Austin, TX
Joined Jan 2009
Tried the new pre 2.0 software out today on my muck about quad. Great news is that the Crius board SE is easily configured as it exists in the multiwii config.Just uncomment the board and all the correct sensors are enabled. The mag and baro now works! I upped the mag setting from 4 to 10 and it really holds yaw very well. Tried the carefree mode too.This truly screws your head up ![]() For years i have been learning to fly,finding the difficult bit to be correctly responding to the craft in various orientations.With carefree enabled it doesn't matter! I arm the craft with it pointing directly away from me.The cyclic stick(roll/pitch) then moves the craft in the same direction you push the stick, regardless of any subsequent yaw commands. I know that most of you will already know this stuff but i am truly impressed with this board and the stability of my quad.Tis well good
Austin, TX
Joined Jan 2009
Latest newbies guide
I updated the last section finally for Lite boards since the questions come up again and again....I don't own one so I originally wrote the guide just help me before I got my first SE board, but I have decided to add the Lite compile options in it...
EDIT: latest guide is in Post 1 |
Really nice to see good support like this as the first attempt at a multirotor is a big hurdle. Great work and many thanks Atx_Heli |
Joined Nov 2008
Hi guys,
Firstly, I've been following this thread for months and am wowed at the progress the board's followers have made. We appear to have some coding einsteins;watching the jump from multiwii v1.9 to v2.0 made me go out and buy the board ![]() Which brings me onto a total noob question... Basically, I appear to have a crius SE board which has no stability in its roll or yaw axis and would like to know what's up with it. After going through enough pages of this thread to take up an afternoon and half an evening, I don't think I've seen any guide that can help or similar query. The board is dead centre on the frame and vibration-free. A week of PID tuning has been fruitless. The board is always tested with the accelerometer, mag and baro disabled. Interestingly, the pitch axis appears to work fine. This scenario is consistent regardless of the code. I have tried both 1.9 and 2.0. Also interestingly... -My debug1 values are in the thousands (approx 3000 within 10 seconds of connecting the board) -My debug 2,3 and 4 values are zero -The sensor graph shows no irregularities in the gyro readings. All present a flat line when the board is undisturbed. Rolling the board right causes the roll reading to move upwards, as I believe it should (gyro sense direction is correct) -Accelerometer readings are all over the place, jumping wild amounts regardless of calibration. -The bottom-right 'quadcopter graphic' shows erratic movement even when the quad is stationery. Sometimes it will spin a full 360, other times it will twitch from side to side on a random axis (which can be pitch). Help! |
@AtxHeli,
I've followed the guide and edited the code for lite FC board but when I uploaded the code the the lite board, the status LED (blue) just keeps on blinking. but if I upload the SE code, the lite board accepts it. btw, my lite board has these chips: ITG3205 ADXL345B if I use #define ADXL345 the status LED blinks but if I use #define BMA180, the board accepts the code. (the board clearly has 345B chip on it) what's the meaning of the blue LED blinking? wrong code? but code's ok after compiling (no error) |
If yes, try to press with finger on acc/gyro chip when copter is attached to PC (not armed, better take off props - safer). If something changes (You get straight lines in GUI) - then You got cold soldering. Re-flow chip with hot air (or ask in mobile phone repair box to do it for You). And test with gyro-only first. That will help to isolate problem (when testing acc+gyro combo, You won't know what is failing - maybe just gyro and acc axis mixed up - yaw acc to roll gyro, etc...). |
| Thread Tools | |
| New Product Full Foxtech AIO Glasses Review | Guizmo12 | Video Piloting (FPV/RPV) | 1200 | May 05, 2013 03:04 PM |
| Sold Arduino / MultiWii / Megapirates Boards | 3rdeyepro | Aircraft - Electric - Multirotor (FS/W) | 3 | Dec 03, 2011 08:43 PM |
| Wanted MSR 5in1 boards and MCPX 3in boards | beachflyer | Aircraft - Electric - Helis (FS/W) | 3 | Nov 22, 2011 09:14 PM |
| Discussion Foxtech AIO goggles RX? | Teamsherman | Video Piloting (FPV/RPV) | 2 | Oct 02, 2011 10:06 AM |
| Sold 3 x PCB boards for multiwii copter for $28 | madushan2008 | Aircraft - Electric - Multirotor (FS/W) | 1 | Sep 06, 2011 06:53 AM |
