Old Mar 19, 2012, 10:17 AM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Originally Posted by Stoned doggie View Post
hey i have 2 1550mah 3s 25c lipo's and 1 1800mah 3s 25c lipo bot gens ace i only have 1 2200mah 30c eflite lipo for this plane do you think i could use the 1800mah and get like 4 min out of it atleast?
I accidentally put a 1550mah in mine and flew it for 5:30. Came down at 11.1 volts.
Man, it flies GREAT with the lighter battery. I never thought this plane hovered as well as my 51... but with the 1550mah it's sooooo easy.
FireyFate is offline Find More Posts by FireyFate
Old Mar 19, 2012, 02:53 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Got my maiden in today, 8 flights and I just love this thing, flys great, can't wait for more
3drcparts is offline Find More Posts by 3drcparts
Old Mar 19, 2012, 02:55 PM
3Dplank is offline
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
They are great. I got one when they first came out. Mine has been repaired numerous times One of my favorites to fly
3Dplank is offline Find More Posts by 3Dplank
Old Mar 19, 2012, 03:14 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
thanks sounds good.
yup got mine for christmas and only flew it 2-3 times, but now since i know i have 4 lipo's for this thing i am gonna be fling it atleast 4 times this coming weekend!
skarface is offline Find More Posts by skarface
Old Mar 19, 2012, 09:57 PM
DR. Watson is offline
Find More Posts by DR. Watson
United States, AR, Conway
Joined Jan 2012
Does anyone have a template for a new firewall? 3DHS is out and mine is toast. I am working on making a homegrown version but any help would be appreciated.
Thanks...
DR. Watson is offline Find More Posts by DR. Watson
Old Mar 20, 2012, 11:13 AM
Wrongstuff05 is offline
Find More Posts by Wrongstuff05
**Balsa Mulisha**
Wrongstuff05's Avatar
So. Cal
Joined Jun 2009
Originally Posted by Sonny Cheeba View Post
Question...... Anyone know why My alierons dont travel the same distance up and down??? I get more deflection when they are facing down but when they go up I get a considerably tarvel distance..... Thanks!!!!
If you're using a spektrum TX, make sure your flap input switch is set to inh. This will probably fix your problem.
Wrongstuff05 is offline Find More Posts by Wrongstuff05
Old Mar 20, 2012, 03:53 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Thanks...
I cut a new one but I didn't make a drawing of it. I just cut to almost fit and then trimmed to fit and epoxied it over what was left of the original.
cmala is offline Find More Posts by cmala
Old Mar 20, 2012, 05:36 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
BEC voltage
What voltage do you guys suggest using with the castle 10a bec and HS65MG's?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 20, 2012, 05:42 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
My 65's run fine on 6v. Some have pushed them a little higher.
tominator06 is offline Find More Posts by tominator06
Old Mar 20, 2012, 05:55 PM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
I'd go for 6v.
Old Mar 20, 2012, 07:28 PM
You down with EPP?
Houston, Tx
Joined May 2009
Sounds suitable. Thanks
Old Mar 20, 2012, 10:32 PM
Joined Jan 2012
Thanks, thats pretty much what I did as well. Once 3dhs gets some in I will make a template for all. Thanks!
Old Mar 21, 2012, 09:11 AM
Turbofans is offline
Find More Posts by Turbofans
Joined Nov 2009
I have the castle 10 amp bec and HS65MG's as well. I set the output voltage (with the castle link) at 5.3 volts. The 65's seemed to be over excited at the full 6.0 volts. The rated range on the box is 4.8 to 6.0 volts. I was thinking of halfway at 5.4 volts.
Turbofans is offline Find More Posts by Turbofans
Old Mar 22, 2012, 09:09 PM
Joined Nov 2009
I just bumped the voltage up to 5.6 volts. I was swinging an APC 14X7E with Turnigy 3S 2200 40C. It seemed a bit weak and my flying time was low @ 6 minutes. I propped down to a 13X6.5E.
Old Mar 24, 2012, 03:10 PM
davebloomer is offline
Find More Posts by davebloomer
Fly Low, Fly 3d, Repair Often
davebloomer's Avatar
United States, OK, Weatherford
Joined Jun 2011
sweet! i'm ordering one on the first.
davebloomer is offline Find More Posts by davebloomer
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5823 Jun 16, 2016 04:33 PM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
