Old Dec 08, 2011, 09:30 AM
Tim K is offline
Find More Posts by Tim K
Tim K's Avatar
Woodland Park, CO
Joined Jul 2000
CNC equipment and CAD files?
I own a large CNC router that is used for my cabinet business. I'm wondering if it could be used to make some of these little foamies.
When guys are cutting these things out professionally, I assume they're using some sort of router, not a laser. Is that right?
If that's true, does anyone out there have some CAD files I could fool around with? I have no interest in getting into the aircraft manufacturing business, I just think it would be fun to screw around in the shop in the evenings.
Tim K is offline Find More Posts by Tim K
Old Dec 08, 2011, 11:12 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Most manufacturing is either laser or CNC routed. theres plenty of plans in this thread that can be use. Vectric cut 2D opens PDF's perfectly and produces the required Gcode
Andy
Andycap is offline Find More Posts by Andycap
Old Dec 08, 2011, 11:27 AM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
I don't know how common it is, but a third option is high pressure water jet. This possibly gives the best results since the cut is so fine. A friend uses a CNC router and by all accounts it is a pain to set up because the tools clog easily.
Mike Seale is offline Find More Posts by Mike Seale
Old Dec 08, 2011, 12:26 PM
Andycap is offline
Andycap's Avatar
Leeds
Joined Mar 2003
Getting the speed of the cutting bit and the travel just right does take some playing. I believe that Donuts models were cut using a waterjet
Old Dec 08, 2011, 02:50 PM
Tim K is offline
Tim K's Avatar
Woodland Park, CO
Joined Jul 2000
I looked quickly at the Vectric site. Looks perfect. I'll have to spend some time researching when the workload lightens up around here.
Old Dec 09, 2011, 04:39 AM
srl is offline
srl
Find More Posts by srl
srl
srl's Avatar
Sydney New South Wales Aust
Joined Mar 2007
This is my latest indoor build based on the Index3 in the plans thread here. Its now finished and been flying almost every day for the last three weeks.
It was milled using a 1 and 6mm dremel bits on my DIY machine. Just give the depron a spray of water to stop the bits over heating.
srl
srl is offline Find More Posts by srl
Old Jan 15, 2012, 10:44 PM
bjzq8 is offline
Find More Posts by bjzq8
Joined Dec 2008
What kind of router is it? Do you know what kind of input files it takes now? I used to program for a large router, but it had custom "sign making" software. It could import a DXF file, though, which is a standard AutoCAD exchange type. I have AutoCAD and I'm good enough at it (still, after all these years, sniff..sniff) to convert pretty much any way you'd like to go. Let me know the specifics and I'll see if I can help you.
bjzq8 is offline Find More Posts by bjzq8
Discussion Cad Cnc interest Books listed ptxman CAD/CAM 0 Jul 25, 2011 10:10 PM
Discussion CAD files for ROLL PITCH CAMERA MOUNT? arnaldo26 Multirotor Talk 0 Apr 04, 2011 06:33 AM
CNC@net's cnc files? Phillybaby The Builders Workshop 17 Nov 20, 2005 03:48 AM
Question Delta Cad files to DXF files ?? Marion Modeling Science 0 Nov 12, 2004 08:09 PM
