Old Dec 08, 2011, 04:16 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
n3m1s1s, are you saying a new (smaller) board is coming out soon?
SGsoar is offline Find More Posts by SGsoar
Old Dec 08, 2011, 04:31 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
YEP thats exactly what im saying, imagine a cc sized board with gyro acc baro and mag on board
MULTIWII 1.9 How to tune an Accelerometer and balance props the easy way N3M1S1S (8 min 58 sec)
that might help you imagine see the simcard? the dt700? the keychain cam? vado hd? see the size of the board? see whats on it? see what is coming?
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Dec 08, 2011, 08:09 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
http://www.youtube.com/watch?v=80nUT...w&feature=plcp
I like the feature where you can simply cut power to the sensors and use the board as an Arduino Pro mini. Best of both worlds, good for testing.
Erknie is offline Find More Posts by Erknie
Old Dec 09, 2011, 06:37 AM
leprud is offline
Find More Posts by leprud
Trying to learn.
leprud's Avatar
Moscow, Russia
Joined Jun 2010
Hah. goodluckbuy are totally in copters
MUCH cheaper boards, than on ebay.
Damn.
leprud is offline Find More Posts by leprud
Old Dec 09, 2011, 06:49 AM
abriosi is offline
Find More Posts by abriosi
abriosi's Avatar
Portugal, Setúbal, Palmela
Joined Jul 2011
lol im just waiting for someone to post a review on this board so i can buy one
abriosi is offline Find More Posts by abriosi
Old Dec 09, 2011, 09:27 AM
Katch is offline
Find More Posts by Katch
FC flux'd
Katch's Avatar
Joined Jan 2007
Damn.
$37 and $63! bargin!
Katch is offline Find More Posts by Katch
Old Dec 09, 2011, 09:32 AM
edwin3162 is offline
Find More Posts by edwin3162
Joined Sep 2007
Luckily I didn't place my order two days ago from GLB, now can add this board(lite lightweight version) to my cart . I've paid my very first board(standard multiwii) for SGD $185(USD $143) locally . So imo $38 is too cheap to be true I'm well prepare for "you hit or you miss ". I'll test it on BambuCopter Mini Quad or GLB MK Multicopter Mini Quad-Rotor Multi Friber Glass Folding Frame 400mm once all stuffs ready.
P.S. if any experienced pilot can suggest me which size motor/prop/esc combo for 400mm frame(big thks in advance ).
Regards,
Edwin.K
edwin3162 is offline Find More Posts by edwin3162
Old Dec 09, 2011, 11:22 AM
himagain is offline
Find More Posts by himagain
himagain's Avatar
United Kingdom, South York
Joined Aug 2002
Mine's arrived
Got mine today in the UK. Ordered it 6 days ago from force hobby.
Looks a nice little unit, loaded with 1.9... off to the shed to plug it in
I'll let you all know
himagain is offline Find More Posts by himagain
Old Dec 09, 2011, 11:42 AM
abriosi is offline
abriosi's Avatar
Joined Jul 2011
put a video with everything on (with press sensor, mag gyro and acc) i mean if it doenst give you much trouble
Old Dec 09, 2011, 01:34 PM
Katch is offline
FC flux'd
Katch's Avatar
Joined Jan 2007
would like to see it in the GUI cycle times and graph response.
vids vids vids
Old Dec 09, 2011, 01:54 PM
SGsoar is offline
Joined Aug 2007
Himagain, did you get the "SE" standard board or "lite" gyro+acc only?
looking forward to your response and vids just like everyone else
Old Dec 10, 2011, 05:44 AM
spudandretti is offline
Find More Posts by spudandretti
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
Got one for you here? Ordered one (lite) in tri version but might want to use it on a quad instead now. Wondering when downloading 1.9 would I define gyro (ITG3200) and acc (ADXL345) seperately in the config section and have the 12c pullups defined, plus 12c speed as 400? My assumption would be to define promini too?This is what I get for trying something new. Thanks, Bud.
