Hey guy's, can anyone tell me if this combo would suit the savage flux xs, i was thinking if the combo would be equal power to the stock xs electrics i will build up an xs, they both are 4000kv motors & can both run on 3S lipo's but still being new to electrics i don't know if that means they would be around the same power.
Here is the specs of my combo.
Cheers.
An extremely powerful brushless system for any 1/10 or 1/12 scale truck, car or buggy.The specially designed motor gives more run time and comes with thermal protection.Brushless Electronic Speed Controller(ESC).
Features:
Enhanced throttle response, excellent acceleration,strong brakes and throttle linearity
Programable with a HKSS programming card to make adjustments.
Automatically detects the number of cells within the battery pack.
Multiple protection features: Low voltage cut-off protection, over-heat protection, throttle signal loss protection and motor blocked protection
Compatible with NOVAK, LRP , ORION Sensored brushless motor
ESC Spec.
Continuous Current: 100A
Burst Current: 540A
Resistance: 0.0004ohm
Suitable Car: 1/8, 1/10, 1/12 on and off road.
Battery: 2-3 cells Lipo (5-10 cells NI-xx)
BEC output: 6V/3A switch mode buit-in
Motor type: Sensorless and sensored brushless motors
Dimension: 43 x 39 x 30mm
Weight: 102g
Motor Spec.
Model: 3650
Kv: 4000
Scale: 1:10
Max Current: 41Amp
Turns: 8.5T
Weight: 165g
Diameter: 36mm
Length: 52.5mm
Shaft length: 15mm
Shaft Diameter: 3.17mm
