Old Feb 16, 2012, 03:44 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I dislike 2-handed Naza arming sequence with a passion. Please do not change MultiWii arming pattern, especially since throttle down+yaw is like standard arming process for just about every FC out there.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Feb 16, 2012, 04:50 AM
spudandretti is offline
Find More Posts by spudandretti
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
Originally Posted by SGsoar View Post
reason for what? contributing information?
No, I was wondering if you knew something new I didn't know. I don't flip through a lot of other threads. I use to be under the impression to only use one hot and thought I missed something somewhere.
spudandretti is offline Find More Posts by spudandretti
Old Feb 16, 2012, 06:02 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Don't worry. I won't barge into your house and re-flash your Multiwii boards. :P
I just want to know if it's possible and it could be good for me.
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 16, 2012, 06:53 AM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
look for this code fragment in the main file
Code:
      } else if ( (rcData[YAW] < MINCHECK || rcData[ROLL] < MINCHECK)  && armed == 1) {
        if (rcDelayCommand == 20) armed = 0; // rcDelayCommand = 20 => 20x20ms = 0.4s = time to wait for a specific RC command to be acknowledged
      } else if ( (rcData[YAW] > MAXCHECK || rcData[ROLL] > MAXCHECK) && rcData[PITCH] < MAXCHECK && armed == 0 && calibratingG == 0 && calibratedACC == 1) {
        if (rcDelayCommand == 20) {
          armed = 1;
change
Code:
to
Code:
rcData[YAW] < MINCHECK && rcData[ROLL] < MINCHECK
and change
Code:
to
Code:
rcData[YAW] > MAXCHECK && rcData[ROLL] > MAXCHECK
it should cause
- disarm to need both yaw left and roll left
- arm to need both yaw right and roll right
disclaimer: i did not test this change
noobee is offline Find More Posts by noobee
Old Feb 16, 2012, 10:01 AM
golfhaha is offline
Find More Posts by golfhaha
Joined Jul 2010
I already set up new tx but still found problem as vdo
http://youtu.be/R0zRtXE1MsA
Blue LED blink when arm but motor do not start and when move trot up then motor start but not for all
min trot = 1100
golfhaha is offline Find More Posts by golfhaha
Old Feb 16, 2012, 10:02 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Any way to change the arming sequence to something like this? Throttle low, full rudder left/right, full aileron left/right. Like on the Naza.
It's much safer, I've accidentally armed the quad one or two times. At the time I was wearing thick winter clothes so the prop didn't do anything. Still, that's a much safer way of arming it I think. (I was panicking a bit, this was after the quad flipped, I picked it up, motors were shrieking and I fumbled a bit with the transmitter and re-armed the quad while I had my foot on the center plate.)
There is an option so that the motors will stop (when armed) if the throttle is low. This is what I prefer. The down side is if you throttle down to zero in flight the motors may not restart properly; especially if you are dropping altitude quickly and they are rotating backwards.
leadfeather is offline Find More Posts by leadfeather
Old Feb 16, 2012, 10:03 AM
madushan2008 is offline
Find More Posts by madushan2008
sri lanka
Joined Nov 2010
i received the Crius Multiwii Lite FC before 3 weeks.
when i put the multiwii 1.9 codes it did not work properly.even in the gyro mode it vobble. when i change the PID settings it works fine.but when i switched to level mode it drifted everywhere like wild elephant.after altering some codes later now it works well.
quadcopter ACRO & LEVEL mode test (goodluckbuy Crius Multiwii Lite FC ) (5 min 5 sec)
madushan
madushan2008 is offline Find More Posts by madushan2008
Old Feb 16, 2012, 10:53 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
my board is missing in postage in process getting refund from goodluckbuy will be buying from ebay or just give up totally with this board :banghead:
skellator is offline Find More Posts by skellator
Old Feb 16, 2012, 03:37 PM
Gazzas_86 is offline
Find More Posts by Gazzas_86
United Kingdom, England, Portsmouth
Joined Dec 2011
Evening folks,
Finally managed to get power to my board tonight via the FTDI & laptop whoop!
Havn't used battery power yet but first things first as they say
Had problems installing FTDI drivers, the 0023 didn't work and i had to use V1.0 for it to work,
Anyhow opened multiwii config, selected com port and away we go,
I've calibrated ACC and MAG, however all inputs seem to max out at 70%,i.e. throttle, pitch etc,
Heres some screenshots of the config...
I only viewed the Multiwii youtube video for beginners 5 mins before so im no pro at changing the min max values, could someone tell me the to change the values..
Cheers folks
Gaz
Gazzas_86 is offline Find More Posts by Gazzas_86
Thepasty is offline
Find More Posts by Thepasty
Fly fast, Dont crash.
Thepasty's Avatar
Cornwall, UK
Joined Sep 2006
hey guys
i got a small hexa going with the crius board, hover is stable as a rock but as I increase forward speed it pitches up... any thoughts?
I've tweaked a few things and searched alot but cant get shot of it.
cheers
steve
Thepasty is offline Find More Posts by Thepasty
Old Feb 16, 2012, 04:35 PM
NICO38 is offline
Find More Posts by NICO38
Joined Dec 2011
Need to cut the red wire in three of them ?
Hi,
I ordered the CRIUS SE board
And i have a this esc :
Description:
and this Lipo :
Description:
Do I still need to cut the red wire in three of four esc
My Quadricoptere make 2.6 lb (1.2 kg) with all.
I would like to buy this 10x4.5" EPP1045 Counter Rotating Propellers :
http://cgi.ebay.fr/4-Pairs-10x4-5-Co...item2a0f6a4418
Is there ok for my four motors
Description:
Thanks a lot.
NICO38 is offline Find More Posts by NICO38
Old Feb 16, 2012, 05:50 PM
Phalanx-0 is offline
Find More Posts by Phalanx-0
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
See this link to calculate the propellor you need for your weight /motor combination.
http://adamone.rchomepage.com/calc_motor.htm
You only NEED power from 1 esc to power the flight controller board. Yes, disconnect the red wire from the other 3 esc's.
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Feb 16, 2012, 06:31 PM
welcome99 is offline
Find More Posts by welcome99
Deutschland, HE
Joined May 2010
Do I still need to cut the red wire in three of four esc ?
the Red Brick ESC has a switched BEC (not linear), so you have to cut the red wire on 3 of the 4 ESC`s
welcome
welcome99 is offline Find More Posts by welcome99
Old Feb 16, 2012, 07:00 PM
Olympian is offline
Find More Posts by Olympian
United States, AL, Huntsville
Joined Dec 2007
Compass is tilt compensated
Originally Posted by Olympian View Post
I have noticed that, on my board, the compass does not appear to be tilt compensated.
Is it supposed to be tilt compensated, in version 1.9 ???
I scanned the code briefly and didn't find any math that appeared to be doing a heading compensation.... but I may have missed it.
Olympian
I still haven't found the code, but learned that you have to calibrate the compass by rotating AND TILTING... and writing!
So now it functions as I would expect of a tilt compensated compass!
So it is tilt compensated.... if you follow the procedures!
Olympian is offline Find More Posts by Olympian
Old Feb 16, 2012, 07:27 PM
Winging it >
Joined May 2006
welcome
Instead of cutting the red wire, I lift the little plastic flap from the connector and pull the red wire out of the connector. I then put a little heat shrink or tape on the red wire end. This way I can reinsert the red wire if the esc goes on a different project.
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 08:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 09:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 10:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 11:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 07:53 AM
