Old Dec 04, 2011, 11:20 PM
ASG29 is offline
Find More Posts by ASG29
Joined Apr 2009
Question
MXC control throws
Can someone please give me the control throws. for the ailerons, ie how much up and down.
And also what is the center/neutral position of the elevator measured vertically from the bottom of the fin to the trailing edge of the elevator.
Ross
ASG29 is offline Find More Posts by ASG29
Old Dec 05, 2011, 10:10 AM
DEAN GRADWELL is offline
Find More Posts by DEAN GRADWELL
Ross,
I'm out of town and away from my glider till Friday. If others don't get back to you I can then.
The stab pivot is not exact from glider to glider so the trailing edge measurement should be a relationship between the two.
As a starting point I have always eyeballed it from behind aligning it with the wing.
Regards Dean
DEAN GRADWELL is offline Find More Posts by DEAN GRADWELL
Old Dec 05, 2011, 01:11 PM
ASG29 is offline
Joined Apr 2009
Thanks Dean, you are a great help.
Regards
Ross
Old Dec 11, 2011, 04:51 PM
Aileron differential in degrees is 15 up and 3 down. This was settled on after dozens of test flights with a camera and yaw vane. Used right stick only and 100% rudder mixed in.
Old Jun 19, 2013, 04:49 AM
How about feedback on what I posted.
Share your CG location as well.
Regards Dean
Old Jun 19, 2013, 10:36 PM
XC soaringpilot is offline
Find More Posts by XC soaringpilot
Joined Jan 2005
Dean
My MXC cg is 120mm from leading edge of wing at wing root.
My control surface movements are:
Aileron Differential - 16 degrees up, 8 degrees down
Rudder/Aileron mix: cruise 90%, Thermal 110%, Launch 110%, Reflex 20%
MODES -Measurement in degrees
_________ Cruise _______ Reflex _____Thermal _____Launch
Flap --------------- 0 ----------------- -1 ------------ +4 ----------- +6.5
Aileron ----------- 0 ---------------- -1 ------------ +4 ----------- +5.5
Elevator --------- 0 ----------------- -3/4 ---------- +1 ------------ +2
John
XC soaringpilot is offline Find More Posts by XC soaringpilot
Question Looking for Control Throws for HF DG-505 Crash Prone Scale Sailplanes 19 Sep 20, 2011 10:43 AM
Discussion Airfield F-4 Phantom Control throws jnoetzelmann Foamy EDFs 0 Sep 09, 2011 09:03 AM
Discussion Setting throws on control surfaces? Jamcon Beginner Training Area (Aircraft-Electric) 6 May 28, 2011 06:49 PM
Question Royal Stuka Control Throws? modelmaster2001 The Builders Workshop 2 Mar 31, 2011 02:13 PM
Help! Setting Aileron Control Throws gpower77 Beginner Training Area (Fuel) 9 Mar 25, 2011 02:30 PM
