Old Dec 07, 2011, 09:31 PM
AsSoulsDream is offline
Find More Posts by AsSoulsDream
AsSoulsDream's Avatar
United States, FL, Ocala
Joined Sep 2011
spackle????
I have been looking around on youtube and have seen where some guys building foamies are using spackle to smooth out or shape their planes, is this the same spackle as they use in drywall?????
AsSoulsDream is offline Find More Posts by AsSoulsDream
Old Dec 07, 2011, 09:54 PM
djacob7 is online now
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
Here's a trick you could use to find the answer. Type this into your browswer:
spackle site:rcgroups.com
djacob7 is online now Find More Posts by djacob7
Old Dec 07, 2011, 10:25 PM
billwhit is offline
Find More Posts by billwhit
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
No, there is lightweight spackle you can buy. It's usually sold with the other stuff, but the container will feel empty when you pick it up. I use it all the time on my foamies, it works really well and sands smooth once dry.
billwhit is offline Find More Posts by billwhit
Old Dec 08, 2011, 03:02 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Yes Indeed! The light-weight spackle is a Foamies freind indeed! quick repairs, blending, or shaping Spackle Rocks!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Dec 08, 2011, 12:51 PM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
Spackle rocks? Why would I want to attach rocks to my aircraft? Aren't rocks kinds heavy? [cough]
The idea is to get the foam as smooth as you can first, then apply Spackle as a last surface smoother. Kinda like Bondo for cars, but without so much rust involved.
A Useless Geek is offline Find More Posts by A Useless Geek
Old Dec 08, 2011, 03:31 PM
Joined Sep 2011
awesome, that opens so many door in my head for ideas......TYVM
Old Dec 08, 2011, 06:31 PM
rchank is offline
Find More Posts by rchank
I used to like trees
rchank's Avatar
United States, WA, Spokane
Joined Jul 2011
Some builders are also mixing the light weight spackle with WBPU or Polycrilic to make a coating that can be brushed on, then sanded after it dries.
rchank is offline Find More Posts by rchank
Old Dec 08, 2011, 07:50 PM
propjobbill is offline
Find More Posts by propjobbill
propjobbill's Avatar
USA, OH, Oberlin
I use the lightweight spackle all the time. This is not the drywall spackle that is like joint compound. Lightweight spackle is almost weightless. Once it dries I doubt that it weighs much if any more than foam the same size.
propjobbill is offline Find More Posts by propjobbill
Old Dec 08, 2011, 08:51 PM
dhc8guru is offline
Find More Posts by dhc8guru
Joined Apr 2006
I use hobby-lite. I bought it then figured out it is the same as the Elmer's dry filler I had. When the hobby lite runs out I will use the Elmer's or dap filler, it's about $3 a can cheaper.
dhc8guru is offline Find More Posts by dhc8guru
Old Dec 08, 2011, 08:55 PM
Up-Out-&-Gone
Joined Mar 2007
Rocks on an airplane? . . . .Shure! Hay the Flintstones made it work! lol
Old Dec 08, 2011, 09:43 PM
RJD1234 is offline
Find More Posts by RJD1234
RJD1234's Avatar
Bakersfield, CA
Joined Apr 2008
I've use Spackle for some of my larger aircraft. The trick is to make sure to sand most of it off. Leave just enough to cover dents and holes or whatever. It still adds weight.
RJD1234 is offline Find More Posts by RJD1234
Old Dec 09, 2011, 11:51 AM
Chicagoland
Joined Oct 2008
Bill, I was trying to make a phunny. Obviously my phunny skills are not even up to my flying skills, which aren't all that great to begin with...just take a look at my collection of damaged and wrecked 3D planes. Heh.
Hey, maybe some Spackle on those 3D planes, and...
Old Dec 09, 2011, 12:21 PM
USA, OH, Oberlin
Sorry about that, my bad. Shows how little I know. When I first read about using skackle, I thought they were talking about the heavy stuff.
That was a few years ago.
Old Jan 06, 2012, 09:21 PM
Coulee Flyer is offline
Find More Posts by Coulee Flyer
Another Flying W
Coulee Flyer's Avatar
Joined Dec 2011
Good Info....
Will have to give this a try on the left sponson of my Flying W - damaged in a bone-head maneuver trying to fly through a "tunnel" - made it the first time, second time "not so good"
Coulee Flyer is offline Find More Posts by Coulee Flyer
Old Jan 07, 2012, 01:59 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
Also, you can shape and then sand the dry spackle and then hit it with foam safe CA and it becomes rock hard at no added weight.
62pilot is offline Find More Posts by 62pilot
Discussion LWS (light weight spackle) for EPP wing question Twyl Slope 6 Jun 06, 2011 11:42 AM
Will spackle compound work to fill pin-holes in a FG fusalage? tempest411 Electric Sailplanes 7 Apr 03, 2002 02:44 AM
Spackle and Foam and Polyurethane and Paint (Oh my!) Merlin_FAC Foamies (Kits) 19 Nov 24, 2001 05:53 PM
Just what is spackle ? Fronty Electric Plane Talk 16 Aug 03, 2001 06:33 AM
What is SPACKLE!?!!? gdb1973 Foamies (Kits) 5 Apr 22, 2001 07:34 PM
