Old Dec 08, 2011, 04:51 AM
Adverse Effects is offline
Find More Posts by Adverse Effects
Australia, QLD, Acacia Ridge
Joined Dec 2011
Build Log
Adverse's Proposed Quad Build -AU - QLD
Hi All
i feel like a total noob to what is out there now
the last time i played with RC was 30 odd years ago and it all was so basic and i dont think i ever saw an electric RC plane back then
i have spent the last 3 weeks struggling through the multi copter forum section
(i am dislexic and have an extreme trouble reading and writing all i can say is than god for spell checker or you wouldnt be able to read what i type)
i am losing mobility slowly but surly (back and right leg failing) so carnt do much of what i love to do (build things like cars and trikes from scratch for road use)
so i have decided to get back in to the RC game
OMFG is all i can say LOL
there is more technology in a single servo now then there was in a full high end 5 ch TX/RX plane from when i did it last
if you had a motor bigger than a 0.25cc motor on your plane you had sold your house to buy it
my first plane was a plastic Delta with a 0.25cc and 3 ch controller and it cost me over $ 400 back then (30 years ago that was about 6 weeks pay for me) and it was that brittle that i cracked it when i bumped it on my car putting it in the boot on the 4th or 5th time i took it out to fly
but enough about me on to my build
i want to build a Quad (and other types at a later date)
because if my reading skills i am having trouble understanding a lot of it
i want to build a long duration flight quad and be able to go up to 1K away if i can
FRAME
i will be building my own frame about 1/2 Mt across (bit under 2 feet)
FPV
this will come once i have destroyed the copter several times or i get good at flying
But am looking at something like fly higher&see farther ALL-IN-ONE video goggles about $470 for the full kit
CONTROLLER
i would love a OP CC Pro (or what ever the new one will be called) when they come out
will have to look at other options if i carnt get one by the time i need it
ECS
HobbyKing Red Brick 25A ESC
Specs.
Max Amps: 25A
Ubec: 5v / 3A
Cells: 2~3s Lipoly
Size: 48mm x 10mm 26mm
Weight: 23g (Inc Wires)
*** OR ***
HobbyKing 30A BlueSeries Brushless Speed Controller
Spec.
Cont. Current: 30A
Burst Current: 40A
Battery: 2-4 Cell Lipo / 5-12 Cell Ni-XX
SBEC: 5V/ 3A Output
Weight: 28g
MOTORS
NX-4005-650kv Brushless Quadcopter Motor
Specs
Kv: 650rpm/v
Turns: 24T
Resistance: 0.147Rm
Idle Current: 0.6A
Can size: 45mm
Can Length: 10mm
Shaft: 3mm (Includes Prop saver mount for GWS style props)
Suggested ESC Amps: 20A
Rated Watts: 130W
Weight: 59g
Cell count: 3~4S Lipoly
Prop adapter suit 5mm propeller
*** OR ***
NX-4008-620kv Brushless Quadcopter Motor
Specs
Kv: 620rpm/v
Turns: 16T
Resistance: 0.129Rm
Idle Current: 0.8A
Can size: 45mm
Can Length: 14mm
Suggested ESC: 30A
Rated Watts: 180W
Weight: 79g
PROP'S
GWS HD9050 3 Blade Prop (2pc pack)
and
GWS HD9050 3 Blade Prop Counter Rotate (2pc)
*** OR ***
GWS HD8040 3 Blade Prop Counter Rotate (2pc)
and
GWS HD8040 3 Blade Prop (2pc pack)
i would like bigger props but i carnt find counter rotating ones to match bigger ones
BATTERY
ZIPPY Flightmax 5000mAh 4S1P 45C
MORE TO COME
how am i doing so far?
any help and or changes i should do i would be grateful for the help
as for the TX/RX unit i am totally lost
i am the type of person that dose not like to do thing "cheep and nasty"
for instance i needed something turned up on a lath could have bought a $300 cheepy but went out and bought a 2nd hand mid range commercial lath to do the job same with a band saw i could have got away with a $200 hobby unit but got a 2nd hand 9 foot tall commercial unit the same thing will ALL my 2 car garage full of tools
dont get me wrong i am not rich (infact i am now on a disability pension) but i wont buy something that will only work a few time and have to replace it i would rather save up 2 times the money and buy a good commercial unit
Adverse Effects is offline Find More Posts by Adverse Effects
Old Dec 08, 2011, 07:29 AM
Tifani is offline
Find More Posts by Tifani
United States, IL, Park Ridge
Joined Apr 2010
Hi !
I would say - don't be cheep with Radio TX/RX
All other parts I will go by statistics - it mean more peoples use it better.
For egz.
DT-750 motors
Plush or SS ESC
Good luck
Tom
Tifani is offline Find More Posts by Tifani
Old Dec 08, 2011, 06:48 PM
AusTelemetry is offline
Find More Posts by AusTelemetry
Australia, NSW, Glen Innes
Joined Sep 2011
G'Day Adverse
There are quite a few Aussies here who will be able to guide you and I'm sure that thre are some Brisbane based members who will step up and help you out.
regards
AusTelemetry is offline Find More Posts by AusTelemetry
Old Dec 08, 2011, 10:09 PM
Joined Dec 2011
Thanks AusTelemetry my head is just swimming with all the new stuff out there LOL
i am even going to the extent of looking for a smallish cnc router so i can draw and cut my own frames and maybe even for others down under so we all can have custom units ;-)
if someone wants to come over and give me a hand there could even be some free drinks in it for them ;-)
Old Dec 08, 2011, 10:50 PM
Joined Dec 2011
one thing i have noticed is if i want to buy most of the stuff here in Oz its 4 times the price what the hell is going on there?
