Old Mar 16, 2012, 08:56 PM
mdv is offline
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
Originally Posted by cmala View Post
another +1 on the CA. Whenever you are "threading" the wood with a screw, reinforce it with CA.
Also, I use these for just about everything now
http://rtlfasteners.com/RC/d.html
metric or bust
mdv is offline Find More Posts by mdv
Old Mar 16, 2012, 09:18 PM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Originally Posted by janole View Post
Came a day early and she is already built and ready for a maiden, it's raining of course.
Omega 130g, 14x7 Hobbywing 40a platnium and hs-65mg, watts test was 534 watts at 43a on a fresh gens ace 2200 55c pack. Might try 13x6.5?
Nahhh fly it on a 14x7. I've got the exact same setup. It's sooooo much fun!
FireyFate is offline Find More Posts by FireyFate
Old Mar 17, 2012, 08:41 PM
Turbofans is offline
Find More Posts by Turbofans
Joined Nov 2009
The pants and skinny wheels were not performing well @ my grass field. Dubro 2.75" superleggera
Turbofans is offline Find More Posts by Turbofans
Old Mar 17, 2012, 08:57 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I get the feeling I'll be needing those as well, whats the sbach in the corner?
3drcparts is offline Find More Posts by 3drcparts
Old Mar 17, 2012, 09:31 PM
Joined Nov 2009
Dynam Sbach 342 from NitroPlanes.
Old Mar 17, 2012, 10:05 PM
3Dplank is online now
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
This plane can take a beating. I spent all day repairing it. It's ready for another beating
3Dplank is online now Find More Posts by 3Dplank
Old Mar 17, 2012, 11:06 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by plank420 View Post
Sweet thanks for the link gonna pic me up 100 of those badboys What size should I get for hs-65mgs? Do they have any to fit the hs85 mgs?
I use the 7/16" for everything from hs65 to 7955's
cmala is offline Find More Posts by cmala
Old Mar 18, 2012, 01:00 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
hey i have 2 1550mah 3s 25c lipo's and 1 1800mah 3s 25c lipo bot gens ace i only have 1 2200mah 30c eflite lipo for this plane do you think i could use the 1800mah and get like 4 min out of it atleast?
Because i will be at my dads and we have to drive to a park to fly and it sucks having to pack everything up in the car to fly one lipo.
o and ithought about getting more 2200mah but they wouldent make it here quick enough since i am going to his house next weekend.
skarface is offline Find More Posts by skarface
Old Mar 18, 2012, 01:33 PM
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
You can fly with all them batteries just watch your time, and how you manage your throttle. You should balance the plane with each battery though Fly and be merry
Old Mar 18, 2012, 01:51 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
ok thanks, yea i know that for each battery im gonna have to balance it.
Old Mar 18, 2012, 04:17 PM
Sonny Cheeba is offline
Find More Posts by Sonny Cheeba
United States, FL, Fort Lauderdale
Joined Feb 2012
Question...... Anyone know why My alierons dont travel the same distance up and down??? I get more deflection when they are facing down but when they go up I get a considerably tarvel distance..... Thanks!!!!
Sonny Cheeba is offline Find More Posts by Sonny Cheeba
Old Mar 18, 2012, 04:20 PM
CrashesALot is offline
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
Are you talking about moving them by hand, or with the servos? If with the servos, are both sides traveling the same amount in the "up" direction, if yes to both of those, sounds like your end points are adjusted incorrectly.
CrashesALot is offline Find More Posts by CrashesALot
Old Mar 18, 2012, 04:31 PM
Joined Feb 2012
i was talking about when the servos are on. I set up the edpoints correctly but it still isn't working
Old Mar 18, 2012, 05:46 PM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
When you're ailerons are at center, is the servo arm perpendicular to the control surface? If it's not, that could cause uneven throws.
Old Mar 18, 2012, 07:25 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
yes^ that or what radio are you using because i know when i was setting it up with my dx6i that i was still alittle unfimilar with to be able to change the travel adjust on one side then i had to move the stick to the left to be able to change it for the other side, also the flap in travel adjust as to be the same as what your aileron is set to.
again im just putting out guesses of what could be happening.
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5823 Jun 16, 2016 04:33 PM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
