Old Feb 06, 2013, 12:13 PM
MrDeath is offline
Find More Posts by MrDeath
Moldova, Chisinau
Joined Oct 2012
Originally Posted by helizrnew2me View Post
ok, you might have a vibration problem causing that .enable the 42hz low pass filters and then try again .assuming you calibrated the esc`s right?
aaaaa no, how to do that ?
sorry for noob question
this way ?
http://www.multiwii.com/wiki/index.p...SC_Calibration
MrDeath is offline Find More Posts by MrDeath
Old Feb 06, 2013, 12:21 PM
helizrnew2me is offline
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
wait ...before we go farther lets be clear . when you say it auto increases speed by itself do you mean during flight?
or you mean the motors turn on when you arm the copter?
helizrnew2me is offline Find More Posts by helizrnew2me
Old Feb 06, 2013, 12:22 PM
Joined Sep 2010
this way ?
yes thats the correct way
Old Feb 06, 2013, 12:30 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
my steps:
1.turn of from battery
2. arm
3. move up throttle stick for low rpm,
motors spins let say at 1300 rpm, after some seconds it increase rpms let say 1350, and again, after some seconds it increase to 1400 ... and so on ... but I don't touch stick in that moment.
Old Feb 06, 2013, 12:32 PM
Ackroyd is offline
Find More Posts by Ackroyd
Joined Sep 2011
here is how its connected http://www.imagehosting.cz/?v=hpim7217.jpg and here i made a video about whats happening :-)
CRIUS PROBLEM.AVI (0 min 42 sec)
Ackroyd is offline Find More Posts by Ackroyd
Old Feb 06, 2013, 12:34 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
my steps:
2. arm
Does it only happen on the ground? Does it cause a flip?
brontide is offline Find More Posts by brontide
Old Feb 06, 2013, 12:42 PM
Joined Sep 2010
let me add to that
have you gotten it off the ground yet?into a hover?
Old Feb 06, 2013, 12:56 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
no, now i just adjust it, never fly
Old Feb 06, 2013, 12:59 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
yes, but not durng fly but without props
Old Feb 06, 2013, 01:00 PM
Joined Sep 2010
well it could still be getting too much vibration .and if thats the case you would need to enable the low pass filters .
hovering it would help me know .a board thats getting vibrations will hover badly ,have the jitters and the motors could speed up n down .
do you know how to load a new sketch??
Old Feb 06, 2013, 01:02 PM
brontide is offline
Joined Sep 2012
You may be witnessing "integral windup" where the controller is doing it's job and increasing motor speed in response to a persistent error ( slight tilt on the ground ). Easiest way to see is tilt it even more, is the speedup clearly on the down side and accelerates faster the more tilt you have?
http://en.wikipedia.org/wiki/Integral_windup
If it does it in a random direction, yes, you probably need the LPF and to better balance your props if you have not done so already.
Old Feb 06, 2013, 01:05 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
do you mean firmware ?
Old Feb 06, 2013, 01:18 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
May be this screen will exaplain
http://ialex.info/01.jpg
http://ialex.info/02.jpg
Old Feb 06, 2013, 01:51 PM
Joined Sep 2010
the links dont work ,but yes do you know how to load the firmware to the board?
if so you need to enable the low pass filters .
start with 42hz like in this shot below
/* ITG3200 & ITG3205 Low pass filter setting. In case you cannot eliminate all vibrations to the Gyro, you can try
to decrease the LPF frequency, only one step per try. As soon as twitching gone, stick with that setting.
It will not help on feedback wobbles, so change only when copter is randomly twiching and all dampening and
balancing options ran out. Uncomment only one option!
IMPORTANT! Change low pass filter setting changes PID behaviour, so retune your PID's after changing LPF.*/
//#define ITG3200_LPF_256HZ // This is the default setting, no need to uncomment, just for reference
//#define ITG3200_LPF_188HZ
//#define ITG3200_LPF_98HZ
#define ITG3200_LPF_42HZ
//#define ITG3200_LPF_20HZ
//#define ITG3200_LPF_10HZ // Use this only in extreme cases, rather change motors and/or props
/* MPU6050 Low pass filter setting. In case you cannot eliminate all vibrations to the Gyro, you can try
//#define MPU6050_LPF_256HZ // This is the default setting, no need to uncomment, just for reference
//#define MPU6050_LPF_188HZ
//#define MPU6050_LPF_98HZ
#define MPU6050_LPF_42HZ
//#define MPU6050_LPF_20HZ
//#define MPU6050_LPF_10HZ // Use this only in extreme cases, rather change motors and/or props
you can see where i removed the hash marks to enable these .
if this doesnt help then you may have other issues .you should really try to hover it and see whats going on with it .do it over tall grass at low height in case you crash.
Old Feb 06, 2013, 02:02 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
Yes I know how to flash it.
But I have a question, - seems my Gyro don;t work, or not enabled in code, when I'm trying to turn my copter, sensors doesn't react, also I'm getting i2c error, ...
may be I;m not flashing in right mode ?
I flash with Arduino nano w/ATmega 328, compile an upload work, but gyro not.
http://s019.radikal.ru/i642/1302/01/9d6c709b19de.jpg
http://s019.radikal.ru/i612/1302/a8/28d01c1d3cff.jpg
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
