Old Mar 13, 2012, 09:49 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
No, not enough power for this bad boy
3drcparts is offline Find More Posts by 3drcparts
Old Mar 13, 2012, 09:57 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Thanks.
chopper62 is offline Find More Posts by chopper62
Old Mar 14, 2012, 04:37 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Cmala where did you get those from?
Eagle34 is offline Find More Posts by Eagle34
Old Mar 14, 2012, 05:02 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
China
ebay
http://www.ebay.com/itm/10-Pcs-High-...item1c2436cbb9
cmala is offline Find More Posts by cmala
Old Mar 14, 2012, 07:28 AM
M.Putnam is offline
Find More Posts by M.Putnam
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
Originally Posted by LandCruiser View Post
Drilled a hole down the wings with an old arrow shaft with a drill bit glued to it.
Spliced some micro deans on the harness and decided I need to pick up another set for the tail led so I can remove the driver to save weight while not in use.
I also decided against using the arrow ends to attach the wing tip bars and went with some nylon wire keepers and the SFG mounting hole instead. I think I can adjust tension and they rotate if I drag a wing tip and not break the bar. Need to pick up some smaller keepers as the 1/4" I had on hand require 2 pieces of split fuel tubing.
Going to try a foam wire keeper on the tail feather bar.
I'll post more pics when finished.
Please keep us posted on your setup. Might try this...
M.Putnam is offline Find More Posts by M.Putnam
Old Mar 14, 2012, 08:28 AM
mdv is offline
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
Originally Posted by CrashesALot View Post
Speaking of crashing, in the main part of the fuse (from right behind where the turtledeck starts forward) is it just epp, or is there any depron in there? I need to do some decent repair work and I was planning on just using welders, but I know there is depron in the wings and a few other spots that will get eaten by the welders.
I've been wondering the same thing. Is it only EPP in the front of the fuselage? This plane sure could use some thicker ply up front.
mdv is offline Find More Posts by mdv
Old Mar 14, 2012, 10:36 AM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Originally Posted by chopper62 View Post
Did a quick search but did not find the answer. After reading 30 pages, I stopped. So here is the question - can I use the E-Flite Park 450 890KV? I've this NIB motor and would love to pull the trigger on this bad boy as the daily flyer.
Even a 480 would be too small for this plane.
FireyFate is offline Find More Posts by FireyFate
Old Mar 14, 2012, 05:30 PM
davebloomer is offline
Find More Posts by davebloomer
Fly Low, Fly 3d, Repair Often
davebloomer's Avatar
United States, OK, Weatherford
Joined Jun 2011
Does any1 have a video of a crash and damage done on this plane? Also how would it compare in durability to like a 32 epp edge. And how would it compare to balsa.
Lets say 32" epp edge Is a 10 and balsa is a 1 on the durability scale where does the 48 extra fall.
davebloomer is offline Find More Posts by davebloomer
Old Mar 14, 2012, 05:40 PM
Joined Jun 2011
Just realized how rediculous of a question that is... But I want something bigger than a profile epp but don't wanna fly a balsa plane for a while.
Old Mar 14, 2012, 06:25 PM
Turbofans is offline
Find More Posts by Turbofans
Joined Nov 2009
This plane is for you. It's bigger than a profile EPP but not a balsa.
Turbofans is offline Find More Posts by Turbofans
Old Mar 14, 2012, 06:52 PM
CrashesALot is offline
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
Dave,
I can't fully help you as I have no video, but here is the current state of my Extra. I can tell you this plane takes an extreme beating. If you need to repair it and you have a little skill, you can keep putting it back together.
I absolutely destroyed my motorbox on my maiden (tried flying it at night, lighted only by some dim parking lot lights ... went vertical after the end of a straight away and went right into a tree . That is where the big chunk came out of the wing. I used the throttle to get out of the tree, but it was pointing straight down and so I went nose first into the pavement). I repaired everything within an hour or two and it flew great (a miracle considering the firewall was in a bazillion pieces and I never bought the replacement motorbox kit for it) ... read as the motor was about 10 feet from the plane
She flew great with minor bumps and abuse until this past weekend where I was doing fast rollers (I would call them rifle rollers, but they are no where as fast as Wamsy's or Joe's), when I was about 7 feet up and I messed up and pulled when I should have pushed and nosed her in really really hard. It would have destroyed a balsa plane.
The pics show the current state, and with about an hour or so of work, I am hoping she'll be back to new (unless I decide to wait for a new fire wall).
I hope this helps.
CrashesALot is offline Find More Posts by CrashesALot
Old Mar 14, 2012, 07:05 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Mine is coming on Friday, can't wait. I flew a friends and it fly more like balsa than any of my foamies or profiles, yet it slows down so nicely and is so predictable. The only issue I could see was the firewall and motor mounting screws and the landing gear seemed weak
Old Mar 14, 2012, 07:41 PM
Team 3DHS
Western CT
Joined Aug 2009
Don't worry about the firewall, I think it is plenty strong enough. Mine was fine (except for the strong impacts with the ground ... lol)
Old Mar 14, 2012, 08:18 PM
mdv is offline
mdv
mdv
Joined Jun 2009
Despite what others are saying, I don't think this plane can handle much of a crash. I have nosed my Telink Yak in much harder with no damage. I would rather fly this than the Yak but I'd much rather crash the Yak.
Old Mar 14, 2012, 08:29 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I don't know what a telink yak is but this plane is much more damage resistant than any of my balsa planes.
A profile foamy will take more abuse due to the reduced mass but you have more sacrifices in flying characteristics with a profile foamy.
This plane flys much closer to a balsa plane but is definitely more durable than balsa.
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5823 Jun 16, 2016 04:33 PM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
