Old Dec 14, 2011, 12:47 PM
NICO38 is offline
Find More Posts by NICO38
Joined Dec 2011
This is my list of christmas father
Hi,
This my list of christmas father for myQuadricoptère :
2 tube de 12*10 mm sur 1 m => 5 € (après je ferais les trous nécessaire dedans moi-même) avec deux plaque de plexy chez casto (je prévois 40 cm de diamétre) :
http://www.castorama.fr/store/Tube-r...RDm173921.html
4 esc 30 A => 33 $ (les 4) :
http://www.hobbyking.com/hobbyking/s...k_30A_ESC.html
1 Carte mère multiwii complete => 73$ :
http://www.ebay.co.uk/itm/MWC-MultiW...item20bfc4cb9c
programmeur => 15 $ :
http://www.ebay.com/itm/FTDI-Basic-B...item336eb09c9a
Moteur : 243w 950kv/ 30a 70g => 46.22$ :
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Batterie 22ma, 25c, 0,188g =>8$ :
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
1 telecommande 6 voies avec le recepteur => 22.99 $ :
http://www.hobbyking.com/hobbyking/s...2_Mode_2_.html
Cable usb pour telecommande => 2.99 €
http://www.hobbyking.com/hobbyking/s...USB_Cable.html
4 hélices 10*4,5" => 8 € :
http://cgi.ebay.fr/4-Pairs-10x4-5-10...item3f0c5f42f9
Charger de batterie => 11.44 $ :
http://www.hobbyking.com/hobbyking/s...40v_Input.html
23 $ livraison hobbyking
If that can help us. For me this is the best value for money.
Nico38
NICO38 is offline Find More Posts by NICO38
Old Dec 14, 2011, 03:39 PM
jb92563 is offline
Find More Posts by jb92563
Fournier RF4D N1771 Awesome!
jb92563's Avatar
Riverside, CA
Joined Nov 2004
Originally Posted by SGsoar View Post
is there any documentation that says you cannot plug all 4 esc's into the crius boards?
i would assume they are the same as the KK boards... where it is ok to use multiple power inputs
In the early development of the MultiWii it was found that hooking all the BEC's together would cause problems.
Even now some folks are finding it necessary to connect a Seperate dedicated BEC.
You can try and let us know if you fry your ESC's, MWC board, RX, servos or get unstable performance.
There is no reason to connect more than one in any case since it only powers the board, RX and servos(Tri or camera gimbal).
Ray
jb92563 is offline Find More Posts by jb92563
Old Dec 14, 2011, 08:30 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by WiseDuck View Post
I'm not sure how to do this. I've intalled the drivers for the FTDI board and it's alright. But connecting it to the Crius board gives me nothing, I see a red and orange led on it. Shows up in the Device Manager as a "USB Serial Port" with an exclamation mark next to it. Do you need drivers for the Multiwii board too?
I'll test it on my Macbook as well.
My board just arrived, I plugged it into a Windows XP machine, the hardware wizard detected it and went off to the Internet downloaded and installed the correct drivers. Ran the Multiwii java GUI, selected COM3, clicked start and it all worked fine. Just have to figure out what the wall of variables in the GUI should be set to!
It was X-Mode out of the box.
Erknie is offline Find More Posts by Erknie
Old Dec 15, 2011, 04:09 AM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Originally Posted by Atx_Heli View Post
Latest version of guide....
Added a lot of setup info....I think that this is what I really needed two days ago when I began researching everything...to avoid the research...
feel free to correct and comment...if it passes muster, maybe we should move it to the first post by Katch
First, very cool guide i think many will apreciate the effort you took to make one gongrats!
I have a question about it though, maybe more..
In your guide you are talking about "Autoleveling" can you please describe "How/what/do" Autolevel? :S
erazotropa is offline Find More Posts by erazotropa
Old Dec 15, 2011, 07:09 AM
Rober-t is offline
Find More Posts by Rober-t
Joined Feb 2010
Autolevel means that you control the angle with your stick, so as long as you have the stick off center, the copter will be off horizontal position.
Heading hold means that you control the angular velocity with your stick, so as long as you have the stick off center, the copter will rotate.
Of course Autolevel is easier to fly because you can let the stick snap to the center and the copter will move to horizontal (hover) position and will not just stop rotating.
Bad thing is, that you will need an additional sensor (accelerometer) or an additional calculation (integrating the angular velocity over time) for autoleveling.
As the gyroscopes we use in our copters are drifting quite a bit you'll have better results with an accelerometer.
Another drawback is, that loopings can not be flown with autolevel. As most of the projects limit the angle to about 90° or less you just can not rotate your copter beyond that point.