spudandretti is offline Find More Posts by spudandretti
Old Dec 10, 2011, 06:30 AM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
i ordered one full version yesterday..
do you have an idea what i need define in the gui?
i think i have define this
· ATMEGA328P microcontroller
· ITG3205 three-axis digital gyroscope
· BMA180 triaxial accelerometer
· BMP085 pressure sensor
· HMC5883
but what about pullup or llc?
titeuf007 is offline Find More Posts by titeuf007
Old Dec 10, 2011, 07:34 AM
n3m1s1s is offline
Joined Feb 2007
· HMC5883
mine is setup like this
/* Set the minimum throttle command sent to the ESC  (Electronic Speed Controller)
   This is the minimum value that allow motors to  run at a idle speed  */
//#define MINTHROTTLE 1300 // for Turnigy Plush ESCs 10A
#define MINTHROTTLE 1120 // for Super Simple ESCs 10A
//#define MINTHROTTLE 1220
//#define MINTHROTTLE 1150
/* The type of multicopter */
//#define GIMBAL
//#define BI
//#define TRI
//#define QUADP
#define QUADX
//#define Y4
//#define Y6
//#define HEX6
//#define HEX6X
//#define OCTOX8
//#define OCTOFLATP
//#define OCTOFLATX
//#define FLYING_WING //experimental
#define YAW_DIRECTION 1 // if you want to reverse the yaw correction direction
//#define YAW_DIRECTION -1
//#define I2C_SPEED 100000L     //100kHz normal mode, this value must be used for a  genuine WMP
#define I2C_SPEED 400000L   //400kHz fast mode, it works only with some WMP clones
//enable internal I2C pull ups
#define INTERNAL_I2C_PULLUPS
//****** advanced users settings   *************
/* This option should be uncommented if ACC Z is ac curate enough when motors are running*/
//#define TRUSTED_ACCZ
/* PIN A0 and A1 instead of PIN D5 & D6 for 6 motor s config and promini config
   This mod allow the use of a standard receiver o n a pro mini
   (no need to use a PPM sum receiver)
//#define A0_A1_PIN_HEX
/* possibility to use PIN8 or PIN12 as the AUX2 RC  input
   it deactivates in this case the POWER PIN (pin  12) or the BUZZER PIN (pin 8)
//#define RCAUXPIN8
//#define RCAUXPIN12
/* This option is here if you want to use the old l evel code from the verison 1.7
   It's just to have some feedback. This will be r emoved in the future */
//#define STAB_OLD_17
/* GPS
   only available on MEGA boards (this might be po ssible on 328 based boards in the future)
   if enabled, define here the Arduino Serial port  number and the UART speed
   note: only the RX PIN is used, the GPS is not c onfigured by multiwii
   the GPS must be configured to output NMEA sente nces (which is generally the default conf for most  GPS devices)
//#define GPS
//#define GPS_SERIAL Serial3 // should be Serial2 for flyduino v2
//#define GPS_BAUD   4800
//#define GPS_BAUD   9600
/* Pseudo-derivative conrtroller for level mode (experimenta l)
   Additional information: http://www.multiwii.com/forum/viewto...p?f=8&t=503 */
//#define LEVEL_PDF
/* introduce a deadband around the stick center
   Must be greater than zero, comment if you dont  want a deadband on roll, pitch and yaw */
//#define DEADBAND 6
/* if you use a specific sensor board:
   please submit any correction to this list.
