Old Sep 29, 2003, 02:57 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Laird Super Solution Build Thread!
OK guys the first 10 kits should be in the hands of builders at this time so thought a consolidated build thread to share ideas and answer questions along with any pics you can submit would be helpful! I will be writing a review on the plane for Bill and will also post progress pics here as I build! Thanks in advance for your input!
boomer
boomerace is offline Find More Posts by boomerace
Old Sep 29, 2003, 03:22 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Ok, a couple small issues have already been noted:
1. There's no 1/16 stringers for the bottom of the fuse sides. The 1/8" by 1/16" laser cut stringers SHOULD subsitute for the 1/16 square.
2. There's no 1/32 balsa sheeting for the kit. My bad. Straight up stupidity on my part.
3. Boxes have been ordered 32" x 6" x 6", which should allow plenty of cushion room for the kit, and anything else someone might order.
4. I hate Kinkos, and won't use them again for the blueprints. I stood there with a ruler in hand checking print size against the plan, and it still appears that the print isn't 100% to size. Again, I hate Kinkos, enough said.
I'm big enough to admit mistakes and make corrections. If you have something constructive to input about the kit, or if you feel that you deserve a partial refund for the lack of about 1.00 in balsa, let me know and I'll make right.
Bill.
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Sep 29, 2003, 03:31 PM
boomerace's Avatar
Joined Sep 2001
Bill are you saying to use the 1/8 X 1/16 instead of buying some 1/16 or am I not understanding!?
boomer
Old Sep 29, 2003, 04:20 PM
St. Louis Metro
Joined Apr 2003
Exactly. I think the 1/8 x 1/16 can be substituted on the bottom of the fuse, where it calls for 1/16.
Old Sep 29, 2003, 04:25 PM
boomerace's Avatar
Joined Sep 2001
Thanks Bill!
boomer
Old Sep 29, 2003, 05:41 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Bill, on the prints since I'm an architect I have some insight on this. When running anything on a diazo process, you're going to get some stretch in one direction (parallel to the direction of feed). Normally it's not an issue, but for something like a plane kit plan, accuracy is very important. There are a few possible solutions:
- Call around and find a print shop that has a flat bed printer. The print paper and tracing are placed flat on a table, so there's no stretch of the print. Not sure if it costs more, I don't think it does, but it might.
- Send the CADD file to the shop and have them plot it direct. Most print shops can plot right to bond, and I don't think it costs anymore than a bond copy (see below, bond copy is slightly more than a bond print).
- Run bond copies instead of prints. In this case they scan the original into memory, then shoot off how ever many copies you want. It's not a process of laying the original over the media like in diazo, so there's no stretch. Bond copies cost a little more than diazo last time I checked, but the price keeps coming down on them.
Good luck!
Tres Wright is offline Find More Posts by Tres Wright
Old Sep 29, 2003, 05:46 PM
St. Louis Metro
Joined Apr 2003
Tres,
These were printed from a DWG file that was converted to the "Kinko's File Format".
The paper was fed through a pretty large printer. I wound up using a 103% blow up of the print to get the horizontal scale correct, but come to think of it, I never did check verticle, nor is there a verticle scale to check against.
I'll try contacting several local print shops to see who has a plotter.
Thanks for the advice.
Bill
Old Sep 29, 2003, 09:18 PM
Jblk9695 is offline
Find More Posts by Jblk9695
Razor Saver Man
Jblk9695's Avatar
San Bernardino, CA
Joined Jul 2003
You will need to cut the 1/16 x 1/8 in half or make the notches in the fuse formers larger, also make sure to allow clearance for F7 or you will be cutting the 1/16 stringer back a bit, ask me how I know. Got side tracked today or I would have had most of the fuse done. Wife said I had to work on paying jobs, oh well.
Jerry
Jblk9695 is offline Find More Posts by Jblk9695
Old Sep 29, 2003, 09:34 PM
Jblk9695 is offline
Razor Saver Man
Jblk9695's Avatar
San Bernardino, CA
Joined Jul 2003
Fuse Top
Old Sep 29, 2003, 09:45 PM
Jblk9695 is offline
Razor Saver Man
Jblk9695's Avatar
San Bernardino, CA
Joined Jul 2003
Fuse top at higher res. sorry about the small one.
Old Sep 29, 2003, 09:46 PM
Jblk9695 is offline
Razor Saver Man
Jblk9695's Avatar
San Bernardino, CA
Joined Jul 2003
Fuse side
Old Sep 29, 2003, 09:51 PM
Jblk9695 is offline
Razor Saver Man
Jblk9695's Avatar
San Bernardino, CA
Joined Jul 2003
You will also need to sand a little on F9 to make the angle match up to F2 and you will need to make the slot in F2 a little longer toward the bottom, see photo. No big deal, just a little sanding and fitting.
Old Sep 29, 2003, 10:06 PM
St. Louis Metro
Joined Apr 2003
Say, I have a plane that resembles that!
Old Sep 29, 2003, 10:29 PM
boomerace's Avatar
Joined Sep 2001
Good Progress Jerry! Hopefully my kit will be here tomorrow!
boomer
Old Sep 29, 2003, 11:30 PM
St. Louis Metro
Joined Apr 2003
I just put the instruction manual up on the site, in case any of the printed pics on my Samsung laser printer didn't come out clear @ 600x600 dpi.
www.parkflyermotors.com/LairdManual.ppt
It's in MS PowerPoint, and you will probably want to do a "Right Click" and "Save As", because with all of it's pics, it's about a 14mb download.
Bill
Contest Build Off: Laird Super Solution glewis Scale Kit/Scratch Built 224 Oct 22, 2012 05:08 PM
Discussion LAird Super Solution BennyLaird Scale Kit/Scratch Built 22 Jan 24, 2007 09:57 PM
Laird Super Solution Ready for Maiden!!! boomerace Parkflyers 34 Nov 03, 2003 10:39 AM
Park Flyer Motors Presents: The Laird Super Solution WJ Birmingham Scale Kit/Scratch Built 1 Oct 29, 2003 10:07 AM
Park Flyer Motors: Laird Super Solution Bi-Plane WJ Birmingham Parkflyers 105 Sep 29, 2003 03:02 PM
