Old Jun 19, 2012, 05:38 AM
indra9110 is offline
Find More Posts by indra9110
The Netherlands, ZH, The Hague
Joined Mar 2012
PID setting on crius Multiwii SE X500 quadcopter
Hi all just wanna share my PID setting on X500
Multiwii 2.0
-Lowpass freq 42hz
-defined trust acc
-in flights calibration
Board Crius Multiwii SE from GLB
motor : 1000KV
ESC : Hobbywing 20A
Prop : 3blade 9x4.5
lipo : 2200mAh 45C flight time on stable mode about 10-12 minute with FPV gear about 7-8 minute
Roll/Pitch PID= P:3,5 I: 0,025 D:35,
Yaw: P: 7 I: 0,045 D: 0,
Level : P:7,0 0, I: 010 D:100.
Now i did the PID Tuning for the
ALT/Baro (default PID: 1,6 0,015 7) and ended up with P=0,3 I=0,001 D=1
My quad never so stable like this before
maybe can help you ..
cheers
Indra
indra9110 is offline Find More Posts by indra9110
Old Jun 19, 2012, 05:43 AM
deno6031 is offline
Find More Posts by deno6031
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
The 1000kv ones on 4s lipo with 8x4.5 props have a thrust off 900grams, they are really nice motors, I use them
deno6031 is offline Find More Posts by deno6031
Old Jun 19, 2012, 07:33 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
Thanks deno6031. I plan to buy them and replace the ultra-weak dt700s bought from HK.
Vineet
vineet_p is offline Find More Posts by vineet_p
Old Jun 19, 2012, 07:35 AM
rolin is offline
Find More Posts by rolin
Joined Jul 2011
Originally Posted by deno6031 View Post
you should try to lower the low pass freq to 42hz or similar, it changes everything, if you have vibrations it no use to change the pid settings
Thanks, mine was one step higher. Don't see much vibrations, but it's worth trying to lower the low pass setting.
rolin is offline Find More Posts by rolin
Old Jun 19, 2012, 07:40 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
I made one garbage-quad recently and it vibrates like a car-engine. I set the low-pass filter setting to the last-but-one setting!
Vineet
Old Jun 19, 2012, 07:50 AM
ulkar is offline
Find More Posts by ulkar
Discovery
ulkar's Avatar
Joined Apr 2012
I just bought this fc, had experience with an homemade wii controller but I don't get what this low-pass filter is related to?
ulkar is offline Find More Posts by ulkar
Old Jun 19, 2012, 08:15 AM
deno6031 is offline
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
It practicaly makes your fc less sensitive againts vibrations
Old Jun 19, 2012, 08:32 AM
ulkar is offline
Discovery
ulkar's Avatar
Joined Apr 2012
Ok, is that something you set through the software or something else
Old Jun 19, 2012, 08:37 AM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
Hello
How you find my T-tricopter?
stable or not?
Turnigy motor 2830 / 800kV
ESC 18A turnigy
3 blade 9/5 x 3 propeller
Drone Tricopter RC-premier-vol.MPG (4 min 32 sec)
Crius SE
-Lowpass freq 98hz
Lipo 2200 mAh flight time 13 minutes.
Flying Weight 867 gr
Sorry next time will make a video near you.
go with the version MultiWii_dev_20120606.
and change the camera
one more question please.
What was the use PASSTHRU and HEADFREE?
magik30 is offline Find More Posts by magik30
Old Jun 19, 2012, 11:43 AM
deno6031 is offline
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
it seems that you have a stable hover but it is too early to say it is perfect, you have to fly forth and back and see its reactions, that is more important
headfree is the carefree mode on the mikrocopter systems, try searching on youtube for 'multiwii carefree' you will be amazed passthru function is for the inflight accelerometer calibration(you have to enable it in the config)
Old Jun 19, 2012, 11:55 AM
rolin is offline
Joined Jul 2011
Originally Posted by vineet_p View Post
Hi rolin.
How are your NTM 2826 motors? I plan to buy the 1000kv ones and my quad will be slighly heavier than yours. Do you feel your quad is turbocharged or is the thrust just enough to lift it up?
Vineet
Too early to tell, mine hovers at 50%, but have not enough stability to feel the motor power. The motors were super smooth when I was calibrating the ESCs. It seems that the prop adapters introduced some vibration.
Old Jun 19, 2012, 12:02 PM
rolin is offline
Joined Jul 2011
Indra
Thanks. Tried these, my quad didn't liked them much.
I am starting to thing there is something else wrong. I replaced the Crius with a KK board I have laying around. Couldn't make it to fly smooth, although I followed the procedures. With both boards, the quad behaves like it's feeling ground effect even when flying 2 meters from the ground.
Could this be power related and how can I check if the motors have enough power. They seem to run smooth when I am holding the quad and give full throttle, but sometimes twitch when I am holding the quad and don't touch the sticks.
Old Jun 19, 2012, 12:08 PM
Joined Mar 2012
did you try smoothing the gyro with 42hz??
Old Jun 19, 2012, 12:12 PM
rolin is offline
Joined Jul 2011
Yes, it's set at 42Hz.
Old Jun 19, 2012, 11:23 PM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
In the sketch, there are some lines that configure the gyro directions, you must ne have them as negative inputs =D
Thanks deno. Will try that tomorrow.
boardman is offline Find More Posts by boardman
New Product Full Foxtech AIO Glasses Review Guizmo12 FPV Equipment 1362 Dec 13, 2014 07:08 PM
Sold Arduino / MultiWii / Megapirates Boards 3rdeyepro Aircraft - Electric - Multirotor (FS/W) 3 Dec 03, 2011 08:43 PM
Wanted MSR 5in1 boards and MCPX 3in boards beachflyer Aircraft - Electric - Helis (FS/W) 3 Nov 22, 2011 09:14 PM
Discussion Foxtech AIO goggles RX? Teamsherman FPV Talk 2 Oct 02, 2011 10:06 AM
Sold 3 x PCB boards for multiwii copter for $28 madushan2008 Aircraft - Electric - Multirotor (FS/W) 1 Sep 06, 2011 06:53 AM
