Old Apr 07, 2012, 08:07 AM
Joined Apr 2008
Almost done. Waiting for the Welder to cure.
chopper62 is offline Find More Posts by chopper62
Old Apr 07, 2012, 08:46 AM
Irg
ol' yellow eyes is back
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
I did a few things differently on my second. I reinforced the landing gear slot with epoxy. this was the first thing to break on the first one (after I smacked it into the ground of course). other thing was that I used welders for the tail hinges. the slots were just a little too wide for thin ca, but the welders filled them nicely and they seem very strong.
Irg is online now Find More Posts by Irg
Latest blog entry: laser repair
Old Apr 08, 2012, 02:29 PM
United States, NJ, Clayton
Joined Aug 2010
not a bad idea, welders is awesome, i guess the only disadvantage is welders weighs more then c.a. glue....
keithy4129 is offline Find More Posts by keithy4129
Old Apr 08, 2012, 06:22 PM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Welders is also known to eat depron, which is sandwiched in the tail feathers. From everything I've read, I would not use it for the hinges.
FireyFate is offline Find More Posts by FireyFate
Old Apr 08, 2012, 06:26 PM
Joined Aug 2010
Phoenix
huckin
addict
Old Apr 08, 2012, 06:27 PM
Joined Aug 2010
doesnt regular ca eat depron too? isnt that what they recommend for the hinges?
Old Apr 08, 2012, 06:39 PM
Joined Jan 2012
Hey guys, very excited, my build is complete and just fine tuning. Some pain points were installing the control horns into the pre-cut slots, motor mount screws - it was easier to hold the motor so the bracket was inside the compartment but close to the opening then insert the screws then press the motor against the firewall, line up the holes and screw in. Also I used long throw arms on my servo and it took awhile to get things so I had no servo stress at any position. All and all not a bad build.
My purchase experience was fantastic, Rob at ADChobbystore was great to deal with and very responsive, thanks Rob!
Question: I have a dx6i, what are you all using for radio settings on dual rates. Can we get a discussion on what some of you are using?
geewow is offline Find More Posts by geewow
Old Apr 09, 2012, 08:43 AM
Fly it 'till it breaks.
Motojunk's Avatar
Joined May 2011
Just went over this in the last 2 pages And yes, regular CA and Welders will eat the inner foam on this plane. However, I built mine as-per the manual with CA on the hinges and it hasn't caused me any problems. Just don't use a ton of thin CA anywhere, or if you must, use foam safe.
Motojunk is offline Find More Posts by Motojunk
Old Apr 09, 2012, 10:16 AM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Well, when I built mine 3DHS didn't have a manual yet. I went by what all the Skywing guys said... which was mainly not to use Welders or thin CA on the hinges... The general consensus is those glues work, but overall the hinges won't be as durable.
Here is what I went by:
Originally Posted by horton View Post
We've been experimenting with glue for the hinges. Good luck with medium foam-safe CA on hinges. Get them started, then put a drop on each side of hinge. Insert the hinge the rest of the way and flex for max deflection. Tape the surface at neutral and let set for a half an hour or so.
Thin CA works as well, but the medium foam-safe will help fill the gaps and not turn brittle.
Old Apr 09, 2012, 10:17 AM
Joined Aug 2010
do they make a foam safe that is thin? that would be the answer
Old Apr 09, 2012, 12:24 PM
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
i am pretty sure any thin CA is already foam safe, so they dont make it say foam safe although any thin Ca is foam safe.
i may be wrong tho...
skarface is offline Find More Posts by skarface
Old Apr 09, 2012, 12:32 PM
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
Foam Safe Ca (odorless) is available...
http://bsi-inc.com/Pages/hobby/oca.html
M.Putnam is offline Find More Posts by M.Putnam
Old Apr 09, 2012, 12:48 PM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Yup, you are wrong.
Old Apr 09, 2012, 01:42 PM
skarface's Avatar
Joined Aug 2011
well... i was told wrong because i heard that from some one else
Old Apr 09, 2012, 02:15 PM
Joined Aug 2010
yeah, the fumes from thin ca are wicked, I have just never seen thin foam safe, its always medium or thick, or is just not popular
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5497 May 01, 2013 09:31 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
