. I'm flying a swap meet find CG Sophisticated Lady, SEEN HERE. The problem I'm having is that the plane is releasing to late. After launch, the plane starts to circle the anchor point and gets dragged down a bit before it releases. What's the usual cause of this, and what's the best solution? Thanks for the help.
Lake Elsinore, California, United States
Joined Aug 2003
Stuff that I learned here. Thanks for all the tips, guys.
Soar! Jun
USA, CA, Redondo Beach
Joined Aug 2003
Nice catch.
Evansville, WI
Joined Dec 2006
I have another question. In order to launch into the wind, my location is ideal. It's slightly uphill to the pin, and the field I thermal above is over the crest of the hill little hill(it's probably only a 30' rise). Too far for me to realistically get the plane with my skill level, not to mention walking to where I can see clearly is I do manage to keep the plane in the air. I can anchor the tubing much more advantagously, but then I will usually be launching with the wind instead of into it. What'll happen if I launch with the wind?
LI, New York, USA
Joined Mar 2003
When a Boeing 777 launches, with all those jet engines - he launches into the wind as much as possible.
When a Piper cub launches, he launches into the wind as much as possible. When an aircraft carrier prepares to launch its catapult boosted, after burner running figthers, they turn the ship into the wind as much as possible. When contest pilots with molded gliders set up their super powerful winches, they set them up to launch into the wind as much as possible. So, when you launch your gliders from your hi-start, you launch into the wind as much as possible. Every other choice is a poor one if you have the opportunity to launch into the wind. That should cover it. |
| Thread Tools | |
| easy way to use hi start | jtraxler | Sailplane Talk | 16 | Dec 12, 2007 10:50 PM |
| Learning to use AutoCAD 2002 | OCModels | Power Systems | 4 | Mar 07, 2002 11:55 AM |
| Need a source for hi start tubing | Jar'sbuddy | Electric Sailplanes | 3 | Feb 01, 2002 12:11 PM |
| NIB Dynaflite Hi-Start (standard) | JCastle | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 27, 2001 10:15 PM |
| How can I make a hi-start?...I've got the materials | kiwip | Electric Sailplanes | 6 | Jul 02, 2001 10:14 AM |
