Old Sep 21, 2012, 05:33 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I didn't take pics when I did the 48" epp, it now has over 200 flights with the mode and never a problem with the mount, the gear has been rebent many times but is still fine. I did take pics however of basically the same mod that I did on the 40 epp, only I used two bolts on the 48".
3drcparts is offline Find More Posts by 3drcparts
Old Sep 21, 2012, 06:55 PM
DocOne is offline
Find More Posts by DocOne
Carpe Fermentum
DocOne's Avatar
United States, VA, Clifton
Joined May 2008
I guess I can accept the bending, but I'll probably reinforce the box after reading all of this.
Has anyone actually had the gear wires spread so far apart they blew out the sides of the box? A wire soldered high to both wires would prevent this, but then again almost all of the force is coming from the front and not the sides.
Also - (per earlier) thoughts on running the 13x6.5 prop with the 3S batteries? Does it give more power than the 14x7?
Doc
DocOne is offline Find More Posts by DocOne
Old Sep 21, 2012, 07:31 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
Originally Posted by Bivens View Post
I just try and land softly....and bend my gear straight as needed. No mods on mine.
land softly?!?!? "cale flying" and "soft landing" are never in the same sentence!
cale10 is offline Find More Posts by cale10
Old Sep 21, 2012, 08:42 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I did say ... "try"
Bivens is offline Find More Posts by Bivens
Old Sep 21, 2012, 09:41 PM
cale10 is offline
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
I did say ... "try"
Old Sep 21, 2012, 09:44 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
this is a very easy plane to land, come in with a tiny bit of power and cut a foot off the ground and flare. I like to say, fly it to the ground not into the ground
Old Sep 21, 2012, 09:53 PM
JDMCARPETS is offline
Find More Posts by JDMCARPETS
KING of PING!
JDMCARPETS's Avatar
United States, PA, Lancaster
Joined Nov 2008
Doc
If you are running 130 omega,14x7 has the most grunt.13x6.5 not so much
JDMCARPETS is offline Find More Posts by JDMCARPETS
Old Sep 21, 2012, 11:23 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
Hmm, it seems they are making changes on each batch of these. Mine already had a landing gear wedge in the kit.
I've just force fit the gear in for now. Will likely glue in with some PU over night.
Other than that, I think I ready for maiden! Got the A9 all programmed up, everything mounted. CG checked. Throws triple checked.
Just need to remember to pack a trash bag in case everything goes wrong!
jtaylor996 is offline Find More Posts by jtaylor996
Old Sep 21, 2012, 11:29 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
they always came with the wedge, I just thought a solid one would be better to drill through.
do not bring a trash bag, it is a bad luck omen, trust me. The one day I thought...you know I should have a trash bag in the car, just in case....I totaled a plane
Old Sep 22, 2012, 01:44 AM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
A couple of photos from today.
A small puzzle: Am I hand launching the plane or am I hand catching it?
groovejet is offline Find More Posts by groovejet
Old Sep 22, 2012, 02:08 AM
IMK is online now
IMK
Find More Posts by IMK
IMK
Joined Aug 2005
I'm guessing you are hand-catching based on the direction you are pointing
IMK is online now Find More Posts by IMK
Old Sep 22, 2012, 05:53 AM
3D Peter is offline
Find More Posts by 3D Peter
3D Peter's Avatar
Joined Oct 2011
looking at the grass in the area you fly IŽd say youŽre catching it, otherwhise you shouldnŽt be able to "land" it without bending the gear
so I guess it is a catch, ....at least, I would land it this way if I had no adequate surface to land the usual way
Pete
3D Peter is offline Find More Posts by 3D Peter
Old Sep 22, 2012, 09:11 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
catching, your are fly mode one and throttle is killed
Old Sep 22, 2012, 09:28 AM
KING of PING!
JDMCARPETS's Avatar
Joined Nov 2008
Catching,says 'low voltage' on transmitter screen
Old Sep 22, 2012, 09:33 AM
rthorne is offline
Find More Posts by rthorne
Quit Chucking My Wood
rthorne's Avatar
USA, TX, Amarillo
Joined Dec 2003
I've had my 48" in the box for some time now. I finally built it last night and just finished a test flight this morning.
Great airplane.
I have lots of room out here in the country so I get so step out my shop door and fly.
Awesome.
Rich
rthorne is offline Find More Posts by rthorne
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5823 Jun 16, 2016 04:33 PM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