Happy Amps!
Rob
Rober-t is offline Find More Posts by Rober-t
Old Dec 15, 2011, 07:31 AM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
also, autolevel (or sometimes called stable mode, using the accelerometers), heading hold (using the magnetometer), as well as camera stable and trigger modes are activated by the AUX switches...what AUX switch position does what is setup in the Configuration program...see video referred to in guide
Atx_Heli is offline Find More Posts by Atx_Heli
Old Dec 15, 2011, 08:09 AM
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Ahh ok thanks, now i understand the meaning
Maybe its good to explain a bit in more "noob" style.. to create a fool proof guide
I was flying with my quad a few minutes ago. with standard PID
The Aileron and Elevator are rock solid with standard settings.. also when i twitch the stick, it doesnt wobble.. need any more adjustment? increasing the P and I? until it does wobble..
What i want to know is the following..
When Hovering, if i increase the P to high it should wobble.. yes..
The I is for anti wobbling at stick release?? just for my uderstanding.
Also the YAW is solid when hovering.. but when i rotate and release the stick it slightly rotates out.. how to adjust this?
Old Dec 15, 2011, 08:47 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
if you like the stability...don't change it!
I've read many suggestions on how to tune I...the one I use is after you have adjusted P and D ,then tune I to eliminate any pitching up tendencies in forward flight after you release the stick...ie pitch forward to set fast forward flight attitude, then releasing the stick, the copter should hold attitude and continue flying...but its personal preference
if it overshoots, you may have too high a P value on yaw...trying backing off a bit...increasing P increases the speed at which the gyros are brought back to zero (no rotation in that plane), but also increases overshoot, until at some point you get unstable and ring a lot or even uncontrollably...increasing D dampens these rings...slowly the rate of correction...smoothing the correction..
on the KK board with 4.7 firmware, yaw is a PI only loop with I fixed...you can only adjust P...I max it out and then back down to a point at which I get reasonable yaw stick sensitivity...you live with whatever overshoot you get, if any...
Old Dec 15, 2011, 11:23 AM
Katch is offline
Find More Posts by Katch
FC flux'd
Katch's Avatar
Joined Jan 2007
added the setup guide to the first post. cheers Atx_Heli
Katch is offline Find More Posts by Katch
Old Dec 15, 2011, 11:27 AM
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Well when i release the Yaw stick it decays before it stops..
When hovering, yaw stays perfectly... but when i rotate and release the stick it decays and stop.. not a solid fix
Old Dec 15, 2011, 11:50 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
okay, I thought you were saying it overshoots and bounces back...ie rings some...if it just slowly comes to rest, increase the P...that will make it try to zero the angular rotation quicker...
here is how the loop works...
-from steady state resting you give it a yaw input
-this results in an error signal since the gyro output is zero (no rotation)...ie error=stick input - gryo...this gets multiplied by P and output to the appropriate motors to start it yawing..
- angular rotation rate increases, until the gyro output = stick input and the error is zero...steady state yaw rotation rate
- then you release the stick input and error jumps the other direction since stick is zero and gyro reflects the rotation rate, this gets multiplied by P and sent to motors, rapidly decreasing yaw rate....as it approaches zero for the error, the motor correction ceases and you are stead state non-rotating...
now if P is too big, you overshoot the steady states above and ring...if too low, you approach the steady states more slowly...but corrections for outside disturbances (wind,etc.) is slowed and reduced...ie more drift..less "locked in"
its a tradeoff between responsiveness and locked in feeling, between overshoots and more drift/error in the steady state...
Old Dec 15, 2011, 01:25 PM
chebari is offline
Find More Posts by chebari
Joined Dec 2011
Hi all.
Might put some video of these prune of estavilizacion
chebari is offline Find More Posts by chebari
Old Dec 15, 2011, 03:00 PM
Erknie is offline
Joined Nov 2011
Run into a problem with the lite board. I am using Turnigy Plush 6 ESCs and when I power up, the do their normal initial beep, then they all start beeping continuously, I think means throttle is not at the lowest position. I looked with the Multiwill GUI and it said the throttle was about 1100 which is low. It's not a specific ESC either, I can test them one by one and they all do it. They were working fine on a HK KK board, I just pulled that out and put the Lite board in. I haven't recompiled Multiwill yet.
Any ideas?
Old Dec 15, 2011, 03:24 PM
chebari is offline
Joined Dec 2011
Please estavilizadora some video of this. Thanks
Old Dec 15, 2011, 03:48 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
Subbed. So is goodluckbuy still the least expensive place to buy for US delivery?
Bmr4life is offline Find More Posts by Bmr4life
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
