Dillingham, Alaska
Joined Jan 2010
I can't answer many of your questions but yes, it can do elevons.
I'm trying to figure out the OSD portion as well. I have an Eagle Tree setup as well and I don't want to duplicate a lot of sensors so I've been looking at their minimOSD but it's been out of stock for quite a while. JDrones is just coming to market with their version of OSD that uses the same board and from what I can tell the big plus for using the JDrones version is the ability to use different supplied power voltages and it's about $10 cheaper. http://store.jdrones.com/category_s/44.htm The Mission Planner software appears to offer the ability of auto take-off and land but I haven't tried it yet. What are you going to install it into? No baro built in as far as I've seen. The list of available sensors supplied by DIYDrones can be found here: https://store.diydrones.com/category_s/12.htm I'm a complete newbie at this so take everything I've stated with a grain of salt. I've played around with Mission Planner but I haven't put it into action in my plane yet. I'm just going through the configuration stages right now. -Mike |
Ardupilot supports elevon mixing for flying wings, thats also part of the setup done through the mission planner. A standard RC control system is required, the telemetry modems (xbee) are optional but it is nice for tuning the autopilot and the moving map etc. When in one of the auto modes (fly by wire, waypoint, RTL) you can use a joystick connected through the ground station (uses mavlink through the xbee, not PPM) but I understand to get good performance you need to use 4 modems to keep latency down. Check out this post talking more about this http://www.diydrones.com/profiles/bl...ource=activity The mission planner doesn't support the PCTx device. I think for best performance you would want to just use that device with its native software, I can't think of any advantage of it running through mission planner. I assume now you just connect the PCTx to the UHF system you have directly and fly like that? I wouldn't change that setup. I also am pursuing joystick control but I'm building a joystick transmitter based on arduino instead of using a computer. Check out this thread if your interested http://www.rcgroups.com/forums/showthread.php?t=1231017 diydrones/3drobitics has an OSD called minimosd This is designed to work with APM or any autopilot that speaks mavlink. The big thing here that is different from most FPV OSD's is that there are not direct inputs, if you want RSSI displayed you need to connect that to the ardupilots analog input for rssi. Same goes for current sensor, connects directly to APM then the OSD gets its info through mavlink. I read on DIYDrones that antenna tracking via the mission planner will happen at some point (will need a usb servo driver). http://diydrones.com/forum/topics/tr...mment%3A793816 Its also possible to use Ardustation if you don't want to use a laptop @ the field. http://diydrones.com/profiles/blogs/...a-tracking-and The APM2 has a Baro built in so thats one less thing to buy Compatible airspeed sensors and sonar can be purchased directly from DIYDrones. The ones they sell are directly supported, you just connect them and enable them during setup in the mission planner software. Sorry for the bad typing, I was in a hurry
Dillingham, Alaska
Joined Jan 2010
I just received the MinimOSD from DIYDrones:
https://store.diydrones.com/Ardupilo...-apmminosd.htm I've got the EagleTree OSD but, like you, didn't want to duplicate a bunch of equipment on my plane. I have only soldered on the pin connectors so far and haven't fired it up yet. -Mike |
Hey Techspy, the way to do antenna tracking with the ardupilot is via the ardustation
![]() http://store.diydrones.com/ArduStation_p/de-0001-01.htm http://www.diydrones.com/profiles/bl...for-arducopter I read on DIYDrones that they will add antenna tracking to the mission planner via a usb servo controller and I think HK's GCS already can do this but that requires a laptop at the field. I only plan to drag mine out while tuning the autopilot after that I will remove the xbee (or apc220 in my case) and just use the OSD as I don't plan on doing antenna tracking. |
| Thread Tools | |
| Discussion Selling my Ardupilot Mega | ababb88 | UAV - Unmanned Aerial Vehicles | 9 | Oct 05, 2011 05:55 PM |
| Sold ArduPilot Mega RTF | hobbyboy | FPV/RPV - Equipment and Vehicles (FS/W) | 0 | Sep 26, 2011 02:52 PM |
| Question Ardupilot Mega: how much time do I have to stabilize the gyros? | marhar | UAV - Unmanned Aerial Vehicles | 1 | Sep 23, 2011 09:29 AM |
| Discussion ArduPilot Mega kit from DIY Drones any good? | spacecase | Multirotor Talk | 11 | Aug 11, 2011 01:07 PM |
| Wanted Full ArduPilot Mega kit | actionplus | Aircraft - Electric - Multirotor (FS/W) | 2 | Aug 11, 2011 01:23 AM |