Old Dec 11, 2011, 02:47 AM
Joined Dec 2011
i would have expected a little bit more help with this looks like i'll have to go it alown and get it wrong a few times
Old Dec 11, 2011, 04:55 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
the motors look very nice so nice i bought a set when they 1st came out i run 3s lipos and to me the nx4008 620kv motor for $31 wasnt as good as a dt700 with same prop and 3s lipo
this may be very different on 4s but for the price?? well i have 4 620kv motors and 14 700kv motors
clicking on my name might offer some helpful reading from another dyslexic
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Dec 11, 2011, 05:26 PM
Joined Dec 2011
thanks for that info n3m1s1s
i'll look at your at your info
Old Dec 13, 2011, 08:57 AM
Joined Dec 2011
where do all the Aussies get there gear from?
i went to HK and added just a few things (6 motors 4 esc's) and that is not even 1/8 of the things i want and the postage was almost the same cost as the hardware
Old Dec 15, 2011, 08:15 AM
Joined Dec 2011
ok so far i have ordered and payed for
1X 2.4Ghz 9Ch Digital RC Plane Heli LCD Radio Gear Tx Rx AU $78.80 +$22 post
Features:
Full range 2.4GHz 3rd Generation 9-channel radio
Multi-data computerized Display 128*64 LCD
8-Model Memory
8 Models Select
Integrated timer
Contrast Adjustment
Throttle cut
Computer Programmable
Digital Control
4 X C2830 KV750 Aeolian motor + skywing 30A ESC BEC 2010 AU $23.29 EACH + free post
Package Content :
1 x aeolian 2830 kv 750 Outrunner Brushless Motor
3 x Golden Connector
Motor Accessories
1 x 30A Speed Controller ESC
5 x Heat shrinking Tube
750 (kv) RPM/V
Continuous Current: 20A
Max. Current: 28A
Input Voltage: 6 - 11.1V
Max. Efficiency: 98%
No Load Current: 0.5A
Internal Resistance: 352(Omega)
Power: 225W
Motor Weight : 108g
Motor Dimensions (Diameter x Length): 28mm x 30mm
Size: 56* 25 *10mm
Constant Current: 30A
Max Current: 40A/12s
BEC output: 3A
Internal Resistance : 0.0021m(Omega)
Cable Type : 16 AWG (Battery & Motor)
Cable Length : 72mm (Battery)
72mm (Motor)
190mm (Receiver)
Input Volt: 6 - 11.1V
Low-Voltage Cutoff: Auto detect and set
Quadplay Q6 Intelligent digital Balance Charger lipo 1-6s AU $126.48 +Free post
Input voltage range: DC11.0-18.0v
Charge current range: 0.1-5.0A
Discharge curren range: 0.1-1.0A
Charge power limited: max.50W x 4
Discharge power limited: max.5W x 4
Balance current:max.250mA
Balance tolerance:0.01V
Nicd/NiMH battery cell count: 1-15cells
Lithium battery types:Lipo,Li-ion,Li-Fe
Lithium Battery cell count:1-6 series
Pb battery voltage: 2-20V(1-10 cells)
weight:1090g
Dimensions: 220x150x55 mm
so how am i doing so far?
still looking for props i would like 3 or 4 blade but haveing trouble finding the counter rotating props to match
Old Dec 15, 2011, 08:25 AM
n3m1s1s is offline
Joined Feb 2007
so far so good
Old Dec 15, 2011, 05:13 PM
Joined Sep 2011
Did you look for the Australian warehouse stuff? Click "Australia" under the sort option when you are browsing by category. This will help with freight as will not buying lipos overseas as the postage is really cruel.
There are some Aussie based multicopter retailers as well. Do a google search for quad copter Australia and see what pops up.
Old Dec 15, 2011, 10:03 PM
Joined Dec 2011
thanks will do a search on it
as for the AU HK stuff there isnt much of it lol
has anyone tryed thes on a quad
EDF
Old Dec 19, 2011, 07:57 AM
Joined Dec 2011
hmm should i be worryed
all the parts i ordered from a ebay seller (he had over 1000 different items for sale) have not been posted yet even tho i have payed for them
and now i look and the guy dosnt have anything at all for sale on ebay i am just glad i payed with paypal so i can do a dispute on them
Old Dec 19, 2011, 08:38 AM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
link?
brodjack is offline Find More Posts by brodjack
Discussion Proposed 450 Pro build LudaChris408 Mini Helis 4 Jun 19, 2011 05:19 PM
Discussion HELP!! Proposed EXI 450 belt build Opie420 Mini Helis 10 Jun 18, 2011 01:34 AM
Discussion Proposed F5J rules _ what would you build jirvin_4505 Electric Sailplanes 42 Nov 20, 2006 07:45 AM
Discussion The President's proposed budget Tim Jonas Life, The Universe, and Politics 54 Feb 16, 2006 08:37 PM
