Old Nov 08, 2012, 11:15 AM
ulkar is offline
Find More Posts by ulkar
Discovery
ulkar's Avatar
Joined Apr 2012
Okay thanks ! I'll definitely do it once I'm all setup again, with this + the parachute thing I'm building, there's no way I'll crash again (well, in theory, and we all know theory is not a big thing in this field )
ulkar is offline Find More Posts by ulkar
Old Nov 08, 2012, 02:00 PM
Ramnes is offline
Find More Posts by Ramnes
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
Crius MW SE, Hexa and gimbal
Edit: I was right.
Ramnes is offline Find More Posts by Ramnes
Old Nov 10, 2012, 03:49 AM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Crius SE (Lite) 10k external pull up resistors
Hi,
Can someone confirm that the Crius SE (Lite) has 10K external pull up resistors (R5 & R7)? If yes, we should use comment out //#define INTERNAL_I2C_PULLUPS or #udef INTERNAL_I2C_PULLUPS
manu
alll is offline Find More Posts by alll
Old Nov 10, 2012, 04:54 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by alll View Post
Hi,
manu
My HK clone has a 1k pullup resistor
To measure it you just need to measure the resistance between sda and sdc, the value that you read is double the pull up resistance used
Anyhow board pull up or not ... it is not issue to enable also pull up also by code
So keep pull up in the code and it will works no matter what
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 10, 2012, 06:38 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
Hi, thanks for this hint,
20K between SDA-SDC of atmega pins, so 10K external pu,
6.3K between SDA-SDC of the I2C pin holes of the board.
So, i prefer to comment out the internal pull ups in config. Atmega pu are as high as 40-50K!
manu
Old Nov 10, 2012, 10:17 AM
PLC77 is offline
Find More Posts by PLC77
Splat
United States, FL, Palm Harbor
Joined Jul 2007
From the photo, it appears that the board has active I2C level conversion (the resistors and transistors in the upper left corner). That being the case the pullups are taken care of in the hardware and the value of the pullups depends on if you looking at the 5 volt (Atmel) side or the 3.3 volt (sensor) side.
PLC77 is offline Find More Posts by PLC77
Old Nov 11, 2012, 07:24 AM
alll is offline
manuLRK
Belgium
Joined Sep 2004
So, should we #udef INTERNAL_I2C_PULLUPS?
Old Nov 11, 2012, 05:03 PM
PLC77 is offline
Splat
Joined Jul 2007
I would suggest the best sellection would be to leave the pull ups commented out with the //.
Although, it is likely that either way would work. Just make sure that you don't get I2C errors.
Old Nov 12, 2012, 09:23 AM
MrDeath is offline
Find More Posts by MrDeath
Moldova, Chisinau
Joined Oct 2012
Hi guys. I have a question:
I want to connect 1 led per "hand/motor" on my quadrocopter, how can I do this ? or How can I do this better ?
From what to get power supply ?
thx in advice
MrDeath is offline Find More Posts by MrDeath
Old Nov 12, 2012, 09:27 AM
e_lm_70 is offline
Austria
Joined Jan 2004
thx in advice
So ... you want to have 1 extra Led signal on your board ????
I did on mine ... for give me a better sign when GPS lock is completed ...
If this what you need I can tell you how I did it
Old Nov 12, 2012, 12:28 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
What Board do you use? if MultiWii than please show me the right road to do this
Old Nov 12, 2012, 01:14 PM
e_lm_70 is offline
Austria
Joined Jan 2004
I have the cirus clone from HK .. same as cirus, just 1 chip difference ...
Anyhow, I'm using one pin from the line of servo output ... and I have led between 5v and the servo signal pin
At code level ... alk you need to do it is to set this pin as output, and then define to set to 0 for switch on the led, or to 1 for keep it on
Check that your led is not consuming more then 1mA ... else you can overheat or damage the cpu
Tomorrow I can post a photo of my board with led
Old Nov 12, 2012, 01:28 PM
MrDeath is offline
Moldova, Chisinau
Joined Oct 2012
ok thx, I;m still waiting my FTDI from ebay ((
btw can i flash it with anduino nano ?
Old Nov 12, 2012, 04:01 PM
e_lm_70 is offline
Austria
Joined Jan 2004
If you can flash your arduino nano ... you should be able to flash multiwii board to
Old Nov 12, 2012, 05:46 PM
PLC77 is offline
Splat
Joined Jul 2007
Mr Death,
you can flash your board with the adapter you have if you just wire it up the way you did to get it working with the multiwii config program. just use Arduino1.0.1 and pick the comm port that you used with the other program. it should work fine but you may need to wire the reset pin to get it to load.
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
