Old Dec 03, 2012, 09:55 PM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Hi QUENAZ,
Good to hear PPM converter installation went smooth and another congratulations!
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Dec 04, 2012, 08:46 AM
bozo bozok is offline
Find More Posts by bozo bozok
Joined Sep 2009
satoru san o henji arigatou gozaimasu
watashi crius aıo pro motte imasu..gps mo arimasu ga return to homu to iu koto o dekinakattan desu..naze wakaranai kedo kono mono wa anmari yokunai ka naaa..
bozo bozok is offline Find More Posts by bozo bozok
Old Dec 04, 2012, 09:37 AM
bc2801 is offline
Find More Posts by bc2801
Joined Oct 2012
ublox flashing
i can not thank you guys enought for all your help. i have follow the instructions. but im having some difficulties getting it to flash the ublox.
can anyone post please a picture of the wire connection ready for flashing the ublox.
im not sure if im supposed to connect the ublox directly to the usb or if im supposed to used the connection on the control board call UART.
im confuse please i need help on that.
im almost there
bc2801 is offline Find More Posts by bc2801
Old Dec 05, 2012, 06:44 AM
ssatoru is offline
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Hi bozo bozok-san,
amari yakuni tatenakute gomennasai. I do not have experience in GPS connected to Pro board. I have only have worked on GPS connected through I2C to ATmega 328 board. Configuration was tough, and PID tuning took loong time. (Completed position hold only after 2 month, not yet on return to home.)
With your Pro board, you have more options to try GPS. MultiWii or Mega Pirate I read. I am sure you can get more info there.
Satoru
Old Dec 05, 2012, 02:36 PM
QUENAZ is offline
Find More Posts by QUENAZ
Brazil, São Paulo, São José dos Campos
Joined Aug 2012
im almost there
Hi!
Pay attention how you must connect a UBLOX GPS using FTDI.
GPS FTDI
RX ------------> TX
TX ------------> RX
5V -------------> 5V
GND ----------> GND
UBLOX GPS v1 (with battery) - file: ublox-config.ublox.txt
UBLOX GPS v2 (with eeprom) - file: u-config-v2.txt
Follow this instructions: http://www.rcgroups.com/forums/showthread.php?t=1724694
Good luck!
QUENAZ is offline Find More Posts by QUENAZ
Old Dec 05, 2012, 03:11 PM
bc2801 is offline
Joined Oct 2012
Originally Posted by QUENAZ View Post
Hi!
GPS FTDI
RX ------------> TX
TX ------------> RX
GND ----------> GND
Good luck!
quenaz thank you for that info. im going to try that tonight.
so let me ask you something i connect the ublox directly to the usb. i dont used the board right ?
Old Dec 05, 2012, 03:12 PM
bc2801 is offline
Joined Oct 2012
ok u said using the FTDI im looking to see what that is heheehe
ok im using this cable just like you see it on this picture.
http://i00.i.aliimg.com/wsphoto/v3/5...ware-PRGMR.jpg
and im connecting them directly to the ublox right?
Old Dec 05, 2012, 04:33 PM
QUENAZ is offline
Joined Aug 2012
Ublox flashing
You'll use this cable + FTDI to GPS flashing.
Don't forget...follow this instructions: http://www.rcgroups.com/forums/showthread.php?t=1724694
Yes! You must connect them directly to the Ublox GPS (not I2C board).
GPS <====> FTDI
RX ------------> TX
TX ------------> RX
GND ----------> GND
Enjoy it!
Old Dec 05, 2012, 05:46 PM
bc2801 is offline
Joined Oct 2012
ok quenaz thanks i will try tonight
Old Dec 05, 2012, 07:18 PM
bc2801 is offline
Joined Oct 2012
ok quenaz im in the process of following the direction but im getting this error while im trying to upload using the arduino
avrdude: stk500_getsync(): not in sync: resp=0x18
Old Dec 05, 2012, 07:19 PM
bc2801 is offline
Joined Oct 2012
under tools-> board . what board should i used i think that is my issue but im not sure of the setting .. ?
Old Dec 05, 2012, 08:06 PM
bc2801 is offline
Joined Oct 2012
mmmm something interesting just happen. i was not able to do none of the steps that it was recomended on the link . but when i connected the gps to the usb cable and then i started the program ublox. the gps started to work. i was able to see the coordinates etc.
so is working.
the only problem is that is working under 38400 and i don know if i can used that . on the multiwii 2.1 settings. ?
Old Dec 06, 2012, 04:25 AM
QUENAZ is offline
Joined Aug 2012
Use ARDUINO NANO W/ ATMEGA 328 to I2C board flashing and ARDUINO PRO OR PRO MINI (5V 16MHz) W/ ATMEGA 328 to Multiwii flashing.
Old Dec 06, 2012, 04:38 AM
QUENAZ is offline
Joined Aug 2012
so is working.
Both GPS version works well.
I uploaded a file (I2C board). Download and configure it: http://www.4shared.com/rar/yYaWO71l/...012__OK_.html?
Old Dec 06, 2012, 02:44 PM
bc2801 is offline
Joined Oct 2012
ok quenaz ill give it a shot and get back to you buddy ok
thanks
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
