Old Dec 24, 2012, 07:34 AM
QUENAZ is offline
Find More Posts by QUENAZ
Brazil, São Paulo, São José dos Campos
Joined Aug 2012
I agree with Satoru! Try to set #define CRIUS_SE in config.h
Good luck!
Originally Posted by ssatoru View Post
Looks like Gregco10 uses this board. Same set of sensors as Crius SE 0.2/1.0 but I do not think this board has ready oto use definition in 2.1. I would try to set #define CRIUS_SE in config.h and check sensor direction following here.
http://www.multiwii.com/faq#How_shou...xis_directions
Satoru
QUENAZ is offline Find More Posts by QUENAZ
Old Dec 24, 2012, 12:05 PM
Gregco10 is online now
Find More Posts by Gregco10
Gregco10's Avatar
Joined Jun 2012
Thanks all for the fast responses, as soon as I get some time to work with it I'll let you know how it goes. All I can say is that my Crius se, out of the box with the suggested pid's in v2.1, that tri is rock solid. It took alot of time sorting the pid's to get the quad to fly well with the red board. I'm hoping for the same results after flashing.
Gregco10 is online now Find More Posts by Gregco10
Old Dec 27, 2012, 10:43 AM
Gregco10's Avatar
Joined Jun 2012
It's nice!!! Just re-flashed the board with v2.1, defined quad x and Crius SE. Panicked a little when I hooked up the 2.1 config, the little quadcopter diagram in the bottom right corner looked like just a line with some flap things on it, an accelerometer cal. cured that readily, it was just on its side, whew! Checked the radio was still in spec, re-attached the props, did an indoor test hover. Hovers great with gyros and auto level, very very slight twitch on auto level, nothing that cant be tuned out. Very happy with it so far can't wait to get it outside, the weather is not very cooperative in the winter.
Do have a question though, the 1.9 had a vel setting which trimmed how the throttle responded, v 2.1 seems to have deleted this, how is the throttle tuned now?
Old Dec 28, 2012, 07:22 AM
QUENAZ is offline
Joined Aug 2012
I have configured the throttle curve on my TX but you can do it using GUI.
See it below in red (throttle: mid / expo)
Old Dec 28, 2012, 09:09 AM
Gregco10's Avatar
Joined Jun 2012
Ok, thanks. That is much simpler than the old way.
Old Dec 28, 2012, 12:26 PM
tasospap is offline
Find More Posts by tasospap
Joined Feb 2009
Hi i like to conect crius se with mobidrone osd and a Feiyu 100A Current Sensor set for AP117 OSD Display .Have anybody a schematic how to do that ?
tasospap is offline Find More Posts by tasospap
Old Dec 28, 2012, 06:27 PM
QUENAZ is offline
Joined Aug 2012
You might see about it at http://www.rcgroups.com/forums/showthread.php?t=1595826
Old Dec 29, 2012, 02:38 PM
QUENAZ is offline
Joined Aug 2012
Hexacopter
Finally I finished my Hexacopter with Crius MultiWii SE + I2C GPS UBLOX (without I2C errors).
RC Groups Team,
Thanks for all! Thank you, guys!!!
Old Dec 30, 2012, 09:33 AM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Nice machine! Congrats on getting everything working right. I am going to tackle the demons on mine now that my Christmas company is gone.
boardman is offline Find More Posts by boardman
Old Dec 31, 2012, 03:11 PM
QUENAZ is offline
Joined Aug 2012
Thank you!
I'll make a video soon.
Happy new year, guys!
Old Dec 31, 2012, 08:10 PM
notlkk is offline
Find More Posts by notlkk
Joined Oct 2012
How to Trim Acc
I just received my Multiwii SE v2.1 board and started configuring it. After calibrating acc I notice that motors output are not in sync (Please see the attached pic).
How do I trim the acc in this case? Thanks.
notlkk is offline Find More Posts by notlkk
Old Dec 31, 2012, 09:13 PM
Flying By is offline
Find More Posts by Flying By
Canada, MB
Joined Feb 2012
Did you calibrate each esc individually?
Flying By is offline Find More Posts by Flying By
Old Jan 01, 2013, 01:20 AM
notlkk is offline
Joined Oct 2012
No, I didn't. Should I calibrate those ESCs?
Old Jan 01, 2013, 08:09 AM
Canada, MB
Joined Feb 2012
Yes. Best to do each one on its own.
Old Jan 01, 2013, 03:23 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Or use 3 servo 'Y' cables and do all 4 together
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
