Old Jan 13, 2013, 11:44 AM
helizrnew2me is online now
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
here you go .i only have 6 channels so i just use level and baro .
my compass is off again .it should be showing north right now .
helizrnew2me is online now Find More Posts by helizrnew2me
Old Jan 13, 2013, 12:29 PM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Ok, with those settings, yaw should be just fine. Can you test again, and if its still misbehaving, try to shoot a video?
TS00 is offline Find More Posts by TS00
Old Jan 13, 2013, 12:32 PM
Joined Sep 2010
maybe its just me .this is coming out a pirouette,how often will i be doing that with a video rig?
cant do no testing today ,light misty rain all day so far .
hey ..whats up with my compass?if i load a fresh copy of 2.0 then upload my sketch it usually straightens out .
i read somewhere that if you open your port and try to hit read too fast you can wipe your settings .maybe i done that and thats why my compass is off now .
that only comes into play if you enable mag right?
Old Jan 13, 2013, 12:33 PM
Flying By is offline
Find More Posts by Flying By
Canada, MB
Joined Feb 2012
Even with 6 channels you can program 2 or 3 way switches to give you a few more options. I have the DX6i and have set up 2 3-way switches.
Flying By is offline Find More Posts by Flying By
Old Jan 13, 2013, 12:41 PM
clough42 is offline
Find More Posts by clough42
Director of Esoteric Projects
clough42's Avatar
Joined May 2012
Can you explain briefly how you did that? I have set up two two-position switches (flight mode and landing gear). How do you get the third position values?
clough42 is offline Find More Posts by clough42
Old Jan 13, 2013, 12:46 PM
Canada, MB
Joined Feb 2012
You need to set up mixes and then can get low, mid, high settings by using a combination of switches. You do use 2 switches to get all 3 positions, but it does allow a few additional options. (same as using the DX6i to have 3 position flaps).
I used this as a guide: http://diydrones.com/forum/topics/dx...-mix-for-modes
I had to play around with the mix settings a bit to get the proper low, mid and high values to register.
Old Jan 14, 2013, 10:24 AM
Canada, MB
Joined Feb 2012
Camera stabilization servos
Is is okay to connect the tilt/roll servos To be powered directly through the Crius SE board or should they be powered by a UBEC instead and only connect the signal wire to the RC board?
I am also looking for instructions on how to use a 3 position switch to control the tilt of the camera manually (using aux 1 or 2) instead of the auto stabilization control. ie. 3 different tilt positions depending on the switch position. Is this possible? I am using a 6 ch system.
If I change the tilt_pitch_aux_ch aux3 to aux2 will that give my tilt the manual control on the 6 ch radio? Although that would affect other options set in the GUI.
Old Jan 15, 2013, 11:08 AM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Originally Posted by TS00 View Post
It's odd that you're getting an overshoot then.
Set the yaw values as: P:8.5 I:0 D:0
Turn off the mag.
Let us know what happens.
I have the same issue. It only does it when yawing to the left though. After centering the stick, it will continue to yaw another 1/4 turn or so. In a hover, it also drifts in yaw to the left. I have tried many different PID settings and have just tried your suggestion here with the same results. Have also upgraded from 1.9 to 2.0 and now 2.1. If I figure it out, I will post results. If anyone has suggestions, I would love to experiment.
boardman is offline Find More Posts by boardman
Old Jan 15, 2013, 02:02 PM
Gordon2 is offline
Find More Posts by Gordon2
Joined Nov 2012
Looking for opinions on how well the barometer will function inside this case with holes. As you can see there are good size openings in the case for the pins and wires; so do you think that this case, with a just a little foam on the baro chip, will work OK????
Will the airflow be sufficient to allow the baro chip to respond quickly?
BTW, the case is a Nintendo cartridge case, used here to help protect the board and to provide a mounting surface to anti-vibration gel (instead of applying it directly to the board). It is hinged to allow access and will have removable stand-offs inside the case to prevent movement.
Update 26 Jan: Well this didn't work out physically (to allow access to ports mostly) so I wont be trying it and wont know if the baro is affected or not.
Gordon2 is offline Find More Posts by Gordon2
Old Jan 15, 2013, 02:21 PM
Joined Sep 2010
excellent reuse of product .but i am thinking it should have an opening above the baro sensor ,the baro should still have some foam over it but it needs to have access to open air .thats my thought.
Old Jan 15, 2013, 02:26 PM
Gordon2 is offline
Joined Nov 2012
Thanks for you input.. I wonder if you (or anyone) has done any testing with air access restricted, and open just over the sensor, and open to the sides at a little distance? I would like to avoid propwash with a opening right at the baro chip but at the same time I need to make sure the pressure changes are not restricted. This way smaller foam (really just enough to block light and not restrict air at all) might work well. Keep the comments coming!.
Old Jan 15, 2013, 05:37 PM
asynchronous is offline
Find More Posts by asynchronous
Joined Jan 2013
please connecting help with the HK MultiWii SE V2.0 controller
asynchronous is offline Find More Posts by asynchronous
Old Jan 16, 2013, 11:58 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I think you're going to need to provide some detail about the exact problem you're experiencing before anyone can help. As much info as possible.
Old Jan 18, 2013, 07:52 AM
jonesy40001 is offline
Find More Posts by jonesy40001
jonesy40001's Avatar
Australia, QLD, Meadowbrook
Joined Sep 2012
The biggest problem with the Baro is it is too sensitive, it needs to be in order to give us the accuracy we want. Even the slightest breez over the sensor will give a reading, Sit the board on your desk while it is connected to the GUI and very very and I mean very gently blow over it and watch the change on the readout, remember they are easly damaged by blowing directly onto them. Most experts recomend placing some breathable foam rubber (like air filter or pillowfoam) over the sensor to help dampen the output. there is also a FW fix to smooth it as well, think its r1240_dev. It made a world of difference to my SE board.
Hope this helps.
Pete.
jonesy40001 is offline Find More Posts by jonesy40001
Old Jan 19, 2013, 01:59 PM
Osprey Engineer is offline
Find More Posts by Osprey Engineer
Osprey Engineer's Avatar
Philadelphia, PA
Joined Oct 2005
How to connect lights
Anyone know how to control LED strip lights with the Crius Multiwii SE?
I got these lights from Hobbyking and would like to control them (on/off) with a switch on my transmitter.
http://www.hobbyking.com/hobbyking/s...0mm_Blue_.html
Osprey Engineer is offline Find More Posts by Osprey Engineer
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
