Old Nov 13, 2012, 03:15 AM
MrDeath is offline
Find More Posts by MrDeath
Moldova, Chisinau
Joined Oct 2012
PLC77 Thx I will try
BTW e_lm_70 i'm waiting for you photos of your board with leds
MrDeath is offline Find More Posts by MrDeath
Old Nov 13, 2012, 04:24 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Here you are ... I did connect on A0
You can also so my GPS directly connected to the serial interface
For activate this led I did use:
#define MY_LED_SWITCH PORTC ^= 1<<0
#define MY_LED_ON PORTC &= ~(1<<0)
#define MY_LED_OFF PORTC |= 1<<0
void initMyLed()
pinMode(A0,OUTPUT); // TILT_PITCH - WING left
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 13, 2012, 04:42 AM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
Nice, Did you used only 1 led ? I want to put 4 leds, one for each motor. Is this possible ?
btw, recommend please some props, Now I have 1650rpm/V motor (170W) and now I have GWS 10x4.7 propellers this is goo choice ?
Old Nov 13, 2012, 04:57 AM
e_lm_70 is offline
Austria
Joined Jan 2004
4 leds per motor
What do you want to do ?
Map the motor power into led around the quad for visibility ?
Have an additional LED for some signalling ?
As you can see ... my quad has also visibility led ... in two colors ... for orientation and eventually night flight ... plus ... 1 LED (actually 2 in series for power reason) for give me 1 additional signal ...
MultiWii Board has only 1 led for signalling .. that means: ON = armed, OFF = not armed .. quite a little for my taste
EDIT: Prop and motor is looking good for a "standard" 500mm quad ... I guess you plan to use a 2200mAh 3S Lipo ... or something similar
Old Nov 13, 2012, 05:13 AM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
Not 4 per motor but 1 per motor, I want to make this for night flight and I don;t know where/how to connect leds.
My Frame is 680mm , 170W Motor, Battery is 2,2A 3S Lipo like you said, and propellers is 10x4.7 I want to buy more but on hobby king its in backorder so I'm searching for alternatives for goog propellers
Old Nov 13, 2012, 06:07 AM
e_lm_70 is offline
Austria
Joined Jan 2004
If you want just night flight ... just connect the 12v led directly to the battery ... that's it ... nothing to do with the board.
About propeller also these one are good for a quad :
http://www.hobbyking.com/hobbyking/s...tate_2pc_.html
http://www.hobbyking.com/hobbyking/s...2pc_pack_.html
I'm using the 8x4 on my 550mm quad ... but also 9x5 should be fine ... since they are 3 blade propeller, they should be consider like a 10x4 or 11x5 equivalent with 2 blades ...
Old Nov 13, 2012, 06:18 AM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
Why you don't use 2Blade ? or 3 Blade is better ?
Old Nov 13, 2012, 06:30 AM
e_lm_70 is offline
Austria
Joined Jan 2004
3 blades are more cool then 2 ... 4 will be even better for me
I did not read it any where, neither I did search or study it ... but .. my "stomach feeling" ... is telling me that more propeller should make a hovering quad more efficient ...
Anyhow ... on my quad the 8x4 do work very fine ... also using 3S Lipo ... but I use a cheap little donkey 1500kv motor : http://www.hobbyking.com/hobbyking/s...ess_Motor.html
my frame ... with 8x4 prop ... is the cheap : http://www.hobbyking.com/hobbyking/s..._Frame_V1.html (in the past was the cheapest one ... anyhow I like wood frames ... in case of crash the wood brake and no other side effect ... and just few drop of CA ... and is back fixed in no time)
If I would have to order again ... I will take this kit: http://www.hobbyking.com/hobbyking/s...dproduct=19596 ... very cheap .. and looking good
If you are not much into acrobatic fly ..
Old Nov 13, 2012, 07:59 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Something is looking wrong
To me ... is looking like you used the same type of propeller on all the motors ... you need 2 CW and 2CCW propeller
Old Nov 13, 2012, 09:45 AM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
No no is ok I just make a Photo with this propellers )) all is right in real life this is old photo
Old Nov 13, 2012, 06:21 PM
helizrnew2me is offline
Find More Posts by helizrnew2me
helizrnew2me's Avatar
United States, PA, Slatington
Joined Sep 2010
i just added simonk esc`s to my multiwii se f450 .do i need to go into sketch and define these esc`s??
helizrnew2me is offline Find More Posts by helizrnew2me
Old Nov 14, 2012, 01:56 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I don't think it is needed ...
But ... you want to calibrate them (to have all with same level) ... simonk ESC FW, learn min and max signal once you power them up with full throttle signal
Old Nov 14, 2012, 09:11 AM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
Hi all again, About ESC Calibration, I use HK ESC http://www.hobbyking.com/hobbyking/s...dProduct=13429
Must I calibrate or (reflash) them ?
Old Nov 14, 2012, 09:27 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I think you can use them as it is ... with default configuration ... so nothing to be done
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
