Old Feb 08, 2012, 08:44 PM
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
erazotropa has posted here.
http://www.rcgroups.com/forums/showp...&postcount=456
Satoru
Originally Posted by ceandre View Post
Where I can get MWC 1.9 with Crius code?
ssatoru is offline Find More Posts by ssatoru
Old Feb 08, 2012, 11:40 PM
Expert Crasher
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Originally Posted by scousethief View Post
Sorry to hear that m8 , thats why i love paypal
Report problem......... no remedy / replacement product after 40 days.... BANG! PAYPAL dispute , no arguments no excuses straight to a dispute.
that what im going to do will be waiting another 2 week no news im filing a dispute with paypal, even my adlx345 ordered from ebay already arrive and it was ordered 2 week after the crius board :banghead:
skellator is offline Find More Posts by skellator
Old Feb 08, 2012, 11:45 PM
Joined Jul 2010
Originally Posted by ssatoru View Post
ceandre is offline Find More Posts by ceandre
Old Feb 09, 2012, 11:05 AM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Here's another video of this board and the F450 frame in action. I'm testing Gemfan 8x4.5 props on it, they handle better in the wind but the thrust is not quite as good as the 10" APC props I used earlier. It climbs nowhere near as good at full throttle, but that might have been the weather, it was -10° C today so I need to test these again later. Most of the wobble is gone too, hooray!
F450 with Crius AIO - Another flight across the ice (6 min 34 sec)
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 09, 2012, 11:41 AM
United Kingdom, England, Redcar
Joined Jan 2006
Might just be delayed , Chinese new year etc , but still , dont listen to the retailer , send them an email telling the date of purchase etc etc and then at 40 days launch a paypal dispute , no messing around.
Its probably stuck in the post somewhere and i know these guys offer excellent prices and free/cheap shipping but your only concern is to get your item or to get your money back , like i said its probably stuck in the post which is no ones fault really but, youve paid so thats just tough luck.
I received batteries the other day that had been floating around Chinese post for the best part of 2 years lol.
scousethief is online now Find More Posts by scousethief
Old Feb 09, 2012, 07:09 PM
Expert Crasher
Joined Nov 2011
2 year? wow that what I call epic delay haha im filing a dispute on day 40 if there did not want to refund
Old Feb 10, 2012, 01:10 AM
Soupbones's Avatar
Australia
Joined May 2011
Ok guys. I have a question related to an issue I am having with the throttle. Since I have been tweaking this Crius board, I have noticed the throttle range is not real great. I have the end points set as far as they can go, and the board set up correctly, having the throttle centred at 1500 roughly. All seems good. But if I go to kick the throttle in to power the quad to gain serious altitude it just doesn't have the guts for some reason.
I suspect this is a board issue because before I had the Crius on this frame I had a Gaui 3444 FC and it would charge off into the sky no issues. Which brings me to my next question.
For the Gaui344 FC You had to set your throttle range from -100 to +80, and leave the extra 20% for the controller and extra thrust. Should you do something similar for this Crius FC as well?
I am about to reset my ESCs as this is the last thing I can think off. I mean sometimes the quad goes up OK, but seems to loose serious altitude for no reason as well. This is with the barometer off totally.
Does anyone have any thoughts on why this may be happening?
Soupbones is offline Find More Posts by Soupbones
Old Feb 10, 2012, 05:31 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Guys, I'm frustrated and could use a hand.
I picked up a micro quad and can't get it set up with my Spektrum transmitter and receiver. It's a DX-7 and a6100e rx.
Flight controller: MWC MultiWii SE Standard Edition 4-axis Flight Control Board QUADX w/ FTDI Basic Breakout
4 Turnigy plush 10A escs
4 10g 2000kV motors.
I've downloaded the wii 1.9 and ran it. I've set the rates on the transmitter up, set the escs individually for throttle range.
I can't get the ESCs to stop beeping when everything is hooked back up to the flight controller. It sounds like the throttle is too high and they won't arm. Can anyone bail me out, I can't figure this out.
