Old Dec 13, 2011, 05:48 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by Altura View Post
Just received my "MWC MultiWii Lite lightweight version 4-axis flight control board" from Ebay.
Everything work good on GUI and on fly.
My frame is a very simple one maked of EPP for the boady and carbon arms.
GUI indicates a Cycle Time=2400
I just broke 3 pins on the board connected to 3 of the 4 ESC to make sure only one ESC power the board.
I uploaded the 1.9 code with arduino 0022 and the following defines:
#define MINTHROTTLE 1300 // for TURNIGY PLUSH 6A
#define QUADX
#define I2C_SPEED 400000L
//#define INTERNAL_I2C_PULLUPS
#define ITG3200
#define ADXL345 // !! beacause the ligth version is NOT BMA0180
#define MAXTHROTTLE 1950
3 pins removed to power fro only one ESC:
GUI
My copter:
Uploaded with ImageShack.us
No need to cut BEC pins, they wouldn't be connected if it was an issue.
I hope that's anti-static foam you are resting the sensitive electronics on?
Erknie is offline Find More Posts by Erknie
Old Dec 13, 2011, 05:52 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Looks like styrofoam to me.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Dec 13, 2011, 09:20 PM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
Noobie Guide to Software
Having gone thru the learning curve of reflashing my TH-9X transmitter to the ER9X firmware and loading new KK controller firmware on my HK Quadcopter V2 board, I really apppreciated some of the novice guides taking one thru the entire process for these systems...
And...not having any previous knowledge of the Arduino or MultiWii systems, and having ordered a CRIUS MultiWii SE board to upgrade my copter, I did not find a guide in one place with the necessary steps and info....so, I decided to create one....bear in mind that I have NOT yet gone thru the process myself...I am awaiting the board....but since I had to do the research in preparation for its arrival, I decided to put this guide together...
please feel free to point out errors I've made and/or make suggestions for improvements...
****UPDATED in later post****
Atx_Heli is offline Find More Posts by Atx_Heli
Last edited by Atx_Heli; Dec 15, 2011 at 08:58 AM. Reason: see later version of manual
Old Dec 14, 2011, 12:09 AM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
I think the board you have chosen in the Arduino Environment is incorect
bignose13 is offline Find More Posts by bignose13
Old Dec 14, 2011, 12:32 AM
edwin3162 is offline
Find More Posts by edwin3162
Joined Sep 2007
Hi Atx_Heli,
Thks for posted the guide very usefull for noob like me . But I was wondering GLB stated "ITG3205 TRIPLE AXIS GYRO" but the code in your guide is "f. Use: #define ITG3200".?
Regards,
Edwin.K
edwin3162 is offline Find More Posts by edwin3162
Old Dec 14, 2011, 12:34 AM
Joined Sep 2007
Hi bignose,
So which board to chose? Thks
Regards,
Edwin.k
Old Dec 14, 2011, 01:00 AM
Altura is offline
Find More Posts by Altura
Altura's Avatar
France, IdF, Paris
Joined May 2011
I think you have to detach 3 of the 4 red wires of your ESC or remove 3 of 4 red pins on the board to make sure you power the board by only one ESC.
My frame is made of Expanded Polypropyle (EPP), hope it's anti-static...never had issue with it and it saves lot of weight (total weight w/o battery is 135 gr)
Altura is offline Find More Posts by Altura
Old Dec 14, 2011, 02:24 AM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
is there any documentation that says you cannot plug all 4 esc's into the crius boards?
i would assume they are the same as the KK boards... where it is ok to use multiple power inputs
SGsoar is offline Find More Posts by SGsoar
Old Dec 14, 2011, 03:00 AM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
With Linear becs there is no use to cut all red wires.. they can be paralel connected with no problem..
Make sure they are linears no switching becs!.
I have Turnigy Plushes connected all togheter.. nooo problemo..
erazotropa is offline Find More Posts by erazotropa
Old Dec 14, 2011, 06:54 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
based this on post #47 of this thread....
if it is incorrect, can someone tell me the correct one?
Old Dec 14, 2011, 06:55 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
I will update the guide to reflect this....thanks
Old Dec 14, 2011, 07:11 AM
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Im using this, and works fine for me
Old Dec 14, 2011, 07:33 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
Looking at the def.h file, it would seem that selecting any board with a 328P will pickup the Promini definitions....so it I think I will leave it be in the guide..
looking thru the config.h file I find these commented out by default:
/* possibility to use PIN8 or PIN12 as the AUX2 RC input
it deactivates in this case the POWER PIN (pin 12) or the BUZZER PIN (pin 8)
//#define RCAUXPIN8
//#define RCAUXPIN12
shouldn't I uncomment one or both to use the second aux input if we aren't using the buzzer or power pin (don't know what that is for anyway)?
Old Dec 14, 2011, 11:12 AM
Atx_Heli is offline
Austin, TX
Joined Jan 2009
Latest version of guide....
Added a lot of setup info....I think that this is what I really needed two days ago when I began researching everything...to avoid the research...
feel free to correct and comment...if it passes muster, maybe we should move it to the first post by Katch
EDIT: Latest guide in post 1
Old Dec 14, 2011, 12:27 PM
Yeah Baby
bignose13's Avatar
Joined Apr 2006
Thats the setting im using, also good for me
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
