Old Dec 03, 2011, 09:35 PM
corsair167 is online now
Find More Posts by corsair167
USA, IN, Seymour
Joined Oct 2009
Moki Parts
Looking for a website that actually has Moki/Mark parts. I need a front bearing housing and complete carb. And no an OS 7D carb is too small.
corsair167 is online now Find More Posts by corsair167
Old Dec 04, 2011, 01:04 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Global sells Mark parts...
http://globalservices.globalhobby.co...arkEngines.asp
Hemikiller is offline Find More Posts by Hemikiller
Old Dec 04, 2011, 02:02 PM
dmcquinn is offline
Find More Posts by dmcquinn
dmcquinn's Avatar
United States, MO, Chesterfield
Joined Jan 2004
I have some parts for a Moki 180 glow engine. What engine do you have?
dmcquinn is offline Find More Posts by dmcquinn
Old Dec 04, 2011, 10:32 PM
USA, IN, Seymour
Joined Oct 2009
I need a complete carb. Also a front bearing housing. A crash broke off the carb off the front housing and damaged the carb mounting area. Carb departed the area. I bought it used but repairable..........PS I have a Moki 1.80
Old Dec 04, 2011, 11:18 PM
dmcquinn is offline
dmcquinn's Avatar
Joined Jan 2004
I have the front housing with thrust washer, complete carb with needle valve assembly and needle valve, and the crankshaft and bearings are still installed inside the front housing. I can't find my gear puller to pull it apart. I want $50 for the whole assembly.
Email me (dmcquinn@charter.net) if you are interested and I will take some pictures.
My Moki 180 2cycle glow engine had the rear bearing fail. I can see the failed bearing from the back of the front housing. The pieces of metal from the bearing race destroyed the piston and I was never able to find another one. So that's how I ended up with this part. The carburetor is deeply scratched from where I used pliers on the carburetor housing. If you buy this assembly from me you will have to get the front thrust washer off the front of the crank and get the crankshaft (which is probably still good) out of the front housing.
Old Dec 05, 2011, 08:25 AM
USA, IN, Seymour
Joined Oct 2009
Originally Posted by Hemikiller View Post
Thanks for the information...........
Old Dec 06, 2011, 04:27 PM
USA, IN, Seymour
Joined Oct 2009
Please respond with a private message. I would like pics and wish to pursue this possibility.....thx
Old Mar 05, 2012, 02:43 PM
spitfire1999 is offline
Find More Posts by spitfire1999
United States, CA, San Jose
Joined Sep 2008
Anyone have a needle valve for a Moki 180 glow?
spitfire1999 is offline Find More Posts by spitfire1999
Old Mar 18, 2012, 01:02 PM
Husker is offline
Find More Posts by Husker
United States, NV, Sparks
Joined May 2008
Moki Parts
Try BJ's engine service. They are the new Moki/Mark engine guy.
Husker is offline Find More Posts by Husker
For Sale Moki 1.8 engine NIB with accessories (Original Moki) $325.00 Gravyzrx Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 29, 2011 10:51 PM
Discussion Where can I get Moki parts? DGrant Engines 6 Apr 08, 2011 04:22 PM
Discussion Moki 210 Parts? New Diamond Engines 3 Sep 11, 2009 09:57 PM
Off Site Moki 2.10 Parts augeringin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 05, 2008 12:25 PM
Found Moki 1.80 Parts engine HUNT Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 22, 2006 10:34 PM
