Old Jan 09, 2012, 03:52 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Good test. I'm gonna have a look at the props and whatnot later. I haven't actually balanced the motors or the props. People say that Tiger motors are good, so I figured I wouldn't have to balance the motors. People also say that APC props are good, so I didn't balance those either. I'll have a look at both later and see what can be done. The quad is certainly flyable but I'm sure GoPro footage wouldn't look good with all that wobble. I'll record a movie later and post it here.
What exactly is "TRUSTED_ACCZ" anyway? Is it disabled by default?
WiseDuck is offline Find More Posts by WiseDuck
Old Jan 09, 2012, 07:24 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Alrighty, have a random video. Still wobbles a bit, haven't fiddled with the settings or balanced anything. Just figured I'd test it outside for a bit. I also tested the barometer, it looked alright at first but then it started to overcorrect to the point where it would eventually hit the ground. So right now it doesn't work in an emergency at all, it WILL oscillate up and down until the movement is so large it'll crash. I have NO idea how to tune the barometer. Any ideas?
http://www.youtube.com/watch?v=-OqylcjOEDY
My settings:
Old Jan 09, 2012, 09:26 AM
alteskind is offline
Find More Posts by alteskind
Deutschland, Schleswig-Holstein, Kiel
Joined Jan 2011
Originally Posted by Erknie View Post
As I mentioned above, it's not specific to the ADXL345 it also effects most popular accelerometers, BMA020, BMA180 see this thread for a serious discussion http://www.multiwii.com/forum/viewtopic.php?f=8&t=849
the adxl345 is far more sensitive to vibrations than the bma020.
i tested both with my new quad - with absolute same setup. some little vibrations due cf2822 motors.
with adxl345 there is no chance of stable hover, GUI shows in ACC pitch + ACC roll fluctuating between +50 and -50 , somtetimes up to 100.....
the copter "levels" to that wrong measure .....
with bma020 fluctuates between + 10 and -10, hovers stable and levelled.
imho its better to buy a bma020 for 5 euro extra, and get rid of that vibration-dampening this way.
the mentioned gaui propsavers are great, but they are 5 euro each, and dont help in case of cheap vibrating motors, or after the first little crash with slightly bend motor shaft....
the bma doesnt care that much about vibrations.
maybe, if there are too much vibrations, it may drift, but i did nt have that ACC drift issue with my (bma020)-copters.
the adxl345 is a very nice sensor, but its not quite good usable in vibrating environment.
i recommend to change the ACC of crius lite to bma020 breakout, instead of permanently trying to get rid of vibrations.
my copters fly well even without balancing props or motors. why should i use a sensor, which forces me to buy very expensive vibrationless motors + balancing every prop, if i can get a working ACC breakout for 5 euro?
who cares the 2 gram extra weight....
alteskind is offline Find More Posts by alteskind
Old Jan 09, 2012, 09:30 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Where do you get this acc breakout? And how do you connect it to the board? (Which pins, what changes need to be made in the code etc.) Does the SE version of the Crius board use the same ADXL345 accelerometer? I get a lot of wobble, tuning hasn't changed the stability much but maybe I'm doing something wrong. It works well enough for flying, but it would be real nice to be able to take off into a perfectly level and stable hover.
Old Jan 09, 2012, 09:52 AM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
I have read that using the TRUSTED_ACC, will disable the MAG and altititude!
read: http://www.multiwii.com/forum/viewto...=8&t=849#p5027
erazotropa is offline Find More Posts by erazotropa
Old Jan 09, 2012, 10:11 AM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
se
ATMEGA328P microcontroller
ITG3205 three-axis digital gyroscope
BMA180 triaxial accelerometer
BMP085 pressure sensor
HMC5883L axis magnetoresistive sensor (electronic compass)
doesnt look like it
scousethief is online now Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Jan 09, 2012, 10:32 AM
Joined Jan 2011
hm, thats not the words there.....
"3) With not TRUSTED_ACCZ you cannot use MAG and Alt. Hold"
does this mean, u have to use trusted ACC if u want to use mag/baro hold? it will depend on....... http://www.multiwii.com/forum/viewto...t=562&start=40
Old Jan 09, 2012, 10:43 AM
Joined Jan 2011
the SE version has bma180,
if your copter flies stable in acro mode , then the wobbles are ACC made.
the breakout can be bought from member "kinderkram", flyduino.net, viacopter.eu and some others. for germans its cheapest to buy from ELV due low shipping price + less resaler charge
the breakout can be put to the free space on the lite board, and connected to the dedicated connectors on the lite board (GND, 5V, SDA,SCL)
in sketch just comment the adxl345, and uncomment the bma020
u ll find connection shematic there
http://www.rcgroups.com/forums/attac...mentid=3668704
Old Jan 09, 2012, 02:30 PM
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Well if you read it that way
Old Jan 09, 2012, 02:53 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Accelerometers are meant to detect movement, it's their job, vibration is movement.
So let me get this right, instead of balancing your Tiger motors and APC props to get rid of unwanted vibrations, you are going to the effort of changing the accelerometer. Do you realize that the ADXL345 g range can be programmed for less sensitivity than the BMA020? 16g vs 8g Perhaps you should read the data sheets for both.
Erknie is offline Find More Posts by Erknie
Old Jan 09, 2012, 02:58 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I'm not changing it. And how is the sensitivity programmed? (The SE version uses BMA180 accelerometers) I suppose I could try to balance everything tomorrow, but my methods are crude at best and the parts are supposed to be at least above average. Before I balance anything I'm gonna have another look at the settings.
Old Jan 09, 2012, 03:01 PM
Joined Jan 2011
some motors, as cf2822, are vibrators. there is nothing u can do than change motors to (more expensive) smooth motors.
i am very interested in trying to make the adxl345 less sensitive.
but i dont know how, i didnt find an answer although i searchred...
what has to be changed in sketch? could u give me a hint?
Old Jan 09, 2012, 03:09 PM
Erknie is offline
Joined Nov 2011
There are many ACC parameters you can adjust, please read this thread, it is now the 3rd time I have posted it.
Old Jan 09, 2012, 03:15 PM
Atx_Heli is online now
Find More Posts by Atx_Heli
Austin, TX
Joined Jan 2009
per this response http://www.multiwii.com/forum/viewto...start=20#p6694, if you do not have TRUSTED_ACCZ, then the altitude hold loop still works BUT only uses the BARO data and not the Z-VEL data in the loop to hold altitude..(VEL is inner loop and ALT is outer loop....like LEVEL is outer loop while GYROS are the inner loops in stable mode)....so if your ACC-Z data is noisy when the motors run, you have to disable (this is the default in the code) TRUSTED_ACCZ...if its not, you can enable it to help stop vertical movement...then the VEL P&D terms have effect (note that only ALT P & I terms have effect in V1.9)
note that its been observed that the VEL loop has some bugs....several people are working on the code right now....in addition, there seems to be imminent improvements in the stable mode (LEVEL) by some config code changes to the ACC sensor operation to reduce vibration effects which create drift, by increasing the allowable measuring range of the sensors (8G instead of 2G)...you could try some of the development branches to see them if you like to experiment...I'll just wait myself
Atx_Heli is online now Find More Posts by Atx_Heli
Old Jan 09, 2012, 03:16 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Yeahhh... No. I don't know. I see chunks of code there. I'll just paste it somewhere and see what happens I guess. I'm no programmer.
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
