Old Feb 19, 2012, 04:28 PM
JDMCARPETS is offline
Find More Posts by JDMCARPETS
KING of PING!
JDMCARPETS's Avatar
United States, PA, Lancaster
Joined Nov 2008
Any news on the new container of these coming in?
JDMCARPETS is offline Find More Posts by JDMCARPETS
Old Feb 19, 2012, 05:00 PM
xsubsailor is offline
Find More Posts by xsubsailor
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
I shredded my firewall yesterday, thank God I bought a spare firewall from 3dhs when I bought the plane.
xsubsailor is offline Find More Posts by xsubsailor
Old Feb 20, 2012, 11:37 AM
jhorton is offline
Find More Posts by jhorton
jhorton's Avatar
United States, TX, Carrollton
Joined Dec 2009
Is anyone else having issues with servo blowback on the HS-65MGs elevator for this SC330? I have on two occasions been on a slightly powered downline and the model would not pull up, though I can see the input as the model does a slight attempt at the input it has been given. I am still a very new pilot and my question is do I need to not do power downline's of any kind with this model or do I need to change my setup to accommodate faster turns?
I run the 3dhs long arms with the linkage on the last hole, on the horn side I am at the second from the last hole, should i go closer in on the server arm to get more torque?
jhorton is offline Find More Posts by jhorton
Old Feb 20, 2012, 12:33 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Andy was just talking about this yesterday at the field. He is going to try an HS-81mg in the tail.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Feb 20, 2012, 12:38 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I'm using stock hs65 arms and I do wide open everything.
Full throttle, dive, level out over runway, full right aileron, full up elevator, full right rudder, 3 complete revolutions without losing any altitude.
My guess is that you could move a little closer to the servo and increase your torque while still having enough throw.
cmala is offline Find More Posts by cmala
Old Feb 20, 2012, 12:49 PM
jhorton is offline
jhorton's Avatar
Joined Dec 2009
When you get time could you post what holes you filled (horn and servo arm) on your SC330. Oh My that sounds so bad!
also are you running the extended arms?
On a side note maybe using cmala videos as learning aids was not one of my best ideas.
Old Feb 20, 2012, 01:35 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
This is how I set mine up. I just made some servo arms though so I might try to get some more throw on the ailerons. My elevator and rudder are fine with stock arms.
Old Feb 20, 2012, 01:37 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
tapatalk is driving me nutz
Old Feb 20, 2012, 04:06 PM
jamesrini is offline
Find More Posts by jamesrini
USA, NJ, West Paterson
Joined Feb 2008
i think i noticed the same thing, i only had 2 flights so far on mine so its hard to tell, but i tried doing a full throttle blender and the roll rate on the ailerons slowed down as i went faster, it rolled slower then when doing a rolling harrier. i too am using the extended servo arms, ill try moving the link closer to the servo gear and see what happens. i didnt notice anything with the elevator and i did some high speed parachutes
jamesrini is offline Find More Posts by jamesrini
Old Feb 20, 2012, 04:56 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
I love this plane! Managed to 4 flights on this bad boy yesterday (and a few on my 103") and I love it more each flight!
I put a throttle curve to smooth out the throttle response and upgraded to a 14x8.5 prop and WOW!!! it is fun!
This place just begs to be thrown around. It makes me look like a better pilot.
Too bad the wind is howling today. No flying.
Brill
Brill 1 is offline Find More Posts by Brill 1
Old Feb 20, 2012, 05:43 PM
jhorton is offline
jhorton's Avatar
Joined Dec 2009
Yep you are using the stock arms on the servo, think the 3dhs arms (1 inch /26mm ) might be the straw that broke the hs-65mg's back
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
The geometry looks good cmala with about 1:1 ratio. The length of your servo arm looks the same as from the hinge point to the hole you picked on the control arm. That should give you plenty of throw.
More throw could go longer on the servo or shorter at the surface
Less throw could go longer on the surface or shorter on the servo
HugoCraft is offline Find More Posts by HugoCraft
Old Feb 20, 2012, 05:47 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Yep you are using the stock arms on the servo, think the 3dhs arms might be the straw that broke the hs-65mg's back
You are running them at 6 volts, right?
I think mine are at 6.3v but I can't remember for sure.
It's either 6, 6.3, or 6.5 volts. I've changed my mind a couple of times for apparently no reason.
Old Feb 20, 2012, 05:58 PM
jhorton is offline
jhorton's Avatar
Joined Dec 2009
Im running 6.0 on my Castle ESC. I could bump it up I just did not know if the 65's will take more than 6 without damage. Ill look on the HiTech Site and see if I can not find what the max voltage is for these servos.
Old Feb 20, 2012, 06:04 PM
Aerobatic Fanatic
HugoCraft's Avatar
Joined Sep 2007
Well since they say 6v that means you could plug in a 6v nimh which peak at 7.5v but usually drop to 7.2v-7v after some use. I usually set them at 6.5v too since I'm scared going to 7v
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5801 Apr 28, 2016 06:32 PM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
