Old Mar 11, 2012, 03:01 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
I'm lazy but where is are the build videos in this thread?
It wouldn't be a bad idea to add them to the first post.
HugoCraft is offline Find More Posts by HugoCraft
Old Mar 11, 2012, 03:05 PM
3Dplank is offline
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Here ya go https://3dhobbyshop.3dcartstores.com...a%20Manual.pdf
3Dplank is offline Find More Posts by 3Dplank
Old Mar 11, 2012, 03:24 PM
Aerobatic Fanatic
HugoCraft's Avatar
Joined Sep 2007
found the link:
BUILD VIDEOS
http://www.rcgroups.com/forums/showt...0#post20289091
Old Mar 11, 2012, 03:55 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Link to build videos added to first post.
tominator06 is offline Find More Posts by tominator06
Old Mar 11, 2012, 08:58 PM
LandCruiser is offline
Find More Posts by LandCruiser
LandCruiser's Avatar
Little Rock, AR
Joined Jul 2005
Originally Posted by CrashesALot View Post
Please do, I'm very curious.
Drilled a hole down the wings with an old arrow shaft with a drill bit glued to it.
Spliced some micro deans on the harness and decided I need to pick up another set for the tail led so I can remove the driver to save weight while not in use.
I also decided against using the arrow ends to attach the wing tip bars and went with some nylon wire keepers and the SFG mounting hole instead. I think I can adjust tension and they rotate if I drag a wing tip and not break the bar. Need to pick up some smaller keepers as the 1/4" I had on hand require 2 pieces of split fuel tubing.
Going to try a foam wire keeper on the tail feather bar.
I'll post more pics when finished.
LandCruiser is offline Find More Posts by LandCruiser
Old Mar 11, 2012, 11:48 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Is there an easier way to bolt up the Omega motor in this plane?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 12, 2012, 12:11 AM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I just sliced the EPP on the front and then used a little welders to patch it back up....
You're likely to need to get in there for a firewall repair anyway after the first 5 crashes or so....
Others just used a screwdriver with tape to hold the screw onto it until you get it started...or similar methods.
Bivens is offline Find More Posts by Bivens
Old Mar 12, 2012, 11:32 AM
CrashesALot is offline
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
Speaking of crashing, in the main part of the fuse (from right behind where the turtledeck starts forward) is it just epp, or is there any depron in there? I need to do some decent repair work and I was planning on just using welders, but I know there is depron in the wings and a few other spots that will get eaten by the welders.
CrashesALot is offline Find More Posts by CrashesALot
Old Mar 12, 2012, 12:26 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Awesome. I just ordered twenty of these
I hope to be able to build two similar setups before SEFF
The more pictures you post the better
cmala is offline Find More Posts by cmala
Old Mar 12, 2012, 08:11 PM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
I am a fan of the cheap LED strips. They have their own sticky already on them and come in about every color you could want. I may work up some lights in the coming months and I'll put some pics up when I do.
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Mar 12, 2012, 08:12 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I've done planes with the self adhesive strips. I wanted to try something different
Old Mar 12, 2012, 09:41 PM
Little Rock, AR
Joined Jul 2005
Let me know what you need detailed pics of and I'll see what I can do.
Old Mar 13, 2012, 08:46 AM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Cool..you're building one for me to fly...
Old Mar 13, 2012, 10:41 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
If I can get it worked out it should be similar to the Aurora Genesis system so yeah, you can install it on one of your planes at SEFF
Old Mar 13, 2012, 09:36 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Did a quick search but did not find the answer. After reading 30 pages, I stopped. So here is the question - can I use the E-Flite Park 450 890KV? I've this NIB motor and would love to pull the trigger on this bad boy as the daily flyer.
chopper62 is offline Find More Posts by chopper62
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 5823 Jun 16, 2016 04:33 PM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 4 Oct 23, 2011 11:21 AM
Sold 3DHobbyshop 38" EPP Slick NIB cjdscratch Aircraft - Electric - Airplanes (FS/W) 2 Oct 22, 2011 09:58 PM
Found 3DHobbyshop 55" Extra 300SHP gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2011 06:56 PM
48" Bat EPP and 48" Bee EPP closeouts stegre Aircraft - Sailplanes (FS/W) 1 May 20, 2005 10:20 AM
