Old Feb 07, 2012, 03:17 AM
Soupbones is offline
Find More Posts by Soupbones
Soupbones's Avatar
Australia
Joined May 2011
OK. Was wondering what happens if you set the P to high?? apparently you are suppose to get wobble, then you back it down, but I still don't have this, just lack of altitude. Motors still lift off, but it goes up a bit then down again. Al other controls seem to work. This is without sensors activated too. Put them back down a bit and it get a bit better lift off. Maybe the D settings are to high.
I think I have some more tweaking to do. Got new frame coming soon, something a bit smaller and lighter. Will see how that goes with the Crius.
Soupbones is offline Find More Posts by Soupbones
Old Feb 07, 2012, 03:39 AM
bignose13 is online now
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
Heres another FPV flight from Sunday, stabilization turned off throughout the flight
be warned though, nothing happens in the video, except i score a goal towards the end, loving this board though big time
00000001 restored (7 min 54 sec)
And Enjoy
bignose13 is online now Find More Posts by bignose13
Old Feb 07, 2012, 07:46 AM
Zombee is offline
Find More Posts by Zombee
Joined Jan 2011
Originally Posted by scousethief View Post
@zombee
Nope what you gave us was
3 top left
9 top right
10 b right
11 b left
which is wrong , now you can argue what you like but you started off giving us the wrong information , fact, end of that bit.
Now
If the GUI is giving you random readouts onscreen then i suggest you first reinstall all drivers and then use Arduino 0023 to upload the Crius 1.9g which is available to download from this thread. Do not connect the motors or battery and instead run the Crius board and Receiver via the power from the FTDI, you do not need the esc's or motors to be connected nor the battery.
IF you still have random numbers , then disconnect the receiver and just run the board connected to the FTDI, that will rule out your TX and RX.
IF you are still having random numbers in the GUI then i would suggest that either your Crius board is faulty or your PC or FTDI, change to another PC or FTDI and start again.
its not actually random numbers, its just it wasnt the same as before. but anyway i would try those, it when i arm the board then put the thorttle 100% all left motors will gradually decrease from 1990-1500,
i think it would help if you guys share the PID values since mine got messed up.
im using a 500mm quad 20a esc 1000kv motors,(thought that would help)
Zombee is offline Find More Posts by Zombee
Old Feb 07, 2012, 07:50 AM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
one way to reset the pid parameters is to load and run an older version of the firmware and reload and rerun the newer version again. the firmware will reset the parameters in the eeprom to default when it detects a version change.
noobee is offline Find More Posts by noobee
Old Feb 07, 2012, 08:06 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
One set of PiD numbers would not neccessarily work with another quad in exactly the same way.
As noobee said using Arduino 0023 upload an earlier version of the software such as 1.7 and then upload version 1.9 this will reset all parameters to stock settings.
scousethief is offline Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Feb 07, 2012, 12:56 PM
Soupbones's Avatar
Australia
Joined May 2011
True, but seeing peoples PID settings gives you a better starting point as well as something different to try. As long as you have some idea on the size of their quad as well, it makes for a good reference point for testing your settings.
Old Feb 07, 2012, 01:23 PM
Joined Jan 2006
Of course , but, the best starting place is usually stock settings as its better to learn your own machine and how it works from the ground up rather than copy what someone else has done and end up even more lost because you dont know which section to adjust.
Old Feb 07, 2012, 06:16 PM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
This. You don't "try" different PID's, you tune them using the default values as a starting point. It takes a while to learn, yes. It's worth it....
Scotth72 is offline Find More Posts by Scotth72
Old Feb 08, 2012, 02:01 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
goodluckbuy is killing me it almost 4 week i haven't receive my crius board yet
skellator is offline Find More Posts by skellator
Old Feb 08, 2012, 06:05 AM
rifki_bewe is offline
Find More Posts by rifki_bewe
Joined Feb 2011
did the shipped? if not
just contact them with your registered email.
rifki_bewe is offline Find More Posts by rifki_bewe
Old Feb 08, 2012, 06:50 AM
9W2DLR
Joined Nov 2011
status shipped but since no tracking i dont really know where the packages now been wating for almost a month now
Old Feb 08, 2012, 07:24 AM
Atx_Heli is offline
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
GoogLuck Buy.....good luck bucko!
great prices!.....horrible customer support....beware:
I received my CRIUS MultiWii SE board in 3.5weeks....but it died in the first hour of operation....being a retired EE I know this sometimes happens with any electronic device....its called "infant mortality"....about a 500 parts per million occurance(unless treated to a "burn-in" at elevated temp for 24hrs)....but it happens...most reputable companies understand and will replace the device..they may want to examine it first to be sure the user did not overstress it (revesre polarity or too high a battery voltage)...no big deal, but they will at least look at it and then issue an RMA
so I email them for an RMA number....wait two weeks , no responses....email them again and warn them that I will post to forums such as this their lack of responsiveness and unwillingness to stand behind their sales...no response...
so if anyone buys from them, just beaware that you are gambling....admittedly, a fairly good gamble, but a gamble nontheless that you are throwing your money away....
at least if you buy from Ebay or Amazon, you have some kind of recourse...
CAVEAT EMPTOR
Atx_Heli is offline Find More Posts by Atx_Heli
Old Feb 08, 2012, 07:42 AM
9W2DLR
Joined Nov 2011
CAVEAT EMPTOR
i aware of that hopefully my gamble paid off amazon wont ship to my country so no luck there i havent checked any crius board on ebay seller yet i guess next time better off with ebay
Old Feb 08, 2012, 09:57 AM
Joined Jan 2006
Sorry to hear that m8 , thats why i love paypal
Report problem......... no remedy / replacement product after 40 days.... BANG! PAYPAL dispute , no arguments no excuses straight to a dispute.
Old Feb 08, 2012, 01:58 PM
ceandre is offline
Find More Posts by ceandre
Joined Jul 2010
Where I can get MWC 1.9 with Crius code?
ceandre is offline Find More Posts by ceandre
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
