Old Nov 14, 2012, 10:52 AM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Hello all , i have decided to try again with my quad using the Crius Se board , i also have a Crius GPS CN-06 along with the Crius I2C GPS NAV Module.
Ok , so , i know my SE board works fine , the other bits i am unsure of but i will work through it.
Can anybody point me in the right direction for the latest software for the Crius, and any links or information on basic setup for the GPS , any help would be gratefully accepted.
TY
Scouse
scousethief is online now Find More Posts by scousethief
Old Nov 14, 2012, 11:08 AM
MrDeath is offline
Find More Posts by MrDeath
Moldova, Chisinau
Joined Oct 2012
firmware here > http://code.google.com/p/multiwii/downloads/list
MrDeath is offline Find More Posts by MrDeath
Old Nov 14, 2012, 11:23 AM
ulkar is offline
Find More Posts by ulkar
Discovery
ulkar's Avatar
Joined Apr 2012
GPS here : http://www.rcgroups.com/forums/showthread.php?t=1724694
ulkar is offline Find More Posts by ulkar
Old Nov 14, 2012, 11:35 AM
Joined Jan 2006
TY , downloaded the dev version (2.1 just kept erroring) i will read up on the GPS.
Thanks again
Scouse
Old Nov 14, 2012, 06:47 PM
helizrnew2me is offline
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
Originally Posted by e_lm_70 View Post
I don't think it is needed ...
But ... you want to calibrate them (to have all with same level) ... simonk ESC FW, learn min and max signal once you power them up with full throttle signal
thanks ......i was thinking more in the terms of min throttle as they say simonk`s should have 1064 on throttle in the sketch .not sure what mine is .
but they do spin fast enough when armed just thought i might wanna have the correct value .
helizrnew2me is offline Find More Posts by helizrnew2me
Old Nov 15, 2012, 02:14 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
I don't use this option on my quad ... I don't like spinning motor as soon as the quad is armed ... anyhow ... default value is just fine
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 17, 2012, 11:51 AM
QUENAZ is offline
Find More Posts by QUENAZ
Brazil, São Paulo, São José dos Campos
Joined Aug 2012
Hi guys! I´m here again...
I need a help...I have a Futaba 7C FASST 2.4Ghz (TX) + R617FS (RX) ->> not PPM signal.
I´m building a Hexacopter with Crius MultiWii SE...I was trying to configure it but I can't.
Someone helps me, please?
or
if someone is selling 'OMM RX Converter R3' ...contact me!
Thanks!
QUENAZ is offline Find More Posts by QUENAZ
Old Nov 17, 2012, 03:00 PM
Polleke is online now
Find More Posts by Polleke
Nederland, Noord-Brabant, Steenbergen
Joined Feb 2011
MultiWii_dev_r1240 CAM STAB problem
Hi all,
I switched from MultiWii 2.0 to MultiWii_dev_r1240.
Very nice ALT HOLD behavior……… but now my Cam Stab isn’t working properly anymore.
However it worked well in the 2.0 version.
I uncommented following lines in the config.h:
#define GIMBAL (commend or uncomment, makes no difference)
#define SERVO_MIX_TILT (commend or uncomment, makes no difference)
#define SERVO_TILT (commend or uncomment, makes no difference)
I’ve turned on Cam Stab in the GUI.
The servo’s jitter and the roll(function) servo goes all in one corner.
What am I doing wrong???
Polleke is online now Find More Posts by Polleke
Old Nov 17, 2012, 03:51 PM
QUENAZ is offline
Joined Aug 2012
Originally Posted by Polleke View Post
Hi all,
#define GIMBAL (commend of uncomment, makes no difference)
#define SERVO_MIX_TILT (commend of uncomment, makes no difference)
#define SERVO_TILT (commend of uncomment, makes no difference)
1) Just uncomment #define SERVO_TILT ...compile 'n upload
2) Active Cam Stab in the GUI interface
...and be happy!!
Old Nov 18, 2012, 02:49 AM
Joined Feb 2011
...and be happy!!
Hello Quenaz,
Like i told in my post:
"#define SERVO_TILT (commend or uncomment, makes no difference)"
"I’ve turned on Cam Stab in the GUI."
Like I did in version 2.0
BUT.......... no luck
Old Nov 18, 2012, 06:49 AM
QUENAZ is offline
Joined Aug 2012
Hello Quenaz,
I'll use the same source code and I'll see what I do to resolve this problem for you.
Old Nov 18, 2012, 12:17 PM
QUENAZ is offline
Joined Aug 2012
Solved!!!
Hello Quenaz,
Hi Polleke!!!
It´s simple!!
1) You should comment these lines:
/*********************** Cam Stabilisation ***********************/
//#define TILT_PITCH_AUX_CH AUX3
//#define TILT_ROLL_AUX_CH AUX4
2) Compile 'n Upload
3) Configure in the GUI interface.
Enjoy it.
Old Nov 18, 2012, 01:33 PM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Hello. Will it be safe to cover the entire circuit board with epoxy for protection?
GTiDonavan is offline Find More Posts by GTiDonavan
Old Nov 18, 2012, 03:52 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
Crashed
Quadro Copter Crash (1 min 30 sec)
5-fly, First crash ....
Old Nov 18, 2012, 04:08 PM
QUENAZ is offline
Joined Aug 2012
Hi guys!
I built a Hexacopter and I need to use PPM SUM signal output. So I bought a FrSky TFR4 to solve my problem with FUTABA 7C 2.4Ghz FASST.
How can I connect a FrSky TFR4 receiver on MWC Crius MultiWii ?
Has anyone done this?
Thanks, guys!
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
