This thread is privately moderated by aeajr, who may elect to delete unwanted replies.
Old Dec 19, 2009, 10:35 AM
RLW is offline
RLW
Find More Posts by RLW
RLW
Joined Dec 2009
Originally Posted by aeajr View Post
Nice example of a hi-start launch Mickey.
RLW, those look like two many tow launches, not hi-start launches.
Yes but the technique is exactly the same with a high start or tow launch.
The problem with Mickey's technique (a very common one btw) is his arm is bent at the elbow and in front. This makes the weak link of the whole system your arm strength. With my example, once you have your arm locked at the elbow you are using almost zero arm strength to hold tension. Now you can use all your strength to keep your plane in the right position and throw it hard on launch.
The added benefit is your plane does not need to take up precious energy to rotate, as its already launched in the nose up position.
Like I said, there is a reason the pros do it. This technique might seem awkward at first, but once you figure it out you'll never go back. It allows you to safely and easily hold a tremendous amount of tension and launch the plane when YOU want, not when your arm gets tired, or your wings are not level and you can't hold it anymore.
RLW is offline Find More Posts by RLW
Old Dec 19, 2009, 12:33 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I concur with the gentleman above. My form may not be exactly what is descibed above, but it is what I am striving for.
But, change is tough sometimes, use what works for you, and be open minded for improvement, that's what I keep thinking.
R,
Target
target is offline Find More Posts by target
Old Dec 19, 2009, 06:48 PM
mikey100 is offline
Find More Posts by mikey100
Joined Feb 2009
I think that the only reason that I dont put my arm all the way back is that I CAN'T. Will have to use the other arm to help 'load' the throwing arm into the locked position, then grab the radio (from a strap around neck). The 'straight arm method' should not be too bad on a winch as you start with no tension and let it build against your locked arm. Will try and see.
mikey100 is offline Find More Posts by mikey100
Old May 11, 2011, 11:18 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Let's bring this back to the top for the benefit of all the new glider pilots.
aeajr is offline Find More Posts by aeajr
Old Jun 29, 2011, 03:10 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Anyone got a good source for thera band rubber? I hear that works well for hi-starts.
Anyone tried the HobbyKing silicone rubber hi-start tubing?
Old Jun 29, 2011, 04:09 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Ed-
Try barrington supply for the Theraband tubing.
R,
Target
Old Jun 29, 2011, 06:45 AM
hornet_dave is offline
Find More Posts by hornet_dave
hornet_dave's Avatar
USA, IA, Cedar Rapids
Joined May 2003
I got mine off of an ebay seller. No probs, price seemed good.
hornet_dave is offline Find More Posts by hornet_dave
Old Jun 29, 2011, 08:44 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Sources for hi-starts and hi-start rubber
This needs to be updated from time to time.
My favorite, NESailplanes seems to be in trouble. No one seems to be able to get in touch with them, so forget the Pinnacle hi-starts.
OTHER SOURCES
Hobby-Lobby - hi-start rubber or full hi-start packages - well known for quality products
http://search2.hobby-lobby.com/psear...-start&x=0&y=0
Aerofoam - Hosemonster - rubber alone or full packages
reputed to be the best
http://www.aerofoam.com/hosemonster.html
HobbyKing - rubber only. I don't know much about these. 30 foot pieces only so you would have to join them for a larger HS.
http://www.hobbyking.com/hobbyking/s...wer_Search.asp
I found this e-bay listing for theraband
http://cgi.ebay.com/ws/eBayISAPI.dll...m=190544596819
I posted a question to see if the spools are 100 feet continous or if it is pieces. 100 foot of green is $53 including shipping. A guestimate would be that red would be good for 2M, Green for typical 3M, Black for extra strong or larger than 3M. Anyone have actual pull measurements for this stuff?
Tower Hobbies - Low cost - they work but I only recommend these for people on a very very tight budget. Use the HD for 2M or above. Probably Ok to 100" wing span. Standard is for under 2M gliders.
http://www3.towerhobbies.com/cgi-bin...EARCH=hi-start
General guidelines
You can buy latex rubber tubing on e-bay or from other sources, just make sure that whatever length they offer is one piece. You can see offers for 100 feet but it comes as a bunch of 5' sections which would be common use for this stuff. You can join pieces but I would not want more than two joiners on a 100 foot hi-start. There are joiners that can be split so having multiple pieces could be an advantage if you fly on varying length fields.