Joe 1320 is offline Find More Posts by Joe 1320
Old Feb 10, 2012, 06:27 PM
Australia, QLD, Brisbane
Joined Nov 2011
Throttle is probably too high, plug each ESC one by one into the receiver throttle channel and calibrate the ESC throttle range. You can change your throttle endpoints on the DX7 to let the throttle have a wider range. You can also recompile the Miniwii firmware and set minimum throttle.
Erknie is offline Find More Posts by Erknie
Old Feb 10, 2012, 06:50 PM
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by Erknie View Post
Throttle is probably too high, plug each ESC one by one into the receiver throttle channel and calibrate the ESC throttle range. You can change your throttle endpoints on the DX7 to let the throttle have a wider range. .
I've done that multiple times and most times the eill simply beep when hooked to the flight controller.
This last time, I dedid everything and hooked up to the FC and the escs all stopped beeping (armed?) but none of the sticks including throttle have any effect.
How does one set minimum throttle?
Old Feb 10, 2012, 08:57 PM
mamba max1's Avatar
United States, NC, Durham
Joined Jun 2010
I am well versed in lipo/bushless tech, but these control boards are totally new to me. My goal is to get an x525 frame. But not sure what board to get. I want to get a multi wii so that I have have the self center mode on until I get used to it. After that, I will switch the mode off.
Now I have a few other questions. (if you don't mind me asking!)
Can somebody please tell me what the difference is between these boards?
#1 http://www.goodluckbuy.com/mwc-multi...breakout-.html
#2 http://www.goodluckbuy.com/mwc-multi...ard-quadx.html
#3 http://www.goodluckbuy.com/mwc-multi...breakout-.html
#4 http://www.goodluckbuy.com/mwc-multi...ard-quadx.html
#5 http://www.goodluckbuy.com/multiwiic...er-board-.html
And I noticed these looked way different:
#6 http://www.goodluckbuy.com/mwc-multi...opter-red.html
#7 http://www.goodluckbuy.com/mwc-multi...uadcopter.html
And finally, what are these?
#8 http://www.goodluckbuy.com/mwc-multi...er-module.html
#9 http://www.goodluckbuy.com/ftdi-basi...i-lite-se.html
THANKS so much!!!!!!
mamba max1 is offline Find More Posts by mamba max1
Old Feb 10, 2012, 10:24 PM
Joined Aug 2007
your links dont work... but all multiwii boards are pretty much the same just from different manufacturers. some of them have built in usb and some need an ftdi adapter to hook to a computer.
the "lite" board is gyro and acc only. no baro or mag. but it still flies great
SGsoar is offline Find More Posts by SGsoar
Old Feb 11, 2012, 12:07 AM
mamba max1's Avatar
Joined Jun 2010
oops, didn't realize that happened! I'm basically going to use one of these boards on my x525 quad. I'm looking for one that has an auto-level feature that can be later turned off once I get used to it.
Sorry!
#2 http://www.goodluckbuy.com/mwc-multi...breakout-.html
#3 http://www.goodluckbuy.com/mwc-multi...uadcopter.html
#4 http://www.goodluckbuy.com/mwc-multi...opter-red.html
#6 http://www.goodluckbuy.com/ftdi-basi...i-lite-se.html
#7 http://www.goodluckbuy.com/mwc-multi...er-module.html
Old Feb 11, 2012, 02:24 AM
Expert Crasher
Joined Nov 2011
Sorry!
1 - 5 are the same thing with diffrent packages and addons
6 - usb serial ttl that is used for gui and uploading firmware also commonly used by arduino to upkoad sketch
7 - diffrent type of mwc fc
so 1 - 5 is the combination with 6 and ohers stuff, like SGsoar said lite version is board only with gyro and acc w/o mag and baro,
i recommend not to buy from goodluckbuy better try ebay i ordered mine from glb still havent recieve them yet after month i ordered another one from ebay last week and already got it yesterday!
Old Feb 11, 2012, 02:40 AM
Joined Nov 2011
If it's armed the motors will all be spinning with the throttle full off.
These are not Crius specific issues you are raising, it's common to most boards with the Multiwii firmware, however If you read this thread from the start, all these things have been answered before, and this thread is way shorter than the Multiwii ones!
New Product Full Foxtech AIO Glasses Review Guizmo12 Video Piloting (FPV/RPV) 1214 Today 11:01 AM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman Video Piloting (FPV/RPV) 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
