Old Jul 21, 2012, 10:00 PM
little nellie is offline
Find More Posts by little nellie
Joined Mar 2012
Originally Posted by TS00 View Post
That is an AIO board, like I have.
I think you need to do some debugging on your serial to i2c converter, to confirm that it is actually outputting data. Do you have a spare arduino to play with?
No, this is the only board I have... should I order another converter or an arduino board? I am not a programmer...
little nellie is offline Find More Posts by little nellie
Old Jul 21, 2012, 10:55 PM
MuddyWulf is offline
Find More Posts by MuddyWulf
United States, CA, Riverside
Joined Mar 2012
Originally Posted by Wasp09 View Post
You should be able to if the battery is 3S unless the whole thing is way overweight. If the battery is 2S, you may need bigger props.
Did you find your battery or connectors hot? Can you get one of those power connection boards and shorten the cables?
Got it figured!!! Messing around in the gui, I increased throttle pid to .89. That got it up off the ground!! This is what I did " " Now I have to get it stable.
Thanks A bunch TS00 and Wasp!! now on to the next challenge.
MuddyWulf is offline Find More Posts by MuddyWulf
Old Jul 22, 2012, 02:13 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Glad to hear it's flying :-) Just for the curious, which of the PID values did you increase to 0.89? (there are three values per axis)
TS00 is offline Find More Posts by TS00
Old Jul 22, 2012, 02:14 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I wouldn't bother with another board if you don't think you'll be able to write some code to debug it.
I'm going to look around for some specific info on the Crius i2c board, see what problems people have had. Sorry I can't help with more info right now.
Old Jul 22, 2012, 11:17 AM
TigerPilot is offline
Find More Posts by TigerPilot
Joined Jan 2005
I have the KK board and had programed it with the programmer that works with it.Should the GUI work with that board too? I connected it to the Crius board and the red led came on and the blue led flashed but when I click on the .exe to start the GUI it doesn't start. I can see that windows start running it for a second or two but I don't see the GUI on the screen.
TigerPilot is offline Find More Posts by TigerPilot
Old Jul 22, 2012, 08:32 PM
eyeinsky1 is offline
Find More Posts by eyeinsky1
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
I install the new Crius board in my nVader 600. With an afternoon of tweaking we took her out to the field. Winds were pretty high but she worked great.
nVader 600 2012 (3 min 9 sec)
Cheers Jerry
eyeinsky1 is offline Find More Posts by eyeinsky1
Old Jul 23, 2012, 05:31 AM
ulkar is offline
Find More Posts by ulkar
Discovery
ulkar's Avatar
Joined Apr 2012
I'm experiencing something weird with my crius se :
I can tune it pretty well so it flies stable, but when I give it full throttle it oscillates more and more until I stop giving it full throttle, if I keep doing it I suppose it's crashing but I never did.
My quad :
frame : tbs discovery
turnigy plush 30a
ntm 750kv
3s lipos
ulkar is offline Find More Posts by ulkar
Old Jul 23, 2012, 12:57 PM
wkm1 is offline
Find More Posts by wkm1
wkm1's Avatar
Joined Apr 2010
workbench for the Crius board and a gift for your girlfriend
Find a parfume (I used a 'Shiseido Zen', or find one with a similar top cap) for your wife / girlfriend and
convince her, that she does not need that huge (maybe you say *ugly*) plastic top cover of this stuff.
Keep that plastic cap! Drill 3 or 4 holes (M3) and you will have a perfect workbench for your Crius board.
The USB cable will not drag the board away anymore. Everyone will be happy ! She got a gift and you
are having a perfect stable board!
wkm1 is offline Find More Posts by wkm1
Old Jul 23, 2012, 01:34 PM
Joined Mar 2012
I got the GPS working.. DrTom from another forum pointed out where the i2c port is at for the CRIUS SE v0.2 board. Once connected to the right place, everything works....
Old Jul 23, 2012, 02:14 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I'm confused - you said earlier you had an AIO, and posted a photo of how you had it connected that showed the Crius nano board connected to an AIO board.
Old Jul 24, 2012, 07:07 AM
ulkar is offline
Discovery
ulkar's Avatar
Joined Apr 2012
My quad :
turnigy plush 30a
ntm 750kv
3s lipos
No one?
Old Jul 24, 2012, 07:51 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
No one?
What are your PID values, and what is the frame size?
Old Jul 24, 2012, 12:10 PM
needforspeed95 is offline
Find More Posts by needforspeed95
Joined May 2012
I have been having a stange issue with my computer/multiwii board. Whenever I connect the board to the computer, it works fine. But after I unplug the board, my computer will not recognize any new hardware I attach. So this means that every time I unplug the board from my computer, I need to restart it in order to connect the board again. Also, after the computer restarts, I get an error message. Has anybody else had this problem or know how to fix it? I have windows 7. Thanks.
needforspeed95 is offline Find More Posts by needforspeed95
Old Jul 24, 2012, 01:46 PM
Phalanx-0 is offline
Find More Posts by Phalanx-0
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
@need
try unplugging the usb connection from the pc. USB is supposed hot plug and play.
Poorly written drivers may not allow.
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Jul 24, 2012, 02:59 PM
C3dke is offline
Find More Posts by C3dke
Joined Jul 2012
Hi
What's in fact the difference between these 2 boards? (except the price )
http://www.goodluckbuy.com/mwc-multi...ard-quadx.html
http://www.goodluckbuy.com/crius-upg...r-v1-0-se.html
I searched through the topic but I just got to the 46th page and gave up
C3dke is offline Find More Posts by C3dke
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
