Old Dec 04, 2011, 02:56 PM
wahoo67 is offline
Find More Posts by wahoo67
Joined Oct 2011
Power Supply (Wall Wart) for HZ Champ Charger
I have a HZ champ that my son and I are having a blast with. I want to be able to use the charger at home by plugging into the wall. The charger has a DC port that says 6v DC 1.5 AMP max. I have an old 5v wall wart from a router that is 2.5 AMPs. May be a dumb question, but can I use that with the HZ charger (it fits)?
wahoo67 is offline Find More Posts by wahoo67
Old Dec 04, 2011, 10:59 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
I would say that the 1V difference eliminates the use of that second charger.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Dec 05, 2011, 06:03 AM
wahoo67 is offline
Joined Oct 2011
It's not a 2nd charger. the little charger that came with the plane runs off of 4 AA batteries. There's also a DC plug receptical on the side of the charger where you can plug it into the wall but it didn't come with the plug. You can by one for $15 but I want to know if the AD/DC power supply I have from the router can be used instead of the one they sell. Here is the one they sell:
http://www.amazon.com/AC-6VDC-1-5-Am...ref=pd_sim_t_7
Old Dec 05, 2011, 07:10 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Yes, that power supply should work on the HZ charger. I've used rechargable AA's in those types of chargers and they charge fine at the lower voltage. Some say it takes longer to charge, but I've not noticed it.
Just make sue the PS is DC and it's plug has the same polarity as the charger. Mine says center is Positive and case is Negative on the charger.
KC
KC is offline Find More Posts by KC
Old Dec 07, 2011, 08:36 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
Joined Jan 2011
I use a random motorola one I hacked up....1.2 amps, 5 volts. works fine. leave in one AA for the status LED though
Endlesslag is offline Find More Posts by Endlesslag
Old Dec 11, 2011, 05:33 PM
wahoo67 is offline
Joined Oct 2011
I tried it this weekend and left one AA battery in as suggested and it seemed to work fine. Thanks for your help!
Discussion wall wart trickle charger rcairboater Batteries and Chargers 4 Apr 07, 2011 07:00 PM
Wanted JR Transmitter power supply wall-wart n1st Aircraft - General - Radio Equipment (FS/W) 1 Dec 06, 2006 11:02 AM
Question Wall Wart to power DC charger - okay? magic612 Electric Plane Talk 9 Jun 30, 2006 02:27 PM
Using a wall wart to power a Lipo charger? rilysi Batteries and Chargers 2 Sep 21, 2004 06:39 PM
How to make your Hitec wall wart into a slow charger for your flight batts LuckyArmpit Batteries and Chargers 4 Jan 05, 2003 08:39 AM
