Old Dec 09, 2011, 12:21 PM
RC10TC is offline
Find More Posts by RC10TC
Joined Oct 2011
T-Rex 450 3GX help with wagging tail
Can anybody give me advice on how to fix wagging tail on my new t-rex 450 3gx? I've tried lowering the gyro , but it still wags. I am using a dx8 radio.
any help/advice will be appreciated. Thanks.
RC10TC is offline Find More Posts by RC10TC
Old Dec 09, 2011, 01:18 PM
Elios000 is online now
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
lower the tail lock gain if the normal gyro gain isnt working
for the normal gyro gain in the DX8 gain menu try around 50 to 60
if that doesnt work youll have lower the tail lock gain in the 3G settings by hooking it up to your PC
Elios000 is online now Find More Posts by Elios000
Old Dec 09, 2011, 01:44 PM
RC10TC is offline
Joined Oct 2011
I'm a newbie to heli set-up....how do you adjust the tail lock gain?
Old Dec 09, 2011, 05:26 PM
Elios000's Avatar
Joined Jul 2010
youll need to hook up the 3GX unit to your pc and change the settings in the software
but try lowering the gain on your radio first
Old Jan 30, 2012, 07:15 PM
RCGP is offline
Find More Posts by RCGP
RCGP's Avatar
Canada
Joined Dec 2010
i have a slightly different trouble. i have the gyro gain to heading hold ( around 70%) but when i start to spool up my 550 3gx, the rudder pitch starts to slide all the way to the end of the shaft causing the help to pyroette to the left and when i give it input the other way it takes abut then immediately goes back far left again and stays there to pirouette.
any thoughts on what i need to do to fix it?
RCGP is offline Find More Posts by RCGP
Old Jan 31, 2012, 07:16 AM
Elios000's Avatar
Joined Jul 2010
it correcting the right way?
if you move the tail to the right does the gyro correct by moving the leading edge to left?
Old Jan 31, 2012, 11:12 AM
RCGP is offline
RCGP's Avatar
Canada
Joined Dec 2010
hey thanks - excellent question - i tried and it did not so i read the manual again and found i needed to reverse the gyro and after that i tried it again and it moves in the right direction now - thanks very much for your help. i really appreciate it.Cheers
Old Jan 31, 2012, 11:16 AM
RCGP is offline
RCGP's Avatar
Canada
Joined Dec 2010
if i could ask another question of you, the dx* has a gyro gain range of -100 to +100 ( unlike other radios). when i set the gain for heading lock mode on a dx7 or other TX, i set around 70%. when i use my dx8 for my flybar helicopter, i set it around 28-32% for heading hold.
on this 3gx unit, the software only shows a bar graph of 0 to 100% so in order to get it to show 70% , i have to set the gain on my dx8 to 70% ( which i know for my flybar help is way too high) so do i use the 30% range on my tx ( therefore showing a 30% setting on the 3gx software setting) to be in heading hold?
Old Jan 31, 2012, 02:06 PM
Elios000's Avatar
Joined Jul 2010
yes the % shown in the gyro menu on the DX8 is the REAL gain number
im running about 46% gain in idle 2 which is gov-ed at 2600rpm on my 500
so 30 to 40 % may be right for a 450
imo set high say 50% if the tail wags back it down till it stops not going to hurt any thing
or if its not waging keep uping it till it does then back it off till to stops
again numbers dont mean much unless your running 2 helis with the same every thing on them
i dont pay much attention to the number just does the tail wag no is it holding yes then thats good
Old Jan 31, 2012, 03:02 PM
RCGP is offline
RCGP's Avatar
Canada
Joined Dec 2010
great thanks again . i will try reducing it tonight as it is currently set to 70% which sounds to be way too high.
cheers
GP
Old Jan 31, 2012, 06:23 PM
Elios000's Avatar
Joined Jul 2010
cheers
GP
no such thing if your not getting wag at 70% id just leave it there
you may want to even dial it up more till it starts wagging then back it off
you want as much gain as you can get with out the tail wagging
Sold T-rex 450 Pro V2 3GX Flybarless $450 PNP bcucoach2 Aircraft - Electric - Helis (FS/W) 4 Nov 23, 2011 08:28 PM
For Sale T-rex 450 pro v2 3gx part out nyesteban Aircraft - General - Radio Equipment (FS/W) 6 Oct 26, 2011 08:47 PM
Found T-Rex 450 3GX wbrannies Aircraft - Electric - Helis (FS/W) 0 Oct 15, 2011 11:04 AM
Help! T-Rex 450 Pro 3GX Setup Problems BimmerM3 Mini Helis 3 Sep 06, 2011 09:40 PM
For Sale Align genuine t-rex 450 pro v2 3gx barebones kit nyesteban Aircraft - Electric - Helis (FS/W) 1 Sep 03, 2011 03:13 PM
