Old Dec 09, 2011, 10:04 AM
skyjacker07 is offline
Find More Posts by skyjacker07
skyjacker07's Avatar
United States, OK, Shawnee
Joined Aug 2009
Help!
Can anyone tell me what heli this is?
I've been trying to figure out what heli this is, it's all plastic, has a brushless main, and a belted tail? I'm having trouble figuring it out, it has the wrong landing gear on it, is running a telebee gyro any help would be greatly appreciated.
skyjacker07 is offline Find More Posts by skyjacker07
Old Dec 09, 2011, 10:38 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
That would be a firefox 200...with some funky skids
That is the older frame maybe 3 years??
old version you have
http://www.elemodel.com/shopen/html/product_1480.html
Newer version
http://www.hobbyking.com/hobbyking/s...idproduct=9387
indoorheli is offline Find More Posts by indoorheli
Old Dec 09, 2011, 11:21 AM
cgriffith is offline
Find More Posts by cgriffith
cgriffith's Avatar
United States, FL, Oviedo
Joined Apr 2011
Or as I like to call them, "Money down the drain".
cgriffith is offline Find More Posts by cgriffith
Old Dec 09, 2011, 11:22 AM
Joined Aug 2009
That would be the one, I do appreciate it, now to find some parts and see how this thing flies.
Old Dec 09, 2011, 11:23 AM
Joined Aug 2009
They suck that bad huh, it was given to me so I have nothing in it, lol.
Everything is there just no tx, tail servo has some stripped gears.
Old Dec 09, 2011, 11:42 AM
indoorheli's Avatar
Joined Sep 2007
It isnt that bad and they are very cheap.
It is a good starter that you dont have to worry about crashing, even more so if it was free.
On servos most micro servos will work for that heli.
Old Dec 09, 2011, 11:43 AM
pseudocolor is offline
Find More Posts by pseudocolor
pseudocolor's Avatar
Joined Apr 2010
fyi, the firefox 200 is a plastic, clone version of the well known heli gaui 200
my favorite
and yeah, the firefox is not that bad, compare to its price.
if you want it perfect, buy the all metal gaui 200, you wont regret it
pseudocolor is offline Find More Posts by pseudocolor
Old Dec 09, 2011, 03:15 PM
Joined Aug 2009
I have a trex 250,450,500,
So being a starter heli isn't the thing, and 150-200 for a heli that I already have basically, I know metal is usually better, I just like building and working on heli's, so I just need to find a tail servo, and a set of blades change out the receiver. Are these 2s heli's or can I run 3s I have several batts for the ole 250 I could use.
Old Dec 09, 2011, 09:10 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
You can run 3s but would need a 10T pinion. It should have a 15T for 2s. I'd actually try to keep it as light as possible. Flightpower 800mah 20C short packs are a cheap decent pack that is pretty light. Hear bad things on the Nano 850's and 1000's...poor cycle life.
They're not bad. See if you can pick up a cheap Gaui 200 head...someone may have gone flybarless. The stock head is ok but breaks balls, and grips pretty easy.
For tail, if the gyro is a digital 302AD (from memory)...
go Hyp ds09
Hyp ds11
Jr290g.
Cyclics...I'd probably go with Blue Arrow D05010Mg (hobbyking). If they fit the openings they're about the best you can find cheap without compromising on function. They're good little servos.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Dec 09, 2011, 10:24 PM
Joined Aug 2009
Right now, I just need to find a tail servo and a batt, I fly my 500, and 250 a lot, so this would be just to play around with, I'm just wanting to get it in the air, so I need to find a tail servo, battery and pair of 200mm blades.
Old Dec 10, 2011, 10:01 PM
DMala is offline
Find More Posts by DMala
DMala's Avatar
New Jersey
Joined Sep 2009
Apart from Elemodel, is there any other place where to find spare parts for the Firefox? Thanks
DMala is offline Find More Posts by DMala
Old Dec 10, 2011, 11:25 PM
XXXmags is offline
Find More Posts by XXXmags
Push
XXXmags's Avatar
Hobbyking
XXXmags is offline Find More Posts by XXXmags
Discussion Can anyone tell me why my Lipos flight log looks like this? evltoy Batteries and Chargers 10 Nov 11, 2011 07:27 PM
Question Can someone tell me what this is called? 3d astronaut DIY Electronics 0 Oct 13, 2011 12:21 AM
Wanted can anyone tell me what plane this is happybird Aircraft - Electric - Airplanes (FS/W) 6 Aug 10, 2011 07:11 PM
Discussion Can anyone tell me what plane this is? mv1976 Foamies (Scratchbuilt) 3 Apr 14, 2011 05:36 PM
Which Dragonfly is which? Can anyone identify this Heli and tell me what it cloned? Snackdrag Micro Helis 22 Mar 29, 2005 06:57 PM