     Note from Alex: I only own some boards
                     for other boards, I'm not sur e, the info was gathered via rc forums, be cautiou s */
//#define FFIMUv1         // first 9DOF+baro board from Jussi, with HMC5843                    <- confirmed by Alex
//#define FFIMUv2         // second version of 9DOF+baro board from Jussi, wit h HMC5883       <- confirmed by Alex
//#define FREEIMUv1       // v0.1 & v0.2 & v0.3 version of 9DOF board from Fab io
//#define FREEIMUv03      // FreeIMU v0.3 and v0.3.1
//#define FREEIMUv035     // FreeIMU v0.3.5 no baro
//#define FREEIMUv035_MS  // FreeIMU v0.3.5_MS                                                 <- confirmed by Alex
//#define FREEIMUv035_BMP // FreeIMU v0.3.5_BMP
//#define PIPO            // 9DOF board from erazz
//#define QUADRINO        // full FC board 9DOF+baro board from witespy  with  BMP085 baro     <- confirmed by Alex
//#define QUADRINO_ZOOM   // full FC board 9DOF+baro board from witespy  secon d edition       <- confirmed by Alex
//#define ALLINONE        // full FC board or standalone 9DOF+baro board from  CSG_EU
//#define AEROQUADSHIELDv2
//#define ATAVRSBIN1      // Atmel 9DOF (Contribution by EOSBandi). requires 3 .3V power.
//#define SIRIUS          // Sirius Navigator IMU                                              <- confirmed by Alex
//#define SIRIUS600       // Sirius Navigator IMU  using the WMP for the gyro
//#define MINIWII         // Jussi's MiniWii Flight Controller
//#define CITRUSv1_0      // CITRUSv1 from qcrc.ca
//#define DROTEK_IMU10DOF
//if you use independent sensors
//leave it commented it you already checked a specif ic board above
/* I2C gyroscope */
#define ITG3200
//#define L3G4200D
/* I2C accelerometer */
//#define ADXL345
//#define BMA020
#define BMA180
//#define NUNCHACK  // if you want to use the nunckuk as a standalone I2 C ACC without WMP
//#define LIS3LV02
//#define LSM303DLx_ACC
/* I2C barometer */
#define BMP085
//#define MS561101BA
/* I2C magnetometer */
//#define HMC5843
#define HMC5883
//#define AK8975
/* ADC accelerometer */ // for 5DOF from sparkfun, uses analog PIN A1/A2/A3
//#define ADCACC
/* ITG3200 & ITG3205 Low pass filter setting. In ca se you cannot eliminate all vibrations to the Gyro , you can try
   to decrease the LPF frequency, only one step pe r try. As soon as twitching gone, stick with that  setting.
   It will not help on feedback wobbles, so change  only when copter is randomly twiching and all dam pening and
   balancing options ran out. Uncomment only one o ption!
   IMPORTANT! Change low pass filter setting chang es PID behaviour, so retune your PID's after chang ing LPF.*/
//#define ITG3200_LPF_256HZ     // This is the default setting, no need to uncomment , just for reference
//#define ITG3200_LPF_188HZ
//#define ITG3200_LPF_98HZ
//#define ITG3200_LPF_42HZ
//#define ITG3200_LPF_20HZ
//#define ITG3200_LPF_10HZ      // Use this only in extreme cases, rather change mot ors and/or props
/* The following lines apply only for specific rece iver with only one PPM sum signal, on digital PIN  2
   IF YOUR RECEIVER IS NOT CONCERNED, DON'T UNCOMM ENT ANYTHING. Note this is mandatory for a Y6 setu p on a promini
   Select the right line depending on your radio b rand. Feel free to modify the order in your PPM or der is different */
//#define SERIAL_SUM_PPM         PITCH,YAW,THROTTLE, ROLL,AUX1,AUX2,CAMPITCH,CAMROLL //For Graupner/Spektrum
#define SERIAL_SUM_PPM         ROLL,PITCH,THROTTLE ,YAW,AUX1,AUX2,CAMPITCH,CAMROLL //For Robe/Hitec/Futaba
//#define SERIAL_SUM_PPM         PITCH,ROLL,THROTTLE ,YAW,AUX1,AUX2,CAMPITCH,CAMROLL //For some Hitec/Sanwa/Others
Old Dec 10, 2011, 08:06 AM
Rensselaer,IN
Joined Jan 2003
what do you have defined in def.h? promini which I assume would define
ATMEGA328P?
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