Assuming you find 30, 50 or 100 foot pieces here are the size breakdowns as I have seen them used. Others may provide different advice. I tend to like my HS a little stronger. You can always pull a little less but if you need more pull and you don't have it you are stuck.
5/16" OD - Standard HS good for about 1.7M up to about 3M or about 65 ounces.
3/8" OD - HS for up to about 3.5M or about 80 ounces. Fine for 2M planes, just don't pull as far.
1/2" OD - Good for up to about 4M or about 100 ounces. May not be good for 2M planes.
Old Jun 29, 2011, 09:13 AM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Theraband tubing is available at many physical therapy websites. Try this one, http://www.ptmart.com/category_s/103.htm , I have not personally ordered from them.
Wayne
Windependence is offline Find More Posts by Windependence
Old Jun 29, 2011, 07:55 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That is a very good price on the Theraband.
I can tell you from experience that the box of 100' tubing is in at least 3 pieces.
So plan on splicing....
R,
Target
Old Jun 30, 2011, 02:34 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
General guidelines
The OD alone doesn't tell you enough. What is fundamentally important is the cross-sectional area of the rubber. That area depends on the OD and the wall thickness. Several summaries of the actual dimensions (OD and wall thickness) of the tubing from many sources have been posted on this forum.
williamson is offline Find More Posts by williamson
Old Jun 30, 2011, 03:41 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I agree, but the typical for this kind of tubing is 1/16" walls. so, your 5/16" OD has an ID or 3/16. the OD of 3/8 is 1/4" and so on.
the list is a general guideline, not a rigerous assessment.
Old Jun 30, 2011, 03:52 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That IS true that most of that sized rubber is about 1/16" wall thickness.
That includes the Theraband, if my memory is correct.
R,
Target
Old Jun 30, 2011, 09:03 PM
Pauliwog is offline
Find More Posts by Pauliwog
United States, OR, Corvallis
Joined Jan 2010
2 more cents........
Another great source of surgical tubing is:
www.reefscuba.com
They have a pretty good variety of sizes of surgical tubing in both natural and black, are a small Ma-n-Pa owned and operated business, are really fast in getting orders shipped out, and they have been very good to deal with over the phone. Their prices were'nt the cheapest but weren't the most expensive either. The material they sell seems to be pretty good material as well and worth the price. You get what you pay for from them.
I'm currently using the natural color material, 1/4" outer diameter, 1/16" wall thickness, 2- 25ft lengths connected with home-made connectors to make a 50 foot long piece of elastic (I think they can sell a continuous 50 foot piece on request, it might be more expensive), attached to 200 feet of line to launch a heavy 38ounce 2m plane. I stretch mine 50 paces, and if I have to launch WITH a slight breeze, it still has plenty of oomph to get that plane up in the air nicely without floundering, granted not as well as if I launched into the wind, but still, well enough. It's had a LOT, LOT of use with no discernable wear yet for the past year(?). I treated mine with Armourall, but Reefscuba also sells a substance specific to their tubing for UV protection.
I will likely order any other surgical tubing from them also in the future.
That's my 2-Cents. - Paul
Pauliwog is offline Find More Posts by Pauliwog
Old Jul 01, 2011, 10:47 AM
JoeCube is offline
Find More Posts by JoeCube
Woodinville, WA
Joined Jul 2009
Here are the exact dimensions I received after asking Theraband a while back.
Color/ID/WALL/OD
tan/.062/.031/.125
yellow/.200/.045/.290
red/.200/.057/.314
green/.200/.069/.338
blue/.200/.085/.370
black/.200/.098/.396
sliver/.200/.125/.450
All dimensions above are in inches.
Joseph
JoeCube is offline Find More Posts by JoeCube
easy way to use hi start jtraxler Sailplane Talk 16 Dec 12, 2007 10:50 PM
Learning to use AutoCAD 2002 OCModels Power Systems 4 Mar 07, 2002 11:55 AM
Need a source for hi start tubing Jar'sbuddy Electric Sailplanes 3 Feb 01, 2002 12:11 PM
NIB Dynaflite Hi-Start (standard) JCastle Aircraft - Electric - Airplanes (FS/W) 0 Dec 27, 2001 10:15 PM
How can I make a hi-start?...I've got the materials kiwip Electric Sailplanes 6 Jul 02, 2001 10:14 AM
